程序代碼
#include "reg51.h"
#include "intrins.H"
//8步式步進電機脈沖序列
//unsigned char steps[8] = {0x77,0x33,0xbb,0x99,0xdd,0xcc,0xee,0x66};
unsigned char steps[8] = {0x2,0x6,0x4,0xc,0x8,0x9,0x1,0x3};
//當(dāng)前各電機在上述序列中的位置
unsigned char cur_step[8] = {0,0,0,0,0,0,0,0};
//這個文件用于記錄舞步信息序列
char speed_tickers[8] = {0,0,0,0,0,0,0,0};
//從上述文件中讀出的當(dāng)前舞步信息
unsigned char speeds[8] = {0,0,0,0,0,0,0,0};
unsigned char data_pointer = 0;//指向舞步數(shù)據(jù)的指針
unsigned char time_t = 0;//指定重新讀取一次 speeds 值的計時周期
code char dancedata[] = {54,15,12,12,87,95,65,45,-89,-88,-54,-54,54,68,-45,-65,-65,-48,101,121,115,117,19,
-98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,109,104,-30,-102,-104,-106,110,100,
54,15,12,12,87,95,65,45,-89,-88,-54,-54,-98,95,102,102,100,130,30,10,-90,-120,87,102-114,-101,-24,-98,95,102,102,
100,130,30,10,-90,-120,87,102,102,100,130,30,10,-90,-120,87,102,103,105,54,15,12,12,87,95,65,45,-89,-88,-54,
-98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,12,87,95,65,45,-89,-88,-54,
100,130,30,10,-90,-120,87,102,102,100,130,30,10,-90,-120,87,-120,87,102,103,105,109,104,-30,-102,-104,-106,110,
code char pin[8] = {1,2,4,8,16,32,64,128};
char MAX_SPEED_TICKER = 120;
unsigned char i; //電機序號
void InitTimer(void) //初始化計數(shù)器
TH0 = 0xFA; //設(shè)置觸發(fā)周期:1000次
TL0 = 0x24;
TMOD = TMOD |0x01; //select mode 1
TR0 = 1; //start timer0
ET0 = 1; //enable timer 0 interrupt
EA =1; //global interrupt enable
void SetAllSpeeds(void) //設(shè)置各電機的速度,并讓它運動起來
char delta; //旋轉(zhuǎn)方向 1:正 -1:反 0:停
for(i=0;i<8;i++)
P2=pin; //發(fā)送鎖存信號
speed_tickers += speeds; //計數(shù)值增加 speed越高,增加得越多
if(speed_tickers >= MAX_SPEED_TICKER) //如果計數(shù)值超過預(yù)定最大值,就發(fā)送脈沖
speed_tickers = 0;
delta = 1;
else if(speed_tickers <= -MAX_SPEED_TICKER) //同上,反響旋轉(zhuǎn)
speed_tickers = 0;
delta = -1;
else delta = 0;
cur_step += delta;
cur_step &= 0x07; //計算當(dāng)前應(yīng)發(fā)脈沖
P0 = steps[cur_step];
P2 = 0;
void OnTimer(void) interrupt 1 using 2
unsigned char j;
SetAllSpeeds();
InitTimer();
time_t++;
if(time_t==200) //每200次觸發(fā)讀取一次新舞步數(shù)據(jù)
for(j=0;j<8;j++)
speeds[j] = dancedata[data_pointer+j];
data_pointer += 8;
time_t = 0;
void main() //程序的入口
InitTimer(); //初始化后等中斷
while(1);
