查看: 3304|回復(fù): 2
stm32f103RCt6 驅(qū)動ADAU1701DSP源代碼
ID:511543 發(fā)表于 2020-1-15 09:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#ifndef _ADAU1701_H
#define _ADAU1701_H
#include "stm32f10x.h"
#include "sys.h"
#define ADAU1701_I2C_WR    0        /* 寫控制bit */
#define ADAU1701_I2C_RD    1        /* 讀控制bit */
#define   ClockSpeed            100000
typedef   unsigned short       ADI_DATA_U16;
typedef   const int            ADI_REG_TYPE;                    //define data storing in flash.
#define   DEVICE_ADDR_         0x68                   //設(shè)備地址
#define   Address_Length          2                        //define address as 16bit. //define address as 16bit.
#define   SIGMASTUDIOTYPE_FIXPOINT      0
#define   SIGMASTUDIOTYPE_INTEGER       1
* 閱讀設(shè)備寄存器
#define SIGMA_READ_REGISTER( devAddress, address, length, pData ) {/*TODO: implement macro or define as function*/}
* 設(shè)置寄存器字段的值
#define SIGMA_SET_REGSITER_FIELD( regVal, fieldVal, fieldMask, fieldShift )  \
        { (regVal) = (((regVal) & (~(fieldMask))) | (((fieldVal) << (fieldShift)) && (fieldMask))) }
* 獲取寄存器字段的值
#define SIGMA_GET_REGSITER_FIELD( regVal, fieldMask, fieldShift )  \
        { ((regVal) & (fieldMask)) >> (fieldShift) }
  將浮點值轉(zhuǎn)換為SigmaDSP(5.23)定點格式,此可選宏用于具有特殊實現(xiàn)的系統(tǒng)
#define SIGMASTUDIOTYPE_FIXPOINT_CONVERT( _value ) {/*TODO: IMPLEMENT MACRO*/}
* Convert integer data to system compatible format
*    This optional macro is intended for systems having special implementation
*    requirements (for example: limited memory size or endianness)
#define SIGMASTUDIOTYPE_INTEGER_CONVERT( _value ) {/*TODO: IMPLEMENT MACRO*/}
#define ADAU1701_GPIO_PORT_I2C      GPIOB                          /* GPIO端口 */
#define ADAU1701_RCC_I2C_PORT       RCC_APB2Periph_GPIOB        /* GPIO端口時鐘 */
#define ADAU1701_I2C_SCL_PIN          GPIO_Pin_10            /* 連接到SCL時鐘線的GPIO */
#define ADAU1701_I2C_SDA_PIN          GPIO_Pin_11            /* 連接到SDA數(shù)據(jù)線的GPIO */
#define ADAU1701_I2C_SCL_1()  GPIO_SetBits(ADAU1701_GPIO_PORT_I2C, ADAU1701_I2C_SCL_PIN)          /* SCL = 1 */
#define ADAU1701_I2C_SCL_0()  GPIO_ResetBits(ADAU1701_GPIO_PORT_I2C, ADAU1701_I2C_SCL_PIN)        /* SCL = 0 */
#define ADAU1701_I2C_SDA_1()  GPIO_SetBits(ADAU1701_GPIO_PORT_I2C, ADAU1701_I2C_SDA_PIN)          /* SDA = 1 */
#define ADAU1701_I2C_SDA_0()  GPIO_ResetBits(ADAU1701_GPIO_PORT_I2C, ADAU1701_I2C_SDA_PIN)        /* SDA = 0 */
#define ADAU1701_I2C_SDA_READ()  GPIO_ReadInputDataBit(ADAU1701_GPIO_PORT_I2C, ADAU1701_I2C_SDA_PIN)    /* 讀SDA口線狀態(tài) */
void i2c_CfgGpio(void);                   //I2C 引腳配置
void i2c_Start(void);                     //開始信號
void i2c_Stop(void);                      //結(jié)束信號
void i2c_SendByte(uint8_t _ucByte);       //發(fā)送一個字節(jié)
uint8_t i2c_ReadByte(void);               //接收一個字節(jié)
uint8_t i2c_WaitAck(void);                //等待應(yīng)答
void i2c_Ack(void);                       //應(yīng)答
void i2c_NAck(void);                      //非應(yīng)答
uint8_t i2c_CheckDevice(uint8_t _Address);//檢查設(shè)備地址是否存在
void SIGMA_WRITE_REGISTER_BLOCK(int devAddress, int address, int length, const ADI_REG_TYPE *pData ) ;  // 向寄存器寫一塊數(shù)據(jù)
void SIGMA_SAFELOAD_WRITE_REGISTER(int devAddress, int address, int length, const ADI_REG_TYPE *pData ) ;
void MASTER_MUTE_download(void);   // 靜音
void MASTER_UNMUTE_download(void); // 取消靜音
// 調(diào)節(jié)bass
void BASS0_download(void);   // 調(diào) bass 為 0
void BASS1_download(void);   // 調(diào) bass 為 +1
void BASS2_download(void);   // 調(diào) bass 為 +2
void BASS3_download(void);   // 調(diào) bass 為 +3
void BASS4_download(void);   // 調(diào) bass 為 +4
void BASS5_download(void);   // 調(diào) bass 為 +5
void BASS6_download(void);   // 調(diào) bass 為 +6
void BASS7_download(void);   // 調(diào) bass 為 +7
void BASS8_download(void);   // 調(diào) bass 為 +8
void BASS9_download(void);   // 調(diào) bass 為 +9
void BASS10_download(void);  // 調(diào) bass 為 +10
void BASS_1_download(void);  // 調(diào) bass 為 -1
void BASS_2_download(void);  // 調(diào) bass 為 -2
void BASS_3_download(void);  // 調(diào) bass 為 -3
void BASS_4_download(void);  // 調(diào) bass 為 -4
void BASS_5_download(void);  // 調(diào) bass 為 -5
void BASS_6_download(void);  // 調(diào) bass 為 -6
void BASS_7_download(void);  // 調(diào) bass 為 -7
void BASS_8_download(void);  // 調(diào) bass 為 -8
void BASS_9_download(void);  // 調(diào) bass 為 -9
void BASS_10_download(void); // 調(diào) bass 為 -10
// 調(diào)節(jié)Treble
void TRE0_download(void);    // 調(diào) Treble 為 0
void TRE1_download(void);    // 調(diào) Treble 為 +1
void TRE2_download(void);    // 調(diào) Treble 為 +2
void TRE3_download(void);    // 調(diào) Treble 為 +3
void TRE4_download(void);    // 調(diào) Treble 為 +4
void TRE5_download(void);    // 調(diào) Treble 為 +5
void TRE6_download(void);    // 調(diào) Treble 為 +6
void TRE7_download(void);    // 調(diào) Treble 為 +7
void TRE8_download(void);    // 調(diào) Treble 為 +8
void TRE9_download(void);    // 調(diào) Treble 為 +9
void TRE10_download(void);   // 調(diào) Treble 為 +10
void TRE_1_download(void);   // 調(diào) Treble 為 -1
void TRE_2_download(void);   // 調(diào) Treble 為 -2
void TRE_3_download(void);   // 調(diào) Treble 為 -3
void TRE_4_download(void);   // 調(diào) Treble 為 -4
void TRE_5_download(void);   // 調(diào) Treble 為 -5
void TRE_6_download(void);   // 調(diào) Treble 為 -6
void TRE_7_download(void);   // 調(diào) Treble 為 -7
void TRE_8_download(void);   // 調(diào) Treble 為 -8
void TRE_9_download(void);   // 調(diào) Treble 為 -9
void TRE_10_download(void);  // 調(diào) Treble 為 -10
#endif
#include "adau1701.h"
*    函 數(shù) 名: i2c_CfgGpio
*    功能說明: 配置I2C總線的GPIO,采用模擬IO的方式實現(xiàn)
*    形    參:無
*    返 回 值: 無
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(ADAU1701_RCC_I2C_PORT, ENABLE);    /* 打開GPIO時鐘 */
        GPIO_InitStructure.GPIO_Pin = ADAU1701_I2C_SCL_PIN | ADAU1701_I2C_SDA_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;        /* 開漏輸出 */
        GPIO_Init(ADAU1701_GPIO_PORT_I2C, &GPIO_InitStructure);
        /* 給一個停止信號, 復(fù)位I2C總線上的所有設(shè)備到待機模式 */
        i2c_Stop();
static void i2c_Delay(void)  // i2c 延時
        uint8_t i;
         下面的時間是通過邏輯分析儀測試得到的。
    工作條件:CPU主頻72MHz ,MDK編譯環(huán)境,1級優(yōu)化
        循環(huán)次數(shù)為10時,SCL頻率 = 205KHz
        循環(huán)次數(shù)為7時,SCL頻率 = 347KHz, SCL高電平時間1.5us,SCL低電平時間2.87us
         循環(huán)次數(shù)為5時,SCL頻率 = 421KHz, SCL高電平時間1.25us,SCL低電平時間2.375us
        for (i = 0; i < 10; i++);
*    函 數(shù) 名: i2c_Start
*    功能說明: CPU發(fā)起I2C總線啟動信號
*    形    參:無
*    返 回 值: 無
    /* 當(dāng)SCL高電平時,SDA出現(xiàn)一個下跳沿表示I2C總線啟動信號 */
    ADAU1701_I2C_SDA_1();
    ADAU1701_I2C_SCL_1();
    i2c_Delay();
    ADAU1701_I2C_SDA_0();
    i2c_Delay();
    ADAU1701_I2C_SCL_0(); // 牽住時鐘線,準(zhǔn)備發(fā)送數(shù)據(jù)
    i2c_Delay();
*    功能說明: CPU發(fā)起I2C總線停止信號
*    形    參:無
*    返 回 值: 無
void i2c_Stop(void)
    /* 當(dāng)SCL高電平時,SDA出現(xiàn)一個上跳沿表示I2C總線停止信號 */
    i2c_Delay();
*    函 數(shù) 名: i2c_WaitAck
*    功能說明: CPU產(chǎn)生一個時鐘,并讀取器件的ACK應(yīng)答信號
*    形    參:無
*    返 回 值: 返回0表示正確應(yīng)答,1表示無器件響應(yīng)
    uint8_t re;
    ADAU1701_I2C_SDA_1();    /* CPU釋放SDA總線 */
    i2c_Delay();
    ADAU1701_I2C_SCL_1();    /* CPU驅(qū)動SCL = 1, 此時器件會返回ACK應(yīng)答 */
    i2c_Delay();
    if (ADAU1701_I2C_SDA_READ())    /* CPU讀取SDA口線狀態(tài) */
        re = 1;
        re = 0;
    i2c_Delay();
    return re;
*    函 數(shù) 名: i2c_Ack
*    功能說明: CPU產(chǎn)生一個ACK信號
*    形    參:無
*    返 回 值: 無
void i2c_Ack(void)
    ADAU1701_I2C_SDA_0();    /* CPU驅(qū)動SDA = 0 */
    i2c_Delay();
    ADAU1701_I2C_SCL_1();    /* CPU產(chǎn)生1個時鐘 */
    i2c_Delay();
    i2c_Delay();
*    函 數(shù) 名: i2c_NAck
*    功能說明: CPU產(chǎn)生1個NACK信號
*    形    參:無
*    返 回 值: 無
void i2c_NAck(void)
    ADAU1701_I2C_SDA_1();    /* CPU驅(qū)動SDA = 1 */
    i2c_Delay();
    i2c_Delay();
    i2c_Delay();
*    函 數(shù) 名: i2c_SendByte
*    功能說明: CPU向I2C總線設(shè)備發(fā)送8bit數(shù)據(jù)
*    形    參:_ucByte : 等待發(fā)送的字節(jié)
*    返 回 值: 無
    uint8_t i;
    /* 先發(fā)送字節(jié)的高位bit7 */
    for (i = 0; i < 8; i++)
        if (_ucByte & 0x80)
        i2c_Delay();
        i2c_Delay();
        if (i == 7)
             ADAU1701_I2C_SDA_1(); // 釋放總線
        _ucByte <<= 1;    /* 左移一個bit */
        i2c_Delay();
*    函 數(shù) 名: i2c_ReadByte
*    功能說明: CPU從I2C總線設(shè)備讀取8bit數(shù)據(jù)
*    形    參:無
*    返 回 值: 讀到的數(shù)據(jù)
    uint8_t i;
    uint8_t value;
    /* 讀到第1個bit為數(shù)據(jù)的bit7 */
    value = 0;
        value <<= 1;
        i2c_Delay();
            value++;
        i2c_Delay();
    return value;
*    函 數(shù) 名: i2c_CheckDevice
*    功能說明: 檢測I2C總線設(shè)備,CPU向發(fā)送設(shè)備地址,然后讀取設(shè)備應(yīng)答來判斷該設(shè)備是否存在
*    形    參:_Address:設(shè)備的I2C總線地址
*    返 回 值: 返回值 0 表示正確, 返回1表示未探測到
    uint8_t ucAck;
    i2c_CfgGpio();        /* 配置GPIO */
    i2c_Start();        /* 發(fā)送啟動信號 */
    /* 發(fā)送設(shè)備地址+讀寫控制bit(0 = w, 1 = r) bit7 先傳 */
    i2c_SendByte(_Address | ADAU1701_I2C_WR);
    ucAck = i2c_WaitAck();    /* 檢測設(shè)備的ACK應(yīng)答 */
    i2c_Stop();            /* 發(fā)送停止信號 */
    return ucAck;
        uint8_t subaddress0;
        uint8_t subaddress1;
        uint16_t i;
        subaddress0 = (address & 0xFF00)>>8;
        subaddress1 = address & 0x00FF;
        i2c_Start();
        i2c_SendByte(devAddress);    // 設(shè)備地址
        i2c_WaitAck();               // 等待應(yīng)答
        i2c_SendByte(subaddress0);   // 寄存器高位地址
        i2c_SendByte(subaddress1);   // 寄存器地位地址
        for(i=0;i<length;i++)
            i2c_SendByte(pData[i]);   // 發(fā)送數(shù)據(jù)
        i2c_Stop();
*        ADAU1701 Sigmastudio Safeload
*        step 1. write target address to safeload address register, address start with 0x0815.
*        step 2. write target data to safeload data register, address start with 0x0810.
*        step 3. set bit IST in DSP CORE control register, address 0x081c, to inital safeload transmitter.
//    uint16_t i=0;
    static uint16_t f = 0;        //set flag for triggering safeload transmite, after finished load 5 safeload data register.
        // write target data to 0x0810
        i2c_Start();
        i2c_SendByte(0x08);
        i2c_SendByte(0x10+f);
        //number of prarameter need to loading, length need offset -2? deal with while length >5?
        i2c_SendByte(0x00);
        i2c_SendByte(pData[0]);
        i2c_SendByte(pData[1]);
        i2c_SendByte(pData[2]);
        i2c_SendByte(pData[3]);
        i2c_Stop();
        // write     target address to safeload address register start with 0x0815
        i2c_Start();
        i2c_SendByte(0x08);
        i2c_SendByte(0x15+f);
      i2c_Stop();
// trigger safeload transmitter.
    f++;
    if(f == 5)
        uint8_t recv0;
        uint8_t recv1;
        f = 0;
        i2c_Start();
        i2c_SendByte(0x08);
        i2c_SendByte(0x1C);
      i2c_Start();
        i2c_SendByte(devAddress+1);
        recv0 = i2c_ReadByte();
        i2c_Ack();
        recv1 = i2c_ReadByte();
        i2c_Stop();                        // read data from DSP CORE control register.
        recv1 = recv1 | 0x20    ;    // set bit IST to trigger safeload.
        i2c_Start();                        // send data to DSP CORE control register.
        i2c_SendByte(0x08);
        i2c_SendByte(0x1c);
        i2c_SendByte(recv0);
        i2c_SendByte(recv1);
        i2c_Stop();
//靜音
ADI_REG_TYPE MASTER_MUTE_0[4] = {0x00, 0x00, 0x00, 0x00};
void MASTER_MUTE_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x003D, 4, MASTER_MUTE_0);            /* MuteNoSlewAlg1mute */
//取消靜音
ADI_REG_TYPE MASTER_UNMUTE_0[4] = {0x00, 0x80, 0x00, 0x00};
void MASTER_UNMUTE_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x003D, 4, MASTER_UNMUTE_0);            /* MuteNoSlewAlg1mute */
/*****************************************音量調(diào)節(jié)**********************************************/
// 調(diào) bass 為 0
ADI_REG_TYPE BASS0_0[4] = {0xFF, 0xBB, 0x10, 0x41};
ADI_REG_TYPE BASS0_1[4] = {0x00, 0x35, 0xFF, 0xDB};
ADI_REG_TYPE BASS0_2[4] = {0x00, 0x10, 0x0D, 0xE0};
ADI_REG_TYPE BASS0_3[4] = {0x00, 0xA8, 0x6F, 0xB3};
ADI_REG_TYPE BASS0_4[4] = {0xFF, 0xD6, 0x72, 0x52};
void BASS0_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS0_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS0_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS0_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS0_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS0_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS1_0[4] = {0xFF, 0xBB, 0x10, 0x57};
ADI_REG_TYPE BASS1_1[4] = {0x00, 0x36, 0x0D, 0x40};
ADI_REG_TYPE BASS1_2[4] = {0x00, 0x10, 0x10, 0xF3};
ADI_REG_TYPE BASS1_3[4] = {0x00, 0xA8, 0x88, 0x0D};
ADI_REG_TYPE BASS1_4[4] = {0xFF, 0xD6, 0x6A, 0x4F};
void BASS1_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS1_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS1_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS1_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS1_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS1_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS2_0[4] = {0xFF, 0xBB, 0x10, 0x6D};
ADI_REG_TYPE BASS2_1[4] = {0x00, 0x36, 0x1A, 0x91};
ADI_REG_TYPE BASS2_2[4] = {0x00, 0x10, 0x14, 0x01};
ADI_REG_TYPE BASS2_3[4] = {0x00, 0xA8, 0xA0, 0x43};
ADI_REG_TYPE BASS2_4[4] = {0xFF, 0xD6, 0x62, 0x59};
void BASS2_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS2_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS2_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS2_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS2_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS2_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS3_0[4] = {0xFF, 0xBB, 0x10, 0x83};
ADI_REG_TYPE BASS3_1[4] = {0x00, 0x36, 0x27, 0xB9};
ADI_REG_TYPE BASS3_2[4] = {0x00, 0x10, 0x17, 0x06};
ADI_REG_TYPE BASS3_3[4] = {0x00, 0xA8, 0xB8, 0x2D};
ADI_REG_TYPE BASS3_4[4] = {0xFF, 0xD6, 0x5A, 0x7B};
void BASS3_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS3_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS3_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS3_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS3_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS3_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS4_0[4] = {0xFF, 0xBB, 0x10, 0x99};
ADI_REG_TYPE BASS4_1[4] = {0x00, 0x36, 0x34, 0xA1};
ADI_REG_TYPE BASS4_2[4] = {0x00, 0x10, 0x19, 0xFC};
ADI_REG_TYPE BASS4_3[4] = {0x00, 0xA8, 0xCF, 0xA3};
ADI_REG_TYPE BASS4_4[4] = {0xFF, 0xD6, 0x52, 0xC4};
void BASS4_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS4_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS4_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS4_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS4_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS4_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS5_0[4] = {0xFF, 0x81, 0xAA, 0xED};
ADI_REG_TYPE BASS5_1[4] = {0x00, 0x91, 0x19, 0x61};
ADI_REG_TYPE BASS5_2[4] = {0xFF, 0xEF, 0x16, 0x44};
ADI_REG_TYPE BASS5_3[4] = {0x00, 0x8F, 0xA6, 0xA8};
ADI_REG_TYPE BASS5_4[4] = {0xFF, 0xEF, 0x4E, 0x79};
void BASS5_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS5_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS5_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS5_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS5_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS5_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS6_0[4] = {0xFF, 0xBB, 0x10, 0xC2};
ADI_REG_TYPE BASS6_1[4] = {0x00, 0x36, 0x4D, 0x67};
ADI_REG_TYPE BASS6_2[4] = {0x00, 0x10, 0x1F, 0xAC};
ADI_REG_TYPE BASS6_3[4] = {0x00, 0xA8, 0xFC, 0xAE};
ADI_REG_TYPE BASS6_4[4] = {0xFF, 0xD6, 0x43, 0xF3};
void  BASS6_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS6_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS6_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS6_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS6_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS6_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS7_0[4] = {0xFF, 0xBB, 0x10, 0xD5};
ADI_REG_TYPE BASS7_1[4] = {0x00, 0x36, 0x59, 0x26};
ADI_REG_TYPE BASS7_2[4] = {0x00, 0x10, 0x22, 0x5E};
ADI_REG_TYPE BASS7_3[4] = {0x00, 0xA9, 0x12, 0x08};
ADI_REG_TYPE BASS7_4[4] = {0xFF, 0xD6, 0x3C, 0xED};
void  BASS7_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS7_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS7_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS7_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS7_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS7_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS8_0[4] = {0xFF, 0xBB, 0x10, 0xE8};
ADI_REG_TYPE BASS8_1[4] = {0x00, 0x36, 0x64, 0x65};
ADI_REG_TYPE BASS8_2[4] = {0x00, 0x10, 0x24, 0xF3};
ADI_REG_TYPE BASS8_3[4] = {0x00, 0xA9, 0x26, 0x7A};
ADI_REG_TYPE BASS8_4[4] = {0xFF, 0xD6, 0x36, 0x34};
void  BASS8_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS8_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS8_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS8_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS8_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS8_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS9_0[4] = {0xFF, 0xBB, 0x10, 0xFA};
ADI_REG_TYPE BASS9_1[4] = {0x00, 0x36, 0x6F, 0x1A};
ADI_REG_TYPE BASS9_2[4] = {0x00, 0x10, 0x27, 0x68};
ADI_REG_TYPE BASS9_3[4] = {0x00, 0xA9, 0x39, 0xF2};
ADI_REG_TYPE BASS9_4[4] = {0xFF, 0xD6, 0x2F, 0xCC};
void  BASS9_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS9_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS9_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS9_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS9_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS9_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS10_0[4] = {0xFF, 0xBB, 0x11, 0x0B};
ADI_REG_TYPE BASS10_1[4] = {0x00, 0x36, 0x79, 0x3F};
ADI_REG_TYPE BASS10_2[4] = {0x00, 0x10, 0x29, 0xBC};
ADI_REG_TYPE BASS10_3[4] = {0x00, 0xA9, 0x4C, 0x63};
ADI_REG_TYPE BASS10_4[4] = {0xFF, 0xD6, 0x29, 0xBC};
void  BASS10_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS10_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS10_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS10_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS10_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS10_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_1_0[4] = {0xFF, 0xBB, 0x10, 0x2B};
ADI_REG_TYPE BASS_1_1[4] = {0x00, 0x35, 0xF2, 0x78};
ADI_REG_TYPE BASS_1_2[4] = {0x00, 0x10, 0x0A, 0xCD};
ADI_REG_TYPE BASS_1_3[4] = {0x00, 0xA8, 0x57, 0x5D};
ADI_REG_TYPE BASS_1_4[4] = {0xFF, 0xD6, 0x7A, 0x53};
void BASS_1_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_1_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_1_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_1_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_1_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_1_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_2_0[4] = {0xFF, 0xBB, 0x10, 0x15};
ADI_REG_TYPE BASS_2_1[4] = {0x00, 0x35, 0xE5, 0x2E};
ADI_REG_TYPE BASS_2_2[4] = {0x00, 0x10, 0x07, 0xC1};
ADI_REG_TYPE BASS_2_3[4] = {0x00, 0xA8, 0x3F, 0x34};
ADI_REG_TYPE BASS_2_4[4] = {0xFF, 0xD6, 0x82, 0x45};
void BASS_2_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_2_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_2_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_2_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_2_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_2_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_3_0[4] = {0xFF, 0xBB, 0x0F, 0xFF};
ADI_REG_TYPE BASS_3_1[4] = {0x00, 0x35, 0xD8, 0x14};
ADI_REG_TYPE BASS_3_2[4] = {0x00, 0x10, 0x04, 0xBF};
ADI_REG_TYPE BASS_3_3[4] = {0x00, 0xA8, 0x27, 0x62};
ADI_REG_TYPE BASS_3_4[4] = {0xFF, 0xD6, 0x8A, 0x1B};
void BASS_3_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_3_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_3_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_3_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_3_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_3_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_4_0[4] = {0xFF, 0xBB, 0x0F, 0xEA};
ADI_REG_TYPE BASS_4_1[4] = {0x00, 0x35, 0xCB, 0x3D};
ADI_REG_TYPE BASS_4_2[4] = {0x00, 0x10, 0x01, 0xCC};
ADI_REG_TYPE BASS_4_3[4] = {0x00, 0xA8, 0x10, 0x0A};
ADI_REG_TYPE BASS_4_4[4] = {0xFF, 0xD6, 0x91, 0xC9};
void BASS_4_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_4_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_4_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_4_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_4_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_4_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_5_0[4] = {0xFF, 0xBB, 0x0F, 0xD5};
ADI_REG_TYPE BASS_5_1[4] = {0x00, 0x35, 0xBE, 0xBD};
ADI_REG_TYPE BASS_5_2[4] = {0x00, 0x0F, 0xFE, 0xEE};
ADI_REG_TYPE BASS_5_3[4] = {0x00, 0xA7, 0xF9, 0x50};
ADI_REG_TYPE BASS_5_4[4] = {0xFF, 0xD6, 0x99, 0x42};
void BASS_5_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_5_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_5_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_5_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_5_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_5_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_6_0[4] = {0xFF, 0xBB, 0x0F, 0xC1};
ADI_REG_TYPE BASS_6_1[4] = {0x00, 0x35, 0xB2, 0xA4};
ADI_REG_TYPE BASS_6_2[4] = {0x00, 0x0F, 0xFC, 0x27};
ADI_REG_TYPE BASS_6_3[4] = {0x00, 0xA7, 0xE3, 0x52};
ADI_REG_TYPE BASS_6_4[4] = {0xFF, 0xD6, 0xA0, 0x7E};
void BASS_6_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_6_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_6_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_6_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_6_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_6_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_7_0[4] = {0xFF, 0xBB, 0x0F, 0xAD};
ADI_REG_TYPE BASS_7_1[4] = {0x00, 0x35, 0xA7, 0x01};
ADI_REG_TYPE BASS_7_2[4] = {0x00, 0x0F, 0xF9, 0x7B};
ADI_REG_TYPE BASS_7_3[4] = {0x00, 0xA7, 0xCE, 0x2B};
ADI_REG_TYPE BASS_7_4[4] = {0xFF, 0xD6, 0xA7, 0x73};
void BASS_7_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_7_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_7_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_7_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_7_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_7_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_8_0[4] = {0xFF, 0xBB, 0x0F, 0x9B};
ADI_REG_TYPE BASS_8_1[4] = {0x00, 0x35, 0x9B, 0xE1};
ADI_REG_TYPE BASS_8_2[4] = {0x00, 0x0F, 0xF6, 0xEE};
ADI_REG_TYPE BASS_8_3[4] = {0x00, 0xA7, 0xB9, 0xF1};
ADI_REG_TYPE BASS_8_4[4] = {0xFF, 0xD6, 0xAE, 0x1A};
void BASS_8_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_8_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_8_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_8_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_8_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_8_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_9_0[4] = {0xFF, 0xBB, 0x0F, 0x89};
ADI_REG_TYPE BASS_9_1[4] = {0x00, 0x35, 0x91, 0x4B};
ADI_REG_TYPE BASS_9_2[4] = {0x00, 0x0F, 0xF4, 0x80};
ADI_REG_TYPE BASS_9_3[4] = {0x00, 0xA7, 0xA6, 0xB3};
ADI_REG_TYPE BASS_9_4[4] = {0xFF, 0xD6, 0xB4, 0x6E};
void BASS_9_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_9_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_9_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_9_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_9_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_9_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE BASS_10_0[4] = {0xFF, 0xBB, 0x0F, 0x79};
ADI_REG_TYPE BASS_10_1[4] = {0x00, 0x35, 0x87, 0x48};
ADI_REG_TYPE BASS_10_2[4] = {0x00, 0x0F, 0xF2, 0x33};
ADI_REG_TYPE BASS_10_3[4] = {0x00, 0xA7, 0x94, 0x7F};
ADI_REG_TYPE BASS_10_4[4] = {0xFF, 0xD6, 0xBA, 0x6B};
void BASS_10_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, BASS_10_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, BASS_10_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, BASS_10_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, BASS_10_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, BASS_10_4);            /* EQ1940Dual12A1 */
/*****************************************調(diào)節(jié)Treble**********************************************/
ADI_REG_TYPE TRE0_0[4] = {0xFF, 0x81, 0xAA, 0x26};
ADI_REG_TYPE TRE0_1[4] = {0x00, 0x90, 0xA1, 0xE3};
ADI_REG_TYPE TRE0_2[4] = {0xFF, 0xEF, 0x26, 0x03};
ADI_REG_TYPE TRE0_3[4] = {0x00, 0x8F, 0x2F, 0xD7};
ADI_REG_TYPE TRE0_4[4] = {0xFF, 0xEF, 0x5E, 0x1D};
void TRE0_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE0_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE0_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE0_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE0_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE0_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 1
ADI_REG_TYPE TRE1_0[4] = {0xFF, 0x79, 0x2A, 0xD9};
ADI_REG_TYPE TRE1_1[4] = {0x00, 0x9E, 0x0C, 0xB1};
ADI_REG_TYPE TRE1_2[4] = {0xFF, 0xEA, 0x46, 0xF3};
ADI_REG_TYPE TRE1_3[4] = {0x00, 0x8B, 0x72, 0xF0};
ADI_REG_TYPE TRE1_4[4] = {0xFF, 0xF3, 0x0E, 0x93};
void TRE1_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE1_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE1_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE1_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE1_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE1_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 2
ADI_REG_TYPE TRE2_0[4] = {0xFF, 0x70, 0x24, 0x03};
ADI_REG_TYPE TRE2_1[4] = {0x00, 0xAC, 0x4D, 0x82};
ADI_REG_TYPE TRE2_2[4] = {0xFF, 0xE5, 0x1A, 0x31};
ADI_REG_TYPE TRE2_3[4] = {0x00, 0x87, 0x7A, 0x69};
ADI_REG_TYPE TRE2_4[4] = {0xFF, 0xF6, 0xF9, 0xE1};
void TRE2_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE2_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE2_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE2_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE2_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE2_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 3
ADI_REG_TYPE TRE3_0[4] = {0xFF, 0x66, 0x99, 0x4A};
ADI_REG_TYPE TRE3_1[4] = {0x00, 0xBB, 0x5E, 0x92};
ADI_REG_TYPE TRE3_2[4] = {0xFF, 0xDF, 0xA1, 0xD3};
ADI_REG_TYPE TRE3_3[4] = {0x00, 0x83, 0x47, 0xDF};
ADI_REG_TYPE TRE3_4[4] = {0xFF, 0xFB, 0x1E, 0x71};
void TRE3_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE3_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE3_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE3_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE3_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE3_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 4
ADI_REG_TYPE TRE4_0[4] = {0xFF, 0x5C, 0x90, 0x9C};
ADI_REG_TYPE TRE4_1[4] = {0x00, 0xCB, 0x36, 0x87};
ADI_REG_TYPE TRE4_2[4] = {0xFF, 0xD9, 0xE1, 0x3E};
ADI_REG_TYPE TRE4_3[4] = {0x00, 0x7E, 0xDD, 0xEC};
ADI_REG_TYPE TRE4_4[4] = {0xFF, 0xFF, 0x79, 0xB3};
void TRE4_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE4_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE4_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE4_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE4_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE4_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 5
ADI_REG_TYPE TRE5_0[4] = {0xFF, 0x52, 0x12, 0x42};
ADI_REG_TYPE TRE5_1[4] = {0x00, 0xDB, 0xC8, 0x48};
ADI_REG_TYPE TRE5_2[4] = {0xFF, 0xD3, 0xDD, 0x35};
ADI_REG_TYPE TRE5_3[4] = {0x00, 0x7A, 0x40, 0x36};
ADI_REG_TYPE TRE5_4[4] = {0x00, 0x04, 0x08, 0x0A};
void TRE5_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE5_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE5_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE5_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE5_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE5_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 6
ADI_REG_TYPE TRE6_0[4] = {0xFF, 0x47, 0x28, 0xEF};
ADI_REG_TYPE TRE6_1[4] = {0x00, 0xED, 0x02, 0xF3};
ADI_REG_TYPE TRE6_2[4] = {0xFF, 0xCD, 0x9B, 0xD8};
ADI_REG_TYPE TRE6_3[4] = {0x00, 0x75, 0x73, 0x72};
ADI_REG_TYPE TRE6_4[4] = {0x00, 0x08, 0xC4, 0xD4};
void TRE6_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE6_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE6_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE6_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE6_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE6_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 7
ADI_REG_TYPE TRE7_0[4] = {0xFF, 0x3B, 0xE1, 0xA8};
ADI_REG_TYPE TRE7_1[4] = {0x00, 0xFE, 0xD1, 0xF7};
ADI_REG_TYPE TRE7_2[4] = {0xFF, 0xC7, 0x24, 0xA0};
ADI_REG_TYPE TRE7_3[4] = {0x00, 0x70, 0x7D, 0x59};
ADI_REG_TYPE TRE7_4[4] = {0x00, 0x0D, 0xAA, 0x68};
void TRE7_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE7_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE7_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE7_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE7_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE7_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 8
ADI_REG_TYPE TRE8_0[4] = {0xFF, 0x30, 0x4B, 0xA0};
ADI_REG_TYPE TRE8_1[4] = {0x01, 0x11, 0x1D, 0x56};
ADI_REG_TYPE TRE8_2[4] = {0xFF, 0xC0, 0x80, 0x40};
ADI_REG_TYPE TRE8_3[4] = {0x00, 0x6B, 0x64, 0x9B};
ADI_REG_TYPE TRE8_4[4] = {0x00, 0x12, 0xB2, 0x2E};
void TRE8_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE8_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE8_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE8_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE8_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE8_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 9
ADI_REG_TYPE TRE9_0[4] = {0xFF, 0x24, 0x77, 0xF0};
ADI_REG_TYPE TRE9_1[4] = {0x01, 0x23, 0xCA, 0x10};
ADI_REG_TYPE TRE9_2[4] = {0xFF, 0xB9, 0xB8, 0x89};
ADI_REG_TYPE TRE9_3[4] = {0x00, 0x66, 0x30, 0xBE};
ADI_REG_TYPE TRE9_4[4] = {0x00, 0x17, 0xD4, 0xB9};
void TRE9_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE9_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE9_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE9_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE9_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE9_4);            /* EQ1940Dual12A1 */
// 調(diào) Treble 為 10
ADI_REG_TYPE TRE10_0[4] = {0xFF, 0x18, 0x79, 0x3D};
ADI_REG_TYPE TRE10_1[4] = {0x01, 0x36, 0xBA, 0xB4};
ADI_REG_TYPE TRE10_2[4] = {0xFF, 0xB2, 0xD8, 0x28};
ADI_REG_TYPE TRE10_3[4] = {0x00, 0x60, 0xE9, 0xF5};
ADI_REG_TYPE TRE10_4[4] = {0x00, 0x1D, 0x09, 0xF1};
void TRE10_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE10_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE10_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE10_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE10_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE10_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_1_0[4] = {0xFF, 0x89, 0xA0, 0x5C};
ADI_REG_TYPE TRE_1_1[4] = {0x00, 0x84, 0x0F, 0x8B};
ADI_REG_TYPE TRE_1_2[4] = {0xFF, 0xF3, 0xB6, 0x7B};
ADI_REG_TYPE TRE_1_3[4] = {0x00, 0x92, 0xB0, 0x70};
ADI_REG_TYPE TRE_1_4[4] = {0xFF, 0xEB, 0xE9, 0x2D};
void TRE_1_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_1_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_1_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_1_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_1_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_1_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_2_0[4] = {0xFF, 0x91, 0x0D, 0xD1};
ADI_REG_TYPE TRE_2_1[4] = {0x00, 0x78, 0x55, 0x24};
ADI_REG_TYPE TRE_2_2[4] = {0xFF, 0xF7, 0xF8, 0x8D};
ADI_REG_TYPE TRE_2_3[4] = {0x00, 0x95, 0xF4, 0xE1};
ADI_REG_TYPE TRE_2_4[4] = {0xFF, 0xE8, 0xAF, 0x9D};
void TRE_2_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_2_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_2_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_2_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_2_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_2_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_3_0[4] = {0xFF, 0x97, 0xF4, 0x7E};
ADI_REG_TYPE TRE_3_1[4] = {0x00, 0x6D, 0x6F, 0x8E};
ADI_REG_TYPE TRE_3_2[4] = {0xFF, 0xFB, 0xED, 0x5A};
ADI_REG_TYPE TRE_3_3[4] = {0x00, 0x98, 0xFE, 0x07};
ADI_REG_TYPE TRE_3_4[4] = {0xFF, 0xE5, 0xB0, 0x92};
void TRE_3_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_3_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_3_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_3_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_3_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_3_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_4_0[4] = {0xFF, 0x9E, 0x57, 0xC0};
ADI_REG_TYPE TRE_4_1[4] = {0x00, 0x63, 0x59, 0x7B};
ADI_REG_TYPE TRE_4_2[4] = {0xFF, 0xFF, 0x96, 0xD1};
ADI_REG_TYPE TRE_4_3[4] = {0x00, 0x9B, 0xCD, 0x5F};
ADI_REG_TYPE TRE_4_4[4] = {0xFF, 0xE2, 0xEA, 0x96};
void TRE_4_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_4_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_4_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_4_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_4_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_4_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_5_0[4] = {0xFF, 0xA4, 0x3C, 0x14};
ADI_REG_TYPE TRE_5_1[4] = {0x00, 0x5A, 0x0B, 0xD4};
ADI_REG_TYPE TRE_5_2[4] = {0x00, 0x02, 0xF7, 0x83};
ADI_REG_TYPE TRE_5_3[4] = {0x00, 0x9E, 0x64, 0xE0};
ADI_REG_TYPE TRE_5_4[4] = {0xFF, 0xE0, 0x5B, 0xB5};
void TRE_5_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_5_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_5_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_5_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_5_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_5_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_6_0[4] = {0xFF, 0xAE, 0x9E, 0x12};
ADI_REG_TYPE TRE_6_1[4] = {0x00, 0x49, 0xA6, 0xD8};
ADI_REG_TYPE TRE_6_2[4] = {0x00, 0x08, 0xEB, 0x4B};
ADI_REG_TYPE TRE_6_3[4] = {0x00, 0xA2, 0xF6, 0x1D};
ADI_REG_TYPE TRE_6_4[4] = {0xFF, 0xDB, 0xD9, 0xAD};
void TRE_6_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_6_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_6_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_6_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_6_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_6_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_7_0[4] = {0xFF, 0xA9, 0xA6, 0xD8};
ADI_REG_TYPE TRE_7_1[4] = {0x00, 0x51, 0x7E, 0x1E};
ADI_REG_TYPE TRE_7_2[4] = {0x00, 0x06, 0x12, 0x86};
ADI_REG_TYPE TRE_7_3[4] = {0x00, 0xA0, 0xC6, 0xE8};
ADI_REG_TYPE TRE_7_4[4] = {0xFF, 0xDE, 0x01, 0x9C};
void TRE_7_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_7_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_7_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_7_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_7_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_7_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_8_0[4] = {0xFF, 0xB3, 0x28, 0x38};
ADI_REG_TYPE TRE_8_1[4] = {0x00, 0x42, 0x7B, 0xD0};
ADI_REG_TYPE TRE_8_2[4] = {0x00, 0x0B, 0x85, 0x88};
ADI_REG_TYPE TRE_8_3[4] = {0x00, 0xA4, 0xF5, 0x56};
ADI_REG_TYPE TRE_8_4[4] = {0xFF, 0xD9, 0xE1, 0x1A};
void TRE_8_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_8_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_8_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_8_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_8_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_8_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_9_0[4] = {0xFF, 0xB7, 0x4C, 0x01};
ADI_REG_TYPE TRE_9_1[4] = {0x00, 0x3B, 0xF2, 0x69};
ADI_REG_TYPE TRE_9_2[4] = {0x00, 0x0D, 0xE5, 0x16};
ADI_REG_TYPE TRE_9_3[4] = {0x00, 0xA6, 0xC7, 0x87};
ADI_REG_TYPE TRE_9_4[4] = {0xFF, 0xD8, 0x14, 0xF9};
void TRE_9_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_9_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_9_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_9_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_9_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_9_4);            /* EQ1940Dual12A1 */
ADI_REG_TYPE TRE_10_0[4] = {0xFF, 0xBB, 0x10, 0x41};
ADI_REG_TYPE TRE_10_1[4] = {0x00, 0x35, 0xFF, 0xDB};
ADI_REG_TYPE TRE_10_2[4] = {0x00, 0x10, 0x0D, 0xE0};
ADI_REG_TYPE TRE_10_3[4] = {0x00, 0xA8, 0x6F, 0xB3};
ADI_REG_TYPE TRE_10_4[4] = {0xFF, 0xD6, 0x72, 0x52};
void TRE_10_download(void){
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0005, 4, TRE_10_0);            /* EQ1940Dual10B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0006, 4, TRE_10_1);            /* EQ1940Dual11B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0007, 4, TRE_10_2);            /* EQ1940Dual12B1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0008, 4, TRE_10_3);            /* EQ1940Dual11A1 */
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_, 0x0009, 4, TRE_10_4);            /* EQ1940Dual12A1 */
收藏收藏2 分享淘帖 頂 踩
ID:89217 發(fā)表于 2020-2-27 13:11 | 只看該作者
多做幾個宏命令多舒服,你這寫的太累了
ID:3706 發(fā)表于 2020-3-2 17:33 | 只看該作者
樓主可以提供這個程序的下載嗎?
