查看: 2712|回復: 0
ARDUINO-ATMEGA328P-AU-Rotate Encoder-2Channel-PWM
ID:486426 發(fā)表于 2020-2-3 08:29 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include <Arduino.h>//ATMEGA328P-AU-2Channel-PWM.ino
  2. #define PIN_ENT   6  //編碼器的按鈕接6
  3. #define PIN_ENA   7  //編碼器的a腳接7
  4. #define PIN_ENB   8  //編碼器的b腳接8
  5. #define PIN_VOL   9  //PWM電平模擬電壓輸出1,可以更換其它 PWM 輸出引腳3,10
  6. #define PIN_CUR   5  //PWM電平模擬電壓輸出2,可以更換其它 PWM 輸出引腳3,10
  7. #define PIN_zhshi 11 // 編碼器調(diào)節(jié)PWM指示
  8. int v_temp = 48;     //PWM輸出1占空比初值
  9. int c_temp = 12;     //PWM輸出2占空比初值
  10. boolean Pmode = true;//true--調(diào)節(jié)PWM輸出1  false--調(diào)節(jié)PWM輸出2
  11. volatile uint8_t a0, b0;
  12. int c0 = 1;  //定義變量存以儲讀值
  13. void setup()
  14. {
  15.   pinMode(PIN_VOL, OUTPUT);//
  16.   pinMode(PIN_CUR, OUTPUT);//
  17.   pinMode(PIN_zhshi, OUTPUT);//
  18.   digitalWrite(PIN_zhshi, HIGH);
  19.   pinMode(PIN_ENA, INPUT_PULLUP);//
  20.   pinMode(PIN_ENB, INPUT_PULLUP);//
  21.   pinMode(PIN_ENT, INPUT);//
  22.   Serial.begin(9600);
  23.
  24.   // setup pin change interrupt for rotary encoder
  25.   PCMSK0 = bit (PCINT0);                // Configure pin change interrupt on Pin8
  26.   PCICR  = bit (PCIE0);                 // Enable pin change interrupt
  27.   PCIFR  = bit (PCIF0);                 // Clear interrupt flag
  28.   a0 = PINB & 1;
  29.   b0 = PIND>>7 & 1;
  30.   //c0 = digitalRead(PIN_ENT);
  31.   }
  32.
  33. void loop()
  34. {
  35. PINENTCheck();
  36. analogWrite(PIN_VOL,v_temp);//
  37. analogWrite(PIN_CUR,c_temp);//
  38. }
  39. // check and activate/deactivate boost mode
  40. void PINENTCheck(void)
  41.   {
  42.          uint8_t c = digitalRead(PIN_ENT);
  43.   if (!c && c0) {
  44.   // check rotary encoder switch
  45.   // delay(10);
  46.   // val = digitalRead(PIN_ENT);
  47.   if(Pmode == false)//切換PWM通道
  48.    {
  49.       Pmode = true;
  50.       digitalWrite(PIN_zhshi, HIGH);
  51.           }
  52.   else
  53.     {
  54.       Pmode = false;
  55.       digitalWrite(PIN_zhshi, LOW);
  56.           }
  57.    }
  58.    c0 = c;
  59. }
  60. // Pin change interrupt service routine for rotary encoder
  61. ISR (PCINT0_vect)
  62. {
  63.   uint8_t a = PINB & 1;
  64.   uint8_t b = PIND>>7 & 1;
  65.   if (a != a0)     // A changed
  66.   {
  67.           a0 = a;
  68.     if (b != b0)   // B changed
  69.     {
  70.       b0 = b;
  71.          if (a == b)
  72.            {
  73.            if  (Pmode == true)
  74.          {
  75.             v_temp++;;
  76.             if (v_temp > 255) {v_temp = 255;}
  77.           }
  78.            else  if ( Pmode == false)
  79.          {
  80.             c_temp++;;
  81.             if (c_temp > 255) {c_temp = 255;}
  82.           }
  83.             }
  84.    else         if (a != b)
  85.      {
  86.       if ( Pmode == true)
  87.         {
  88.             v_temp--;
  89.             if (v_temp < 1) {v_temp = 1;}
  90.         }
  91.             else   if ( Pmode == false)
  92.         {
  93.             c_temp--;
  94.             if (c_temp < 1) {c_temp = 1;}
  95.         }
  96.       }
  97.      }
  98.     }
  99. }
復制代碼
ATMEGA328P-AU-2Channel-PWM.rar
2.19 KB, 下載次數(shù): 10, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
收藏收藏2 分享淘帖 頂 踩
