本設(shè)計為煙霧報警器附帶的有溫度和日期的顯示。需要的拿走。
#include<reg51.h>
#include<intrins.h>
#include"riqi.h"
#include"wendu.h"
#include"n5110.h"
sbit K1=P3^4;
sbit K2=P3^5;
sbit K3=P3^3;
sbit K4=P3^6;
uchar count=0x00;
sbit cs=P1^0;
sbit sclk=P1^1;
sbit dat=P1^2;
sbit fe=P1^3;
sbit k5=P3^7;
sbit mada=P1^4;
uint mdat=0x00;
int tidai;
uchar SetState,SetPlace,m=1;
void Int0Configuration();
void LcdDisplay();
void display(uint temp);
uchar code riqishuzu[][16]={ //8*16 日期數(shù)字
0x00,0xF8,0x04,0x02,0x02,0x04,0xF8,0x00,0x00,0x03,0x04,0x08,0x08,0x04,0x03,0x00,//0
0x00,0x04,0x04,0xFE,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x0F,0x08,0x08,0x00,0x00,//1
0x00,0x1C,0x02,0x02,0x82,0x62,0x1C,0x00,0x00,0x0C,0x0A,0x09,0x08,0x08,0x0C,0x00,//2
0x00,0x0C,0x02,0x22,0x22,0x52,0x8C,0x00,0x00,0x06,0x08,0x08,0x08,0x04,0x03,0x00,//3
0x00,0xC0,0x30,0x08,0x04,0xFE,0x00,0x00,0x00,0x01,0x01,0x09,0x09,0x0F,0x09,0x00,//4
0x00,0x7E,0x42,0x22,0x22,0x42,0x82,0x00,0x00,0x06,0x08,0x08,0x08,0x04,0x03,0x00,//5
0x00,0xF8,0x44,0x22,0x22,0x46,0x80,0x00,0x00,0x03,0x04,0x08,0x08,0x04,0x03,0x00,//6
0x00,0x0E,0x02,0xC2,0x32,0x0E,0x02,0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x00,0x00,//7
0x00,0x1C,0xA2,0x42,0x42,0xA2,0x1C,0x00,0x00,0x07,0x08,0x08,0x08,0x08,0x07,0x00,//8
0x00,0x38,0x44,0x82,0x82,0x44,0xF8,0x00,0x00,0x00,0x0C,0x08,0x08,0x04,0x03,0x00,//9
unsigned char code font6_8[][6] =
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // sp 0
{ 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00 }, // , 1
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 }, // . 2 14
{ 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 }, // / 3 15
{ 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E }, // 0 4 16
{ 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 }, // 1 5 17
{ 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 }, // 2 6 18
{ 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 }, // 3 7 19
{ 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 }, // 4 8 20
{ 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 }, // 5 9 21
{ 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 }, // 6 10 22
{ 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 }, // 7 11 23
{ 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 }, // 8 12 24
{ 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E }, // 9 13 25
{ 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 }, // : 14 26
{ 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 }, // ( 15
{ 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 }, // ) 16
uchar code xingqishuzi[][12]={ // 供星期調(diào)用
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00, //1
0x00,0x20,0x20,0x24,0x24,0x24,0x24,0x24,0x24,0x20,0x20,0x00, //2
0x00,0x80,0x48,0x49,0x49,0x49,0x49,0x49,0x49,0x48,0x80,0x00, //3
0x00,0xff,0xa1,0x91,0x8f,0x81,0x81,0x9f,0x91,0x91,0xff,0x00, //4
0x00,0x80,0x81,0xc9,0xb9,0x8f,0x89,0x89,0xf9,0x81,0x80,0x00, //5
0x00,0x44,0x24,0x14,0x04,0x05,0x04,0x14,0x24,0x44,0x00,0x00, //6
0x00,0x00,0xff,0x89,0x89,0x89,0x89,0x89,0x89,0xff,0x00,0x00, //7
void delay(uchar x)
uint i,j;
for(j=x;j>0;j--)
for(i=110;i>0;i--);
void lcdwritechar(uchar c) //顯示英文字符
uchar line;
//數(shù)組的行號 c=34 ;
for(line=0;line<7;line++)
lcdwritebyte(font6_8[c][line],1);
void xingqi(uchar x,uchar y,uchar e )
uchar tqr;
lcdsetxy(x,y);
for(tqr=0;tqr<12;tqr++)
lcdwritebyte(xingqishuzi[e][tqr],1);
void riqi()
lcdsetxy(58,3); //溫度的小數(shù)點
lcdwritebyte(0x30,1);
lcdsetxy(59,3);
lcdsetxy(13,1); //:
lcdwritechar(14);
lcdsetxy(31,1); //:
lcdwritechar(14);
lcdsetxy(30,0); // /
lcdwritechar(3);
lcdsetxy(52,0); // /
lcdwritechar(3);
lcdsetxy(58,1); //( 61
lcdwritechar(15);
lcdsetxy(76,1); // ) 79
lcdwritechar(16);
void yingwenzifu(uchar x,uchar y,uchar h) //在x y 處顯示一個字符
lcdsetxy(x,y);
lcdwritechar(h);
void wendu_shuzi(uint x,uint y,int a) //日期上顯示占兩行的數(shù)字
uchar b,c;
lcdsetxy(x,y);
for(b=0;b<8;b++)
lcdwritebyte(riqishuzu[a][b],1);
lcdsetxy( x,y+1);
for(c=8;c<16;c++)
lcdwritebyte(riqishuzu[a][c],1);
void convdata(uchar i)//此時的i為ad轉(zhuǎn)換后的值,在0-5v之間,
uchar w=0;
// i=i*100; //把i精確到0.0;i在0-255之間,共5v,十個等級,每個等級0.5v,255/10=25.5取整25
if(i>=0&&i<=3) // if(i>=0&&i<=3)
{wendu_shuzi(60,4,0); // 檢測0-0.3v 5110顯示0級
fe=1;
mada=1;
if(k5==0&&m==1)
delay(10);
if(k5==0&&m==1)
w=1;
m=0;
while(!k5);
// tqr=0; //定時器開始計時,當(dāng)tmr=51 tmr=0;m=0;tqr=1 定時器不在計時
if(k5==0&&m==0)
delay(10);
if(k5==0&&m==0)
w=0;
m=1;
while(!k5);
if(i>3&&i<=225)
mada=0;
if(mada==0&&m==1)
fe=0;
if(mada==0&&m==0&&w==1)
fe=1;
if(i>3&&i<=25) // if(i>3&&i<=25)
{wendu_shuzi(60,4,1);} // 0.3-0.5v 1級
if(i>25&&i<=51)
{wendu_shuzi(60,4,2);} // 0.5-1v 2
if(i>51&&i<=76)
{wendu_shuzi(60,4,3);} // 1-1.5v 3
if(i>76&&i<=102)
{wendu_shuzi(60,4,4);} // 1.5-2v 4
if(i>76&&i<=127)
{wendu_shuzi(60,4,5);} // 2-2.5v 5
if(i>127&&i<=153)
{wendu_shuzi(60,4,6);} // 2.5-3v 6
if(i>153&&i<=178)
{wendu_shuzi(60,4,7);} // 3-3.5v 7
if(i>178&&i<=204)
{wendu_shuzi(60,4,8);} // 3.5-4v 8
if(i>204&&i<=229)
{wendu_shuzi(60,4,9);} // 4-4.5v 9
if(i>229&&i<=255)
wendu_shuzi(69,4,0);;
} // 4.5-5v 10
uchar adc0832(uchar CH) //(ucahr CH)
uchar i,test,adval;
adval=0x00;
test=0x00;
sclk=0;
dat=1; //why dat=1; dat should=0;
_nop_();
cs=0;
_nop_();
sclk=1;
_nop_();
if ( CH == 0x00 ) //通道選擇
sclk = 0;
dat = 1; //通道0的第一位
_nop_();
sclk = 1;
_nop_();
sclk = 0;
dat = 0; //通道0的第二位
_nop_();
sclk = 1;
_nop_();
sclk = 0;
dat = 1; //通道1的第一位
_nop_();
sclk = 1;
_nop_();
sclk = 0;
dat = 1; //通道1的第二位
_nop_();
sclk = 1;
_nop_();
sclk=0;
dat=1;
for(i=0;i<8;i++)
_nop_();
adval<<=1;
sclk=1;
_nop_();
sclk=0;
if(dat)
adval|=0x01;
adval|=0x00;
for(i=0;i<8;i++)
test>>=1;
if(dat)
{test|=0x80;}
test|=0x00;
_nop_();
sclk=1;
_nop_();
sclk=0;
if(adval=test) //如果輸出一直為0 就去掉
mdat=test;
_nop_();
cs=1;
dat=1;
sclk=1;
return adval;
unsigned char i;
//delay(1);
lcdinit();
wendu_shuzi(42,2,0); //0 最初溫度顯示為00.00
wendu_shuzi(50,2,0); //0
wendu_shuzi(61,2,0); //0
wendu_shuzi(69,2,0); //0
hanz(0,2,0); //顯示"溫度等級 "
hanz(0,4,1);
riqi(); //顯示基本格局
mdat=adc0832(0) ;
convdata(mdat);
delay(1);
display(Ds18b20ReadTemp());
if(SetState==0) //如果不按k1就繼續(xù)讀日期
Ds1302ReadTime();
if(K1==0) //檢測按鍵K1是否按下
delay(10); //消除抖動
if(K1==0)
SetPlace++;
if(SetPlace>=7)
SetPlace=0;
while((i<50)&&(K1==0)) //檢測按鍵是否松開
delay(10);
i++;
i=0;
if(K2==0) //檢測按鍵K2是否按下
delay(10); //消除抖動
if(K2==0)
Ds1302Write(0x81+SetPlace,TIME[SetPlace]++); //寫入時間,停止掉電運行,調(diào)完后讀取,在開啟掉電運行
if((TIME[SetPlace]&0x0f)>9) //換成BCD碼。
TIME[SetPlace]=TIME[SetPlace]+6; //
if((TIME[SetPlace]>=0x60)&&(SetPlace<2)) //分秒只能到59
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x24)&&(SetPlace==2)) //小時只能到23
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x32)&&(SetPlace==3)) //日只能到31
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x13)&&(SetPlace==4)) //月只能到12
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x08)&&(SetPlace==5)) //周只能到7
TIME[SetPlace]=1;
// if(SetPlace==5) //月只能到12
// TIME[SetPlace]=;
Ds1302Write(0x8e,0x80);
while((i<50)&&(K2==0)) //檢測按鍵是否松開
delay(10);
i++;
i=0;
if(K4==0) //檢測按鍵K4是否按下
delay(10); //消除抖動
if(K4==0)
// TIME[SetPlace]--;
Ds1302Write(0x81+SetPlace,TIME[SetPlace]--);
if((TIME[SetPlace]&0x0f)==0) //換成BCD碼。
TIME[SetPlace]=9;//TIME[SetPlace]+6;
if((TIME[SetPlace]<=0)&&(SetPlace<2)) //分秒只能到59
TIME[SetPlace]=0;
if((TIME[SetPlace]<=0)&&(SetPlace==2)) //小時只能到23
TIME[SetPlace]=0;
if((TIME[SetPlace]<=0)&&(SetPlace==3)) //日只能到31
TIME[SetPlace]=0;
if((TIME[SetPlace]<=0)&&(SetPlace==4)) //月只能到12
TIME[SetPlace]=0;
if((TIME[SetPlace]<=0x01)&&(SetPlace==5)) //周只能到7
TIME[SetPlace]=1;
// TIME[SetPlace]=;
while((i<50)&&(K4==0)) //檢測按鍵是否松開
delay(10);
i++;
i=0;
LcdDisplay();
//設(shè)置INT0
IT1=1;//跳變沿出發(fā)方式(下降沿)
EX1=1;//打開INT0的中斷允許。
EA=1;//打開總中斷
void LcdDisplay() //lcd顯示
yingwenzifu(0,0,6); // 年
yingwenzifu(7,0,4);
yingwenzifu(15,0,4+TIME[6]/16); //十六進制除以16相當(dāng)于十進制除以十 /16 只取高中四位字節(jié) 高四位是保存十位,低四位是保存?zhèn)位的
yingwenzifu(22,0,4+(TIME[6]&0x0f));
yingwenzifu(38,0,4+TIME[4]/16); // 月
yingwenzifu(44,0,4+(TIME[4]&0x0f));
yingwenzifu(59,0,4+TIME[3]/16); // 日
yingwenzifu(65,0,4+(TIME[3]&0x0f));
yingwenzifu(0,1,4+TIME[2]/16); // 時 高位
yingwenzifu(7,1,4+(TIME[2]&0x0f));
yingwenzifu(19,1,4+TIME[1]/16); // 分
yingwenzifu(25,1,4+(TIME[1]&0x0f));
yingwenzifu(37,1,4+TIME[0]/16); // 秒
yingwenzifu(43,1,4+(TIME[0]&0x0f));
xingqi(65,1,(TIME[5]&0x0f) ); //星期 07 68
void display(uint temp) //lcd顯示 溫度
float tp;
if(temp<0)
yingwenzifu(30, 2,13);
yingwenzifu(34, 2,13); //加上一個負號 其實現(xiàn)在x=
temp=temp-1;
temp=~temp;
temp=tp*100+0.5; //保留兩位小數(shù)
yingwenzifu( 36, 2,0);
yingwenzifu(40, 2,0);
tp=temp;
temp=tp*0.0625*100+0.5;
tidai=temp;
wendu_shuzi(42,2,tidai%10000/1000); //十位 48
wendu_shuzi(50,2,tidai%1000/100); //個位 56
wendu_shuzi(61,2,tidai%100/10); //小數(shù)點后第一位 67
wendu_shuzi(69,2,tidai%10); //小數(shù)點后第二位 75
void Int1() interrupt 2 //中
delay(10);
if(K3==0)
SetState=~SetState;
SetPlace=0;
Ds1302Init();
煙霧報警器.pdf
2020-1-29 19:28 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
244.01 KB, 下載次數(shù): 16, 下載積分: 黑幣 -5
煙霧報警器.zip
2020-1-29 19:24 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
76.38 KB, 下載次數(shù): 21, 下載積分: 黑幣 -5
LCD5110驅(qū)動程序、溫度顯示、煙霧模塊、模數(shù)轉(zhuǎn)換、DS1302
