多路溫度采集程序,每個傳感器都有自己的ID碼,讀取并記錄,通過查表的方式控制每一路溫度采集。
#include <reg51.h>
#include <Intrins.h>
#define DATA P1 //1602驅(qū)動端口
//ROM操作命令
#define READ_ROM 0x33 //讀ROM
#define SKIP_ROM 0xCC //跳過ROM
#define MATCH_ROM 0x55 //匹配ROM
#define SEARCH_ROM 0xF0 //搜索ROM
#define ALARM_SEARCH 0xEC //告警搜索
//存儲器操作命令
#define ANEW_MOVE 0xB8 //重新調(diào)出E^2數(shù)據(jù)
#define READ_POWER 0xB4 //讀電源
#define TEMP_SWITCH 0x44 //啟動溫度變換
#define READ_MEMORY 0xBE //讀暫存存儲器
#define COPY_MEMORY 0x48 //復制暫存存儲器
#define WRITE_MEMORY 0x4E //寫暫存存儲器
//數(shù)據(jù)存儲結(jié)構(gòu)
typedef struct tagTempData
unsigned char btThird; //百位數(shù)據(jù)
unsigned char btSecond; //十位數(shù)據(jù)
unsigned char btFirst; //個位數(shù)據(jù)
unsigned char btDecimal; //小數(shù)點后一位數(shù)據(jù)
unsigned char btNegative; //是否為負數(shù)
}TEMPDATA;
TEMPDATA m_TempData;
//引腳定義
sbit DQ = P2^7; //數(shù)據(jù)線端口
sbit RS= P2^0;
sbit RW= P2^1;
sbit E= P2^2;
//DS18B20序列號,通過調(diào)用GetROMSequence()函數(shù)在P1口讀出(讀8次)
const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7}; //U1
const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E}; //U2
const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9}; //U3
const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0}; //U4
const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52}; //U5
const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65}; //U6
const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C}; //U7
const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B}; //U8
//判斷忙指令
void Busy()
DATA = 0xff;
RS = 0;
RW = 1;
while(DATA & 0x80)
E = 0;
E = 1;
E = 0;
//寫指令程序
void WriteCommand(unsigned char btCommand)
Busy();
RS = 0;
RW = 0;
E = 1;
DATA = btCommand;
E = 0;
//寫數(shù)據(jù)程序
void WriteData(unsigned char btData)
Busy();
RS = 1;
RW = 0;
E = 1;
DATA = btData;
E = 0;
//清屏顯示
void Clear()
WriteCommand(1);
//初始化
void Init()
WriteCommand(0x0c); //開顯示,無光標顯示
WriteCommand(0x06); //文字不動,光標自動右移
WriteCommand(0x38); //設置顯示模式:8位2行5x7點陣
//顯示單個字符
void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
if (bRow) WriteCommand(0xc0 + btColumn);
else WriteCommand(0x80 + btColumn);
if (bIsNumber) WriteData(btData + 0x30);
else WriteData(btData);
//顯示字符串函數(shù)
void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
while (*pData != '\0')
if (bRow) WriteCommand(0xc0 + btColumn); //顯示在第1行
else WriteCommand(0x80 + btColumn); //顯示在第0行
WriteData(*(pData++)); //要顯示的數(shù)據(jù)
btColumn++; //列數(shù)加一
//延時16us子函數(shù)
void Delay16us()
unsigned char a;
for (a = 0; a < 4; a++);
//延時60us子函數(shù)
void Delay60us()
unsigned char a;
for (a = 0; a < 18; a++);
//延時480us子函數(shù)
void Delay480us()
unsigned char a;
for (a = 0; a < 158; a++);
//延時240us子函數(shù)
void Delay240us()
unsigned char a;
for (a = 0; a < 78; a++);
//延時500ms子函數(shù)
void Delay500ms()
unsigned char a, b, c;
for (a = 0; a < 250; a++)
for (b = 0; b < 3; b++)
for (c = 0; c < 220; c++);
//芯片初始化
void Initialization()
DQ = 0;
Delay480us(); //延時480us
DQ = 1;
Delay60us(); //延時60us
if(!DQ) //收到ds18b20的應答信號
DQ = 1;
Delay240us(); //延時240us
break;
//寫一個字節(jié)(從低位開始寫)
void WriteByte(unsigned char btData)
unsigned char i, btBuffer;
for (i = 0; i < 8; i++)
btBuffer = btData >> i;
if (btBuffer & 1)
DQ = 0;
_nop_();
_nop_();
DQ = 1;
Delay60us();
DQ = 0;
Delay60us();
DQ = 1;
//讀一個字節(jié)(從低位開始讀)
unsigned char ReadByte()
unsigned char i, btDest;
btDest >>= 1;
DQ = 0;
_nop_();
_nop_();
DQ = 1;
Delay16us();
if (DQ) btDest |= 0x80;
Delay60us();
return btDest;
//序列號匹配
void MatchROM(const unsigned char *pMatchData)
unsigned char i;
Initialization();
WriteByte(MATCH_ROM);
for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
//得到64位ROM序列(在P1口顯示,必須與Proteus聯(lián)調(diào)且在單步調(diào)試下才能得到)
/*void GetROMSequence()
unsigned char i;
Initialization();
WriteByte(READ_ROM);
P1 = ReadByte();
//讀取溫度值
TEMPDATA ReadTemperature()
TEMPDATA TempData;
unsigned int iTempDataH;
unsigned char btDot, iTempDataL;
static unsigned char i = 0;
TempData.btNegative = 0; //為0溫度為正
i++;
if (i == 9) i = 1;
Initialization();
WriteByte(SKIP_ROM); //跳過ROM匹配
WriteByte(TEMP_SWITCH); //啟動轉(zhuǎn)換
Delay500ms(); //調(diào)用一次就行
Delay500ms();
Initialization();
//多個芯片的時候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
switch (i)
case 1 : MatchROM(ROMData1); break; //匹配1
case 2 : MatchROM(ROMData2); break; //匹配2
case 3 : MatchROM(ROMData3); break; //匹配3
case 4 : MatchROM(ROMData4); break; //匹配4
case 5 : MatchROM(ROMData5); break; //匹配5
case 6 : MatchROM(ROMData6); break; //匹配6
case 7 : MatchROM(ROMData7); break; //匹配7
case 8 : MatchROM(ROMData8); break; //匹配8
//WriteByte(SKIP_ROM); //跳過ROM匹配(單個芯片時用這句換掉上面的switch)
WriteByte(READ_MEMORY); //讀數(shù)據(jù)
iTempDataL = ReadByte();
iTempDataH = ReadByte();
iTempDataH <<= 8;
iTempDataH |= iTempDataL;
if (iTempDataH & 0x8000)
TempData.btNegative = 1;
iTempDataH = ~iTempDataH + 1; //負數(shù)求補
//為了省去浮點運算帶來的開銷,而采用整數(shù)和小數(shù)部分分開處理的方法(沒有四舍五入)
btDot = (unsigned char)(iTempDataH & 0x000F); //得到小數(shù)部分
iTempDataH >>= 4; //得到整數(shù)部分
btDot *= 5; //btDot*10/16得到轉(zhuǎn)換后的小數(shù)數(shù)據(jù)
btDot >>= 3;
//數(shù)據(jù)處理
TempData.btThird = (unsigned char)iTempDataH / 100;
TempData.btSecond = (unsigned char)iTempDataH % 100 / 10;
TempData.btFirst = (unsigned char)iTempDataH % 10;
TempData.btDecimal = btDot;
return TempData;
//數(shù)據(jù)處理子程序
void DataProcess()
m_TempData = ReadTemperature();
if (m_TempData.btNegative) DisplayOne(1, 6, '-', 0);
else DisplayOne(1, 6, m_TempData.btThird, 1);
DisplayOne(1, 7, m_TempData.btSecond, 1);
DisplayOne(1, 8, m_TempData.btFirst, 1);
DisplayOne(1, 10, m_TempData.btDecimal, 1);
int main(void)
//GetROMSequence();
Clear();
Init();
DisplayString(0, 0, " Temperature");
DisplayOne(1, 9, '.', 0);
while (1) DataProcess();
