在網(wǎng)上找的51秒表程序,下載在普中科技的開發(fā)板上 按鍵沒反應(yīng) ,請(qǐng)大神幫忙解答一下 ,或者幫忙給寫個(gè)程序最好不過了,謝謝 51單片機(jī) 6位秒表計(jì)時(shí) “分、秒、毫秒”精度越高越好 或者“秒、毫秒”的也可以
- #include
- #define uchar unsigned char
- #define uint unsigned int
- #define PIN0 P0 //數(shù)碼管段選端
- #define PIN1 P1 //數(shù)碼管位選端
- #define PIN3 P3 //十分位數(shù)碼管的段碼端
- sbit start=P3^2; //啟動(dòng)/暫停按鈕
- sbit reset=P3^3; //復(fù)位按鈕
- uint cnt=0; //1s的次數(shù)的計(jì)數(shù)值
- uint num=0; //進(jìn)入中斷次數(shù)的計(jì)數(shù)值(一次50ms)
- uint num1=0; //0.1s的次數(shù)的計(jì)數(shù)值
- uchar code table[]={0x3f,0x06,0x5b,
- 0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f};
- //不帶小數(shù)點(diǎn)的共陰極數(shù)碼管段碼0-9
- uchar code table1[]={0xbf,0x86,
- 0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
- //帶小數(shù)點(diǎn)的共陰極數(shù)碼管段碼0-9
- char code table2[]={0xc0,0xf9,0xa4,
- 0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- //不帶小數(shù)點(diǎn)的共陽(yáng)極數(shù)碼管段碼0-9
- void Display(uint w,uint a,uint b,uint c,uint d); //聲明顯示函數(shù)
- void InitTimer0(); //聲明定時(shí)器初始化函數(shù)
- void Delayms(uint x); //聲明延時(shí)函數(shù)
- void main()
- uint ms100=0; //秒的十分位
- uint s,s1,min,min1,minu=0;
- //依次是秒的個(gè)位,秒的十位,分的個(gè)位,分的十位
- InitTimer0(); //初始化定時(shí)器
- while(1) //進(jìn)入死循環(huán)
- if(start==0) //檢測(cè)啟動(dòng)/暫停鍵是否按下
- Delayms(20); //延時(shí)消抖
- if(start==0) //消抖之后再次檢測(cè)
- TR0=!TR0; //定時(shí)器的控制位取反
- while(!start); //等待按鍵釋放
- if(reset==0) //檢測(cè)復(fù)位鍵是否按下
- if(reset==0) //消抖之后再次檢測(cè)
- num=0;
- num1=0; //進(jìn)入中斷次數(shù)值清0
- ms100=0; //十分位的計(jì)數(shù)值清0
- cnt=0; //秒的計(jì)數(shù)值清0
- minu=0; //分的計(jì)數(shù)值清0
- while(!reset); //等待按鍵釋放
- if(num1>=2) //檢測(cè)是否達(dá)到0.1s,(兩個(gè)50ms)
- num1=0; //進(jìn)入中斷次數(shù)值清零
- ms100++; //秒的十分位的計(jì)數(shù)值加1
- if(ms100>=10) //若秒的十分位計(jì)數(shù)值達(dá)到10
- ms100=0; //清零秒的十分位的計(jì)數(shù)值
- num1=0; //進(jìn)入中斷次數(shù)值置0
- if(num>=20) //判斷計(jì)時(shí)時(shí)間是否達(dá)到1s(20個(gè)50ms)
- num=0; //進(jìn)入中斷次數(shù)值置0
- cnt++; //秒的計(jì)數(shù)值加1
- if(cnt>=60) //判斷是否達(dá)到60s
- cnt=0; //若達(dá)到60s,將秒的計(jì)數(shù)值置零
- minu++; //分的計(jì)數(shù)值加1
- if(minu>=60) //判斷是否達(dá)到60分鐘,一般秒表是用不到60分的,這是為了程序的嚴(yán)謹(jǐn)性
- TR0=!TR0; //達(dá)到60分鐘則關(guān)閉定時(shí)器并清零所有的計(jì)數(shù)值
- num1=0;
- num=0;
- ms100=0;
- cnt=0;
- minu=0;
- s=cnt%10; //從秒的計(jì)數(shù)值里面分離秒的個(gè)位
- s1=cnt/10; //從秒的計(jì)數(shù)值里面分離秒的十位
- min=minu%10; //從分的計(jì)數(shù)值里面分離分的個(gè)位
- min1=minu/10; //從分的計(jì)數(shù)值里面分離分的十位
- Display(ms100,s,s1,min,min1); //顯示這5個(gè)數(shù)
- void InitTimer0() //定時(shí)器初始化函數(shù)
- TMOD=0x01; //選擇定時(shí)器0的工作方式1
- TH0=(65536-45872)/256; //裝初值(定時(shí)50ms),晶振11.0592MHz
- TL0=(65536-45872)%256;
- EA=1; //打開總中斷
- ET0=1; //打開定時(shí)器中斷
- TR0=0; //先不要啟動(dòng)定時(shí)器
- void TIMER0() interrupt 1 //定時(shí)器中斷服務(wù)函數(shù)
- TH0=(65536-45872)/256; //重裝初值
- num++; //讓進(jìn)入中斷次數(shù)值加1,用于判斷是否達(dá)到1s
- num1++; //讓進(jìn)入中斷次數(shù)值加1,用于判斷是否達(dá)到0.1s
- void Delayms(uint x) //延時(shí)xms
- uint i,j;
- for(i=x;i>0;i--)
- for(j=110;j>0;j--);
- void Display(uint w,uint a,uint b,uint c,uint d) //定義顯示函數(shù)
- PIN3=table2[w]; //秒的十分位的段選
- Delayms(5);
- PIN0=table[a]; //秒的個(gè)位的段選
- PIN1=0x7f; //秒的個(gè)位的位選
- Delayms(5);
- PIN0=table[b]; //秒的十位的段選
- PIN1=0xbf; //秒的十位的位選
- Delayms(5);
- PIN0=table1[c]; //分的個(gè)位的段選(帶小數(shù)點(diǎn))
- PIN1=0xdf; //分的個(gè)位的位選
- Delayms(5);
- PIN0=table[d]; //分的十位的段選
- PIN1=0xef; //分的十位的位選
- Delayms(5);
