查看: 2310|回復(fù): 0
uln2003驅(qū)動步進電機的代碼求講解
ID:418744 發(fā)表于 2020-2-26 20:46 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
20黑幣
#include "SteperMotor.h"
#define            StepMotor_Value 256
unsigned char StepMotor_Direc=0;
unsigned char StepMotor_Busy=0;
unsigned char StepMotor_EN=0;
void Stepper_Motor()
        static unsigned int  Step_Value;
        static unsigned char Step_Con;
        if(StepMotor_EN)
                if(StepMotor_Busy==0)
                        StepMotor_Busy=1;
                        Step_Con=0;
                        Step_Value=StepMotor_Value;
                        switch(Step_Con)
                                case 0:
                                        if(StepMotor_Direc)
                                                StepMoto_Pin1_Set();
                                                StepMoto_Pin2_Clr();
                                                StepMoto_Pin3_Clr();
                                                StepMoto_Pin4_Clr();
                                                StepMoto_Pin1_Clr();
                                                StepMoto_Pin4_Set();
                                        Step_Con++;
                                        break;
                                case 1:
                                        if(StepMotor_Direc)
                                                StepMoto_Pin2_Set();
                                                StepMoto_Pin3_Set();
                                        Step_Con++;
                                        break;
                                case 2:
                                        if(StepMotor_Direc)
                                        Step_Con++;
                                        break;
                                case 3:
                                        if(StepMotor_Direc)
                                        Step_Con=0;
                                        Step_Value--;
                                        if(Step_Value==0)
                                                StepMotor_EN=0;
                                                StepMotor_Busy=0;
                                        break;
void Step_Moto_Init()  //3õê¼»ˉPB13£¬14£¬15oíPA8
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
         GPIO_Init(GPIOB, &GPIO_InitStructure);
