查看: 2807|回復(fù): 2
DS1302,四位共陽極數(shù)碼管顯示時鐘,可調(diào)時間
ID:586236 發(fā)表于 2020-1-13 16:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define D P1   //段選
#define W P2   //位選
sbit IO=P3^3;   //數(shù)據(jù)口
sbit SCLK=P3^4;   //控制數(shù)據(jù)時鐘
sbit RST=P3^2;    //使能端、復(fù)位端
sbit w1=P2^4 ;
/************按鍵引腳定義***********/
sbit s1=P3^5; //按鍵 加
sbit s2=P3^6; //按鍵 減
sbit s3=P3^7;   //按鍵 選擇
sbit led=P2^3; //閃爍的小數(shù)點
uchar s, knum=0,snum,fnum;
bit flag;
/***********寫時分秒地址************/
#define write_shi  0x84
#define write_fen  0x82
#define write_miao 0x80
/***********讀時分秒地址************/
#define read_shi  0x85
#define read_fen  0x83
#define read_miao 0x81
bit miao_flag;
char miao_num;
char Dmiao;
char shi,fen,miao;  //讀出數(shù)據(jù)存儲變量
uchar d[]={0Xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};  //段選
void delay(uint z)         //延時函數(shù),z的取值為這個函數(shù)的延時ms數(shù),如        delay(200);大約延時200ms.
{            //delay(500);大約延時500ms.
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void t0_init()  //定時50ms一個中斷
  TMOD=0X01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
uchar read_1302(uchar add) //讀函數(shù)
uchar i,date;
RST=0;   //禁止讀寫數(shù)據(jù)
for(i=0;i<8;i++)
  RST=1;
  SCLK=0;
  IO=add&0x01;
  add>>=1;
  SCLK=1;
for(i=0;i<8;i++)
  if(IO)
   date=date|0x80;
   date=date|0x00;
  SCLK=1;
  date>>=1;
  SCLK=0;
RST=0;
date=date/16*10+date%16;//進制轉(zhuǎn)換 16轉(zhuǎn)10進制
IO=0;     //數(shù)據(jù)讀完后,IO口必須為0,不然小時一直顯示85
return date;
void write_1302(uchar add,uchar dat)  //寫函數(shù)
uchar i;
SCLK=0;
for(i=0;i<8;i++)    //寫地址
  RST=1;     //允許讀寫數(shù)據(jù)
  SCLK=0;
  IO=add&0x01;
  add>>=1;
  SCLK=1;
for(i=0;i<8;i++)    //寫數(shù)據(jù)
  SCLK=0;
  IO=dat&0x01;
  dat>>=1;
  SCLK=1;
RST=0;
void init_1302() //初始化函數(shù) 設(shè)置時間
  flag=read_1302(0x81);
  if(flag&0x80)
write_1302(0x8e,0x00);  //保護取消,可以進行讀寫操作
write_1302(write_miao,0x56);
write_1302(write_fen,0x49);
write_1302(write_shi,0x14);
write_1302(0x90,0xa5);
write_1302(0x8e,0x80);   //保護啟動,不能進行讀寫操作
void display(uchar shi,uchar fen)   //顯示函數(shù)
if(knum==0)
  snum=30;
  fnum=30;
if(knum==1)
  fnum++;
  snum=30;
if(knum==2)
  snum++;
  fnum=30;
if(snum>=30)
  W=0x7F; //位選
  s=d[shi/10];//段碼先給s,判斷其值是否為0,
  if(s==0xc0)
  W=0xff;
  D=0xff;
                D=s;//s不為零則給D,讓其顯示
  delay(5);
  D=0Xff;         //消隱
  if(miao_flag)       //小數(shù)點閃爍
      miao_flag=0;
   W=0xbF;
   D=d[shi%10];
   delay(5);
   D=0Xff;         //消隱
  W=0Xff;
   W=0xbF;
   D=d[shi%10];
   delay(5);
   D=0Xff;
  W=0Xff;
     if(snum==60)
   snum=0;
if(fnum>=30)
  W=0xdF;
  D=d[fen/10];
  delay(5);
  D=0Xff;
  W=0Xff;         //消隱
  W=0xeF;
  D=d[fen%10];
  delay(5);
  D=0Xff;
  W=0Xff;         //消隱
  if(fnum==60)
   fnum=0;
  D=0Xff;
  W=0Xff;
void read_sf()
miao=read_1302(read_miao);
/*if(miao!=Dmiao)
  Dmiao=miao;
  TR0=1;
  miao_flag=1;
fen=read_1302(read_fen);
shi=read_1302(read_shi);
display(shi,fen);
void keyscan()           //按鍵掃描函數(shù)
if(s3==0)           //選擇按鍵按下
  delay(10);
  if(s3==0)
   while(!s3)
    display(shi,fen); //加上這句,按鍵按下就不會閃
   knum++;
   if(knum==1)        //分閃爍
     write_1302(write_miao,0x80);
   if(knum==3)         //時鐘啟動
    knum=0;
    write_1302(write_miao,0x00);
if(knum==1)        //分鐘調(diào)節(jié)
  if(s1==0)       //加
   delay(10);
   if(s1==0)
    while(!s1)
    fen++;
    if(fen==60)
     fen=0;
    write_1302(write_fen,fen/10*16+fen%10); //寫入1302
//    read_sf();     //讀出時間,然后顯示
  if(s2==0)
   delay(10);
   if(s2==0)
    while(!s2)
    fen--;
    if(fen==-1)
     fen=59;
    read_sf();
if(knum==2)
  if(s1==0)
   delay(10);
   if(s1==0)
    while(!s1)
    shi++;
    if(shi==24)
     shi=0;
    write_1302(write_shi,shi/10*16+shi%10);
    read_sf();
  if(s2==0)
   delay(10);
   if(s2==0)
    while(!s2)
    shi--;
    if(shi==-1)
     shi=23;
    read_sf();
init_1302();
t0_init();
{ if(miao_num<10)
     led=0;
      if(miao_num>=10)
      led=1;
  read_sf();
  keyscan();
void t0_timer() interrupt 1
TMOD=0X01;
miao_num++;
if(miao_num>=25)
  miao_num=0;
  miao_flag=1;
ID:1 發(fā)表于 2020-1-14 14:42 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:36359 發(fā)表于 2020-2-12 10:50 | 只看該作者
看程序應(yīng)該使用處理器的P1的8個端口和P2的4個端口進行控制4位LED數(shù)碼管顯示
