查看: 5050|回復: 5
單片機波形發(fā)生器設計 包含仿真,源程序
ID:571533 發(fā)表于 2020-2-17 20:20 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
波形發(fā)生器,可產(chǎn)生方波,正弦波,三角波,鋸齒波,步進頻率可調(diào),幅值
單片機源程序如下:
  1. #include<reg52.h>                                           //包含頭文件
  2. #include<intrins.h>
  3. #define uchar unsigned char                           //宏定義
  4. #define uint unsigned int
  5. sbit s1=P3^5;                                                    //定義按鍵的接口
  6. sbit s2=P3^6;
  7. sbit s3=P3^7;
  8. sbit s4=P3^4;
  9.
  10. sbit lcdrs=P2^7;                                           //液晶控制引腳
  11. sbit lcden=P2^6;
  12. char num,boxing,u;
  13. int pinlv=100,bujin=1,bujin1=1;                   //頻率初始值是10Hz,步進值默認是0.1,顯示步進值變量
  14. uchar code table[]="0123456789";                //定義顯示的數(shù)組
  15. uchar code table1[]="Fout=     Wave form:";        //初始化顯示字符
  16. unsigned long int m;                                   //定義長整形變量 m
  17. int a,b,h,num1;                                                        //定義全局變量
  18. //自定義字符
  19. uchar code zifu[]={                   //此數(shù)組內(nèi)數(shù)據(jù)為液晶上顯示波形符號的自定義字符
  20.                                                 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
  21.                                                 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00,          //正弦波           0  1
  22.                                                 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
  23.                                                 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00,          //矩形波           2  3
  24.                                                 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
  25.                                                 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00,          //三角波           4  5
  26.                                                 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00,            //鋸齒波           6
  27. };
  28. uchar code sin[64]={           //da輸出對應電壓值對應的數(shù)字量,0是0V,255是5V
  29. 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
  30. 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
  31. };                                          //正弦波取碼
  32. uchar code juxing[64]={                //一個周期是采樣64個點, 所以數(shù)組內(nèi)是64個數(shù)據(jù)
  33. 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  34. 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  35. };                                          //矩形波取碼
  36. uchar code sanjiao[64]={
  37. 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  38. 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  39. };                                                //三角波取碼
  40. uchar code juchi[64]={
  41. 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
  42. 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
  43. };                                          //鋸齒波取碼
  44. void delay(uint xms)         //延時函數(shù)
  45. {
  46.         int a,b;
  47.         for(a=xms;a>0;a--)
  48.                 for(b=110;b>0;b--);
  49. }
  50. void write_com(uchar com)                //寫命令函數(shù)
  51. {
  52.         lcdrs=0;
  53.         P0=com;
  54.         delay(1);
  55.         lcden=1;
  56.         delay(1);
  57.         lcden=0;
  58. }
  59. void write_date(uchar date)                //寫數(shù)據(jù)函數(shù)
  60. {
  61.         lcdrs=1;
  62.         P0=date;
  63.         delay(1);
  64.         lcden=1;
  65.         delay(1);
  66.         lcden=0;
  67. }
  68. //自定義字符集
  69. void Lcd_ram()
  70. {
  71.         uint i,j,k=0,temp=0x40;
  72.         for(i=0;i<7;i++)
  73.         {
  74.            for(j=0;j<8;j++)
  75.            {
  76.             write_com(temp+j);
  77.             write_date(zifu[k]);
  78.             k++;
  79.            }
  80.            temp=temp+8;
  81.         }
  82. }
  83. void init_lcd()                                        //初始化函數(shù)
  84. {
  85.         uchar i;
  86.         lcden=0;                                        //默認開始狀態(tài)為關使能端,見時序圖
  87.         Lcd_ram();
  88.         write_com(0x0f);
  89.         write_com(0x38);                        //顯示模式設置,默認為0x38,不用變。
  90.         write_com(0x01);                        //顯示清屏,將上次的內(nèi)容清除,默認為0x01.
  91.         write_com(0x0c);                        //顯示功能設置0x0f為開顯示,顯示光標,光標閃爍;0x0c為開顯示,不顯光標,光標不閃
  92.         write_com(0x06);                        //設置光標狀態(tài)默認0x06,為讀一個字符光標加1.
  93.         write_com(0x80);                        //設置初始化數(shù)據(jù)指針,是在讀指令的操作里進行的
  94.         for(i=10;i<20;i++)                           //顯示初始化
  95.         {
  96.                 write_date(table1[i]);                   //顯示第一行字符
  97.         }
  98.         write_com(0x80+0x40);                           //選擇第二行
  99.         for(i=0;i<9;i++)
  100.         {
  101.                 write_date(table1[i]);                   //顯示第二行字符
  102.         }
  103.         write_com(0x80+10);                                   //選擇第一行第十個位置
  104.         write_date(0);
  105.         write_date(1);
  106.         write_date(0);
  107.         write_date(1);
  108.         write_date(0);
  109.         write_date(1);                                           //顯示自定義的波形圖案
  110.         write_com(0x80+0x40+0x09);                   //選擇第二行第九個位置
  111.         write_date(' ');
  112.         write_date('1');
  113.         write_date('0');
  114.         write_date('.');
  115.         write_date('0');
  116.         write_date('H');
  117.         write_date('z');                                   //顯示初始的頻率值
  118. }
  119. void initclock()                           //定時器初始化函數(shù)
  120. {
  121.         TMOD=0x01;                                   //定時器的工作方式
  122.         TH0=a;
  123.         TL0=b;                                           //定時器賦初值
  124.         EA=1;                                           //打開中斷總開關
  125.         ET0=1;                                           //打開定時器允許中斷開關
  126.         TR0=1;                                           //打開定時器定時開關
  127. }
  128. void display()                                   //顯示函數(shù)
  129. {
  130.         uchar qian,bai,shi,ge;           //定義變量用于顯示
  131.         qian=pinlv/1000;                   //將頻率值拆成一位的數(shù)據(jù),將數(shù)據(jù)除以1000,得到的商是一位數(shù),賦值給qian
  132.         bai=pinlv%1000/100;                   //將頻率除以1000的余數(shù)再除以100就得到了頻率的百位,賦值給bai
  133.         shi=pinlv%1000%100/10;           //同上,得到頻率的十位
  134.         ge=pinlv%1000%100%10;
  135.         write_com(0x80+0x40+0x09); //選中第二行第九個位置
  136.            if(qian==0)                                   //千位如果為0
  137.         write_date(' ');                   //不顯示
  138.         else                                           //千位不為0
  139.         write_date(table[qian]);   //正常顯示千位
  140.         if(qian==0&&bai==0)                   //千位和百位都為0
  141.         write_date(' ');                   //百位不顯示
  142.         else                                           //不都為0
  143.         write_date(table[bai]);           //百位正常顯示
  144.         write_date(table[shi]);           //顯示十位數(shù)
  145.         write_date('.');                   //顯示小數(shù)點
  146.         write_date(table[ge]);           //顯示個位
  147.         write_date('H');                   //顯示頻率的單位Hz
  148.         write_date('z');
  149.         if(boxing==0)                           //判斷波形為正弦波
  150.         {
  151.                 write_com(0x80+10);           //選中一行頻率圖案位置
  152.                 write_date(0);                   //顯示正弦波圖案
  153.                 write_date(1);
  154.                 write_date(0);
  155.                 write_date(1);
  156.                 write_date(0);
  157.                 write_date(1);
  158.
  159.         }
  160.         if(boxing==1)                                //注釋同上
  161.         {
  162.                 write_com(0x80+10);
  163.                 write_date(2);
  164.                 write_date(3);
  165.                 write_date(2);
  166.                 write_date(3);
  167.                 write_date(2);
  168.                 write_date(3);
  169.
  170.         }
  171.         if(boxing==2)
  172.         {
  173.                 write_com(0x80+10);
  174.                 write_date(4);
  175.                 write_date(5);
  176.                 write_date(4);
  177.                 write_date(5);
  178.                 write_date(4);
  179.                 write_date(5);
  180.
  181.         }
  182.         if(boxing==3)
  183.         {
  184.                 write_com(0x80+10);
  185.                 write_date(6);
  186.                 write_date(6);
  187.                 write_date(6);
  188.                 write_date(6);
  189.                 write_date(6);
  190.                 write_date(6);
  191.
  192.         }
  193. }
  194. void keyscan()                                        //頻率調(diào)節(jié)鍵盤檢測函數(shù)
  195. {
  196.         if(s1==0)                                        //加按鍵是否按下
  197.         {
  198.                 EA=0;                                        //關閉中斷
  199.                 delay(2);                            //延時去抖
  200.                 if(s1==0)                                //再次判斷
  201.                 {
  202.                         while(!s1);                        //按鍵松開
  203.                         pinlv+=bujin;                //頻率以步進值加
  204.                         if(pinlv>1000)                //最大加到100Hz
  205.                         {
  206.                                 pinlv=100;                //100Hz
  207.                         }
  208.                         display();                        //顯示函數(shù)
  209.                         m=65536-(150000/pinlv);//計算頻率
  210. /*頻率值最小是10Hz,pinlv的值是100(因為要顯示小數(shù)點后一位),150000/100=1500,這個1500就是定時器需要計時的,單位是us,65536-1500得到的是定時器的初值,
  211. 先不管初值,先看定時時間,1500us,一個波形的周期是由64個定時組成的,所以,一個波形周期就是64*1500us=96000,也就是96ms,約等
  212. 于100ms,也就是10Hz的頻率*/
  213.                         a=m/256;                        //將定時器的初值賦值給變量
  214.                         b=m%256;
  215.                         EA=1;                                //打開中斷總開關
  216.                 }
  217.         }
  218.         if(s2==0)                                        //減按鍵按下
  219.         {
  220.
  221.                 delay(5);
  222.                 if(s2==0)
  223.                 {
  224.                         EA=0;
  225.                         while(!s2);
  226.                         pinlv-=bujin;                   //頻率以步進值減
  227.                         if(pinlv<100)
  228.                         {
  229.                                 pinlv=1000;
  230.                         }
  231.                         display();
  232.                         m=65536-(150000/pinlv);
  233.                         a=m/256;
  234.                         b=m%256;
  235.                         EA=1;
  236.                 }
  237.         }
  238.         if(s3==0)                                         //波形切換按鍵
  239.         {
  240.                 delay(5);
  241.                 if(s3==0)
  242.                 {
  243.                         EA=0;
  244.                         while(!s3);
  245.                         boxing++;                           //波形切換
  246.                         if(boxing>=4)                   //4種波形
  247.                         {
  248.                                 boxing=0;
  249.                         }
  250.                         display();
  251.                         EA=1;
  252.                 }
  253.         }
  254. }
  255. void bujindisplay()                                 //步進值設置界面顯示程序
  256. {
  257.         uint bai,shi,ge;                         //定義步進值 百十個位
  258.         bai=bujin1/100;                                 //將步進值除以100得到百位,也就是頻率值的十位,因為有一個小數(shù)位
  259.         shi=bujin1%100/10;                         //將步進值除以100的余數(shù)除以十得到十位
  260.         ge=bujin1%100%10;                         //取余10后得到個位,也就是頻率步進值的小數(shù)點后一位
  261.         write_com(0x80+11);                         //選中液晶第一行第十一列
  262.         if(bai==0)                                         //百位是否為0
  263.         write_date(' ');                         //百位不顯示
  264.         else                                                 //百位不為0
  265.         write_date(table[bai]);                 //顯示百位數(shù)據(jù)
  266.         write_date(table[shi]);                 //顯示十位數(shù)據(jù)
  267.         write_date('.');                         //顯示小數(shù)點
  268.         write_date(table[ge]);                 //顯示個位,也就是小數(shù)點后一位
  269. }
  270. void bujinjiance()                                 //步進值設置鍵盤程序
  271. {
  272.         if(s4==0)                                         //步進設置按鍵按下
  273.         {
  274.                 delay(5);                                 //延時去抖
  275.                 if(s4==0)                                 //再次判斷按鍵
  276.                 {
  277.                          while(!s4);                 //按鍵釋放,按鍵松開才繼續(xù)向下執(zhí)行
  278.                          h++;                                 //變量加
  279.                          if(h==1)                         //進入設置狀態(tài)時
  280.                          {
  281.                                   write_com(0x01);                          //清屏
  282.                                  write_com(0x80);                          //初始化顯示步進設置界面
  283.                                  write_date('S');delay(1);          //step value
  284.                                  write_date('t');delay(1);
  285.                                  write_date('e');delay(1);
  286.                                  write_date('p');delay(1);
  287.                                  write_date(' ');delay(1);
  288.                                  write_date('v');delay(1);
  289.                                  write_date('a');delay(1);
  290.                                  write_date('l');delay(1);
  291.                                  write_date('u');delay(1);
  292.                                  write_date('e');delay(1);
  293.                                  write_date(':');delay(1);
  294.                                  bujin1=bujin;                                  //步進值賦值給臨時變量
  295.
  296.                                  bujindisplay();                          //顯示步進值
  297.                          }
  298.                          if(h==2)                                                  //退出設置
  299.                          {
  300.                                  h=0;                                                  //清零
  301.                                 bujin=bujin1;                                  //設置好的臨時步進值賦值給步進變量
  302.
  303.                                 init_lcd();                                          //初始化液晶顯示
  304.                                 initclock();                                  //定時器初始化
  305.                                 display();                                          //調(diào)用顯示程序
  306.                          }
  307.                 }
  308.         }
  309.         if(h==1)        //設置步進值時
  310.         {
  311.                 if(s1==0)                                                          //加按鍵按下
  312.                 {
  313.                         delay(5);                                                  //延時去抖
  314.                         if(s1==0)                                                  //再次判斷
  315.                         {
  316.                                 while(!s1);                                          //按鍵釋放
  317.                                 bujin1++;                                          //步進值加1
  318.                                 if(bujin1>=101)                                  //步進值最大100,也就是10.0Hz
  319.                                 {
  320.                                         bujin1=1;                                  //超過最大值就恢復到0.1Hz
  321.                                 }
  322.                                 bujindisplay();                                  //步進顯示
  323.                         }
  324.                 }
  325.                 if(s2==0)                                                          //減按鍵,注釋同上
  326.                 {
  327.                         delay(5);
  328.                         if(s2==0)
  329.                         {
  330.                                 while(!s2);
  331.                                 bujin1--;                                          //步進減
  332.                                 if(bujin1<=0)
  333.                                 {
  334.                                         bujin1=100;
  335.                                 }
  336.                                 bujindisplay();
  337.                         }
  338.                 }
  339.         }
  340. }
  341. void main()                                         //主函數(shù)
  342. {
  343.         init_lcd();                                 //調(diào)用初始化程序
  344.         m=65536-(150000/pinlv);         //定時器初值
  345.         a=m/256;
  346.         b=m%256;
  347.         initclock();                         //定時器初始化
  348.         while(1)                                 //進入while循環(huán),括號內(nèi)為1,一直成立,所以也叫死循環(huán),程序不會跳出,一直在內(nèi)執(zhí)行
  349.         {
  350.                 if(h==0)                         //正常模式不是步進調(diào)節(jié)
  351.                 {
  352.                         keyscan();                 //掃描按鍵
  353.                 //        display();
  354.                 }
  355.
  356.                 bujinjiance();                 //掃描步進調(diào)節(jié)程序
  357.                 switch(boxing)                                                        //選擇波形
  358.                 {
  359.                         case 0 : P1=sin[u]; break;                        //正弦波
  360.                         case 1 : P1=juxing[u]; break;                //矩形波
  361.                         case 2 : P1=sanjiao[u]; break;                //三角波
  362.                         case 3 : P1=juchi[u]; break;                //鋸齒波
  363.                 }
  364.         }
  365. }
  366. void T0_time()interrupt 1                   //定時器
  367. {
  368.         TH0=a;
  369.         TL0=b;                                                   //根據(jù)不同的初值,定時器定時時間不同,達到不同頻率的目的
  370.         u++;                                                   //變量加
  371.         if(u>=64)                                           //一個周期采樣64個點, 所以加到64就清零
  372.         u=0;                                                   //u清零
  373. }
復制代碼
可調(diào)
全部資料51hei下載地址:
仿真.zip (122.49 KB, 下載次數(shù): 145)
原理圖.zip (21.8 KB, 下載次數(shù): 109)
admin + 50 共享資料的黑幣獎勵!
收藏收藏2 分享淘帖 頂 踩
ID:817203 發(fā)表于 2020-9-11 09:28 來自觸屏版 | 只看該作者
誰能畫一下PCB分享出來嗎?
ID:980857 發(fā)表于 2021-12-3 10:31 | 只看該作者
沒有PCB??
ID:262 發(fā)表于 2021-12-3 18:33 | 只看該作者
這個是沒有,剛幫你找了一下其他的 這里有2個朋友上傳了PCB,這種作品很常見論壇里面應該還有很多 你可以自己找一下 搜索框 輸入"波形 PCB"
http://www.torrancerestoration.com/bbs/dpj-162263-1.html
http://www.torrancerestoration.com/bbs/dpj-198756-1.html
ID:986539 發(fā)表于 2021-12-15 14:09 | 只看該作者
為什么顯示正弦波圖案那里只用寫入0101就行了?上面定義的字符有什么作用?
ID:986539 發(fā)表于 2021-12-15 18:36 | 只看該作者
heicad 發(fā)表于 2021-12-3 18:33
這個是沒有,剛幫你找了一下其他的 這里有2個朋友上傳了PCB,這種作品很常見論壇里面應該還有很多 你可以自 ...
