查看: 5412|回復(fù): 3
AMG8833 8831資料及arduino測試代碼
ID:704867 發(fā)表于 2020-3-8 22:50 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
松下紅外矩陣攝像頭資料 里面包含datasheet 和一些使用手冊,并含有arduino測試代碼,方便大家
Arduino源程序如下:
  1. #include "Adafruit_AMG88xx.h"
  2. bool Adafruit_AMG88xx::begin(uint8_t addr)
  3. {
  4.         _i2caddr = addr;
  5.
  6.         _i2c_init();
  7.
  8.         //enter normal mode
  9.         _pctl.PCTL = AMG88xx_NORMAL_MODE;
  10.         write8(AMG88xx_PCTL, _pctl.get());
  11.
  12.         //software reset
  13.         _rst.RST = AMG88xx_INITIAL_RESET;
  14.         write8(AMG88xx_RST, _rst.get());
  15.
  16.         //disable interrupts by default
  17.         disableInterrupt();
  18.
  19.         //set to 10 FPS
  20.         _fpsc.FPS = AMG88xx_FPS_10;
  21.         write8(AMG88xx_FPSC, _fpsc.get());
  22.         return true;
  23. }
  24. void Adafruit_AMG88xx::setMovingAverageMode(bool mode)
  25. {
  26.         _ave.MAMOD = mode;
  27.         write8(AMG88xx_AVE, _ave.get());
  28. }
  29. void Adafruit_AMG88xx::setInterruptLevels(float high, float low)
  30. {
  31.         setInterruptLevels(high, low, high * .95);
  32. }
  33. void Adafruit_AMG88xx::setInterruptLevels(float high, float low, float hysteresis)
  34. {
  35.         int highConv = high / AMG88xx_PIXEL_TEMP_CONVERSION;
  36.         highConv = constrain(highConv, -4095, 4095);
  37.         _inthl.INT_LVL_H = highConv & 0xFF;
  38.         _inthh.INT_LVL_H = (highConv & 0xF) >> 4;
  39.         this->write8(AMG88xx_INTHL, _inthl.get());
  40.         this->write8(AMG88xx_INTHH, _inthh.get());
  41.
  42.         int lowConv = low / AMG88xx_PIXEL_TEMP_CONVERSION;
  43.         lowConv = constrain(lowConv, -4095, 4095);
  44.         _intll.INT_LVL_L = lowConv & 0xFF;
  45.         _intlh.INT_LVL_L = (lowConv & 0xF) >> 4;
  46.         this->write8(AMG88xx_INTLL, _intll.get());
  47.         this->write8(AMG88xx_INTLH, _intlh.get());
  48.
  49.         int hysConv = hysteresis / AMG88xx_PIXEL_TEMP_CONVERSION;
  50.         hysConv = constrain(hysConv, -4095, 4095);
  51.         _ihysl.INT_HYS = hysConv & 0xFF;
  52.         _ihysh.INT_HYS = (hysConv & 0xF) >> 4;
  53.         this->write8(AMG88xx_IHYSL, _ihysl.get());
  54.         this->write8(AMG88xx_IHYSH, _ihysh.get());
  55. }
  56. void Adafruit_AMG88xx::enableInterrupt()
  57. {
  58.         _intc.INTEN = 1;
  59.         this->write8(AMG88xx_INTC, _intc.get());
  60. }
  61. void Adafruit_AMG88xx::disableInterrupt()
  62. {
  63.         _intc.INTEN = 0;
  64.         this->write8(AMG88xx_INTC, _intc.get());
  65. }
  66. void Adafruit_AMG88xx::setInterruptMode(uint8_t mode)
  67. {
  68.         _intc.INTMOD = mode;
  69.         this->write8(AMG88xx_INTC, _intc.get());
  70. }
  71. void Adafruit_AMG88xx::getInterrupt(uint8_t *buf, uint8_t size)
  72. {
  73.         uint8_t bytesToRead = min(size, 8);
  74.
  75.         this->read(AMG88xx_INT_OFFSET, buf, bytesToRead);
  76. }
  77. void Adafruit_AMG88xx::clearInterrupt()
  78. {
  79.         _rst.RST = AMG88xx_FLAG_RESET;
  80.         write8(AMG88xx_RST, _rst.get());
  81. }
  82. float Adafruit_AMG88xx::readThermistor()
  83. {
  84.         uint8_t raw[2];
  85.         this->read(AMG88xx_TTHL, raw, 2);
  86.         uint16_t recast = ((uint16_t)raw[1] << 8) | ((uint16_t)raw[0]);
  87.         return signedMag12ToFloat(recast) * AMG88xx_THERMISTOR_CONVERSION;
  88. }
  89. void Adafruit_AMG88xx::readPixels(float *buf, uint8_t size)
  90. {
  91.         uint16_t recast;
  92.         float converted;
  93.         uint8_t bytesToRead = min(size << 1, AMG88xx_PIXEL_ARRAY_SIZE << 1);
  94.         uint8_t rawArray[bytesToRead];
  95.         this->read(AMG88xx_PIXEL_OFFSET, rawArray, bytesToRead);
  96.
  97.         for(int i=0; i<size; i++){
  98.                 uint8_t pos = i << 1;
  99.                 recast = ((uint16_t)rawArray[pos + 1] << 8) | ((uint16_t)rawArray[pos]);
  100.
  101.                 converted = signedMag12ToFloat(recast) * AMG88xx_PIXEL_TEMP_CONVERSION;
  102.                 buf[i] = converted;
  103.         }
  104. }
  105. void Adafruit_AMG88xx::write8(byte reg, byte value)
  106. {
  107.         this->write(reg, &value, 1);
  108. }
  109. uint8_t Adafruit_AMG88xx::read8(byte reg)
  110. {
  111.         uint8_t ret;
  112.         this->read(reg, &ret, 1);
  113.
  114.         return ret;
  115. }
  116. void Adafruit_AMG88xx::_i2c_init()
  117. {
  118.         Wire.begin();
  119. }
  120. void Adafruit_AMG88xx::read(uint8_t reg, uint8_t *buf, uint8_t num)
  121. {
  122.         uint8_t value;
  123.         uint8_t pos = 0;
  124.
  125.         //on arduino we need to read in 32 byte chunks
  126.         while(pos < num){
  127.
  128.                 uint8_t read_now = min(32, num - pos);
  129.                 Wire.beginTransmission((uint8_t)_i2caddr);
  130.                 Wire.write((uint8_t)reg + pos);
  131.                 Wire.endTransmission();
  132.                 Wire.requestFrom((uint8_t)_i2caddr, read_now);
  133.
  134.                 for(int i=0; i<read_now; i++){
  135.                         buf[pos] = Wire.read();
  136. ……………………
  137. …………限于本文篇幅 余下代碼請從51黑下載附件…………
AMG8833 8831資料.rar (3.24 MB, 下載次數(shù): 54)
admin + 50 共享資料的黑幣獎勵!
ID:81138 發(fā)表于 2021-2-7 19:22 來自觸屏版 | 只看該作者
此資料不錯很有吸引力
ID:880257 發(fā)表于 2021-2-8 09:25 | 只看該作者
感興趣的領(lǐng)域,實用的源碼,多謝樓主!
ID:252225 發(fā)表于 2021-3-23 10:21 | 只看該作者
實用的源碼,多謝樓主!
