查看: 2995|回復(fù): 1
基于51單片機(jī)的32位流水燈設(shè)計(jì) Proteus仿真程序
led燈的位置可以隨意變動(dòng),這圖案只是自己的一點(diǎn)小惡趣味
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. uchar code Pattern_P0[]=
  5. {
  6. 0xfc,0xf9,0xf3,0xe7,0xcf,0x9f,0x3f,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  7. 0xe7,0xdb,0xbd,0x7e,0xbd,0xdb,0xe7,0xff,0xe7,0xc3,0x81,0x00,0x81,0xc3,0xe7,0xff,
  8. 0xaa,0x55,0x18,0xff,0xf0,0x0f,0x00,0xff,0xf8,0xf1,0xe3,0xc7,0x8f,0x1f,0x3f,0x7f,
  9. 0x7f,0x3f,0x1f,0x8f,0xc7,0xe3,0xf1,0xf8,0xff,0x00,0x00,0xff,0xff,0x0f,0xf0,0xff,
  10. 0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  11. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
  12. 0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  13. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,
  14. 0x00,0xff,0x00,0xff,0x00,0xff,0x00,0xff
  15. };
  16. uchar code Pattern_P2[]=
  17. {
  18. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfc,0xf9,0xf3,0xe7,0xcf,0x9f,0x3f,0xff,
  19. 0xe7,0xdb,0xbd,0x7e,0xbd,0xdb,0xe7,0xff,0xe7,0xc3,0x81,0x00,0x81,0xc3,0xe7,0xff,
  20. 0xaa,0x55,0x18,0xff,0xf0,0x0f,0x00,0xff,0xf8,0xf1,0xe3,0xc7,0x8f,0x1f,0x3f,0x7f,
  21. 0x7f,0x3f,0x1f,0x8f,0xc7,0xe3,0xf1,0xf8,0xff,0x00,0x00,0xff,0xff,0x0f,0xf0,0xff,
  22. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,
  23. 0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  24. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00,
  25. 0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  26. 0x00,0xff,0x00,0xff,0x00,0xff,0x00,0xff
  27. };
  28. //延時(shí)
  29. void DelayMS(uint x)
  30. {
  31. uchar i;
  32. while(x--)
  33. {
  34. for(i=0;i<120;i++);
  35. }
  36. }
  37. //主程序
  38. void main()
  39. {
  40. uchar i;
  41. while(1)
  42. { //從數(shù)組中讀取數(shù)據(jù)送至 P0 和 P2 口顯示
  43. for(i=0;i<136;i++)
  44. {
  45. P0=Pattern_P0[i];
  46. P2=Pattern_P2[i];
  47. DelayMS(100);
  48. }
  49. }
  50. }
全部資料51hei下載地址:
32位LED流水燈.rar (61.38 KB, 下載次數(shù): 22)
ID:776841 發(fā)表于 2020-6-14 02:11 | 只看該作者
可以   挺好
