查看: 3941|回復(fù): 1
藍牙+1602+8盞燈+蜂鳴器+指示燈+Proteus仿真程序
ID:582515 發(fā)表于 2020-1-13 10:35 | 顯示全部樓層 |閱讀模式
通過手機APP(HC-06串口助手)連接藍牙模塊,發(fā)送0-9的數(shù)據(jù),1602顯示出相應(yīng)的數(shù)據(jù)。
實物實現(xiàn)的結(jié)果
實物實現(xiàn)的結(jié)果
單片機源程序如下:
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. #define out P0
  6. sbit RS=P2^0;
  7. sbit RW=P2^1;
  8. sbit E=P2^2;
  9. sbit led8=P2^5;//指示燈
  10. sbit fmq=P2^4;        //蜂鳴器
  11. void delay(uint z)//延時函數(shù)
  12. {
  13.       uint x,y;
  14.         for(x=z;x>0;x--)
  15.                 for(y=120;y>0;y--);
  16. }
  17. void check_busy(void) //讀狀態(tài)
  18. {
  19.   uchar dt;
  20.   do
  21.   {
  22.     dt=0xff;
  23.         E=0;
  24.         RS=0;
  25.         RW=1;
  26.         E=1;
  27.         dt=out;
  28.   }while(dt&0x80);
  29.   E=0;
  30. }
  31. void write_command(uchar com)//寫命令
  32. {
  33.   check_busy();
  34.   E=0;
  35.   RS=0;
  36.   RW=0;
  37.   out=com;
  38.   E=1;
  39.   _nop_();
  40.   E=0;
  41.   delay(1);
  42. }
  43. void write_data(uchar dat)//寫數(shù)據(jù)
  44. {
  45.   check_busy();
  46.   E=0;
  47.   RS=1;
  48.   RW=0;
  49.   out=dat;
  50.   E=1;
  51.   _nop_();
  52.   E=0;
  53.   delay(1);
  54. }
  55. void LCD_initial(void)//初始化
  56. {
  57.         write_command(0x38);
  58.         _nop_();
  59.         write_command(0x0C);
  60.         _nop_();
  61.         write_command(0x06);
  62.         _nop_();
  63.         write_command(0x01);
  64.         delay(1);
  65. }
  66. void string(uchar ad,uchar *s)//顯示函數(shù)
  67. {
  68.         write_command(ad);
  69.         while(*s>0)
  70.         {
  71.                 write_data(*s++);
  72.                 delay(100);
  73.         }
  74. }
  75. void main()
  76. {
  77.   uchar temp=0;
  78.   TMOD=0x20;
  79.   TH1=0xfd;
  80.   TL1=0xfd;
  81.   SCON=0x50;
  82.   PCON=0x00;
  83.   TR1=1;
  84.   LCD_initial();
  85.                 string(0x80,"Bluetooth Test");
  86.                 string(0xc0,"Receive Figure:");
  87.   while(1)
  88.   {
  89.     while(RI==0);
  90.         RI=0;
  91.         temp=SBUF;
  92.         switch(temp)
  93.         {
  94.                 case 0:
  95.                 write_command(0xcf);
  96.                 write_data('0'+temp);
  97.                 break;
  98.
  99.                 case 1:
  100.                 write_command(0xcf);
  101.                 write_data('0'+temp);
  102.                 break;
  103.                 case 2:
  104.                 write_command(0xcf);
  105.                 write_data('0'+temp);
  106.                 break;
  107.                 case 3:
  108.                 write_command(0xcf);
  109.                 write_data('0'+temp);
  110.                 break;
  111.                 case 4:
  112.                 write_command(0xcf);
  113.                 write_data('0'+temp);
  114.                 break;
  115.                 case 5:
  116.                 write_command(0xcf);
  117.                 write_data('0'+temp);
  118.                 break;
  119.                 case 6:
  120.                 write_command(0xcf);
  121.                 write_data('0'+temp);
  122.                 break;
  123.                 case 7:
  124.                 write_command(0xcf);
  125.                 write_data('0'+temp);
  126.                 break;
  127.                 case 8:
  128.                 write_command(0xcf);
  129.                 write_data('0'+temp);
  130.                 break;
  131.                 case 9:
  132.                 write_command(0xcf);
  133.                 write_data('0'+temp);
  134.                 break;
  135.         }
  136.   }
  137. }
藍牙 1602 8盞燈 蜂鳴器 指示燈 仿真.zip (167.77 KB, 下載次數(shù): 51)
admin + 50 共享資料的黑幣獎勵!
ID:699249 發(fā)表于 2020-2-29 22:03 | 顯示全部樓層
好像沒有proteus的工程文件
