查看: 4301|回復(fù): 4
BMP180大氣壓力芯片51單片機(jī)程序
BMP180.rar (7.25 KB, 下載次數(shù): 99) 用的普中實(shí)驗(yàn)板,找個(gè)一個(gè)程序修改好,在開發(fā)板上測(cè)試可用。現(xiàn)在分享給新手參考,哈哈我自己也是個(gè)小白。在測(cè)試過程中時(shí)間久了偶爾顯示屏?xí)@示錯(cuò)誤不知道什么原因。另外本想用這個(gè)改成BMP280傳感器使用的,可是簡(jiǎn)單修改后數(shù)據(jù)不準(zhǔn)。
* BMP085模塊
* 用途:BMP085模塊IIC測(cè)試程序
#include<reg51.h>
#include"lcd.h"
//#include  <REG51.H>
#include  <math.h>    //Keil library
#include  <stdlib.h>  //Keil library
#include  <stdio.h>   //Keil library
#include  <INTRINS.H> //Keil library
#define   uchar unsigned char
#define   uint unsigned int
#define   DataPort P0        //P2 LCD1602數(shù)據(jù)端口
sbit        SCL=P2^1;      //IIC時(shí)鐘引腳定義
sbit        SDA=P2^0;      //IIC數(shù)據(jù)引腳定義
sbit    LCM_RS=P2^6;   //P0^2;LCD1602命令端口
sbit    LCM_RW=P2^5;   //P0^1;LCD1602命令端口
sbit    LCM_EN=P2^7;   //P0^0;LCD1602命令端口
#define        BMP085_SlaveAddress   0xEE          //定義器件在IIC總線中的從地址 BMP180=0xee,BMP280=0xec
#define OSS 0        // Oversampling Setting (note: code is not set up to use other OSS values)
typedef unsigned char  BYTE;
typedef unsigned short WORD;
uchar ge,shi,bai,qian,wan,shiwan;           //顯示變量
int  dis_data;                              //變量
short ac1;
short ac2;
short ac3;
unsigned short ac4;
unsigned short ac5;
unsigned short ac6;
short b1;
short b2;
short mb;
short mc;
short md;
void delay(unsigned int k);
void InitLcd();                            //初始化lcd1602
void WriteDataLCM(uchar dataW);
void WriteCommandLCM(uchar CMD,uchar Attribc);
void DisplayOneChar(uchar X,uchar Y,uchar DData);
void conversion(long temp_data);
void  Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data);   //單個(gè)寫入數(shù)據(jù)
uchar Single_Read(uchar REG_Address);                                      //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
void  Multiple_Read(uchar,uchar);                                          //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
void Delay5us();
void Delay5ms();
void BMP085_Start();
void BMP085_Stop();
void BMP085_SendACK(bit ack);
bit  BMP085_RecvACK();
void BMP085_SendByte(BYTE dat);
BYTE BMP085_RecvByte();
void BMP085_ReadPage();
void BMP085_WritePage();
    shiwan=temp_data/100000+0x30 ;
    temp_data=temp_data%100000;   //取余運(yùn)算
    wan=temp_data/10000+0x30 ;
    temp_data=temp_data%10000;   //取余運(yùn)算
        qian=temp_data/1000+0x30 ;
    temp_data=temp_data%1000;    //取余運(yùn)算
    bai=temp_data/100+0x30   ;
    temp_data=temp_data%100;     //取余運(yùn)算
    shi=temp_data/10+0x30    ;
    temp_data=temp_data%10;      //取余運(yùn)算
    ge=temp_data+0x30;
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<121;j++)
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;LCM_RW=1;_nop_();
LCM_EN=1;_nop_();_nop_();
while(DataPort&0x80);
LCM_EN=0;
if(Attribc)WaitForEnable();
LCM_RS=0;LCM_RW=0;_nop_();
DataPort=CMD;_nop_();
LCM_EN=1;_nop_();_nop_();LCM_EN=0;
WaitForEnable();
LCM_RS=1;LCM_RW=0;_nop_();
DataPort=dataW;_nop_();
void InitLcd()
WriteCommandLCM(0x38,1);
WriteCommandLCM(0x08,1);
WriteCommandLCM(0x01,1);
WriteCommandLCM(0x06,1);
WriteCommandLCM(0x0c,1);
Y&=1;
X&=15;
if(Y)X|=0x40;
X|=0x80;
WriteCommandLCM(X,0);
WriteDataLCM(DData);
延時(shí)5微秒(STC90C52RC@12M)
不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過快時(shí)需要修改
當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
void Delay5us()
    _nop_();_nop_();_nop_();_nop_();
延時(shí)5毫秒(STC90C52RC@12M)
void Delay5ms()
    WORD n = 560;
    while (n--);
起始信號(hào)
void BMP085_Start()
    SDA = 1;                    //拉高數(shù)據(jù)線
    SCL = 1;                    //拉高時(shí)鐘線
    Delay5us();                 //延時(shí)
    SDA = 0;                    //產(chǎn)生下降沿
    SCL = 0;                    //拉低時(shí)鐘線
停止信號(hào)
void BMP085_Stop()
    SDA = 0;                    //拉低數(shù)據(jù)線
    SDA = 1;                    //產(chǎn)生上升沿
發(fā)送應(yīng)答信號(hào)
入口參數(shù):ack (0:ACK 1:NAK)
    SDA = ack;                  //寫應(yīng)答信號(hào)
接收應(yīng)答信號(hào)
    CY = SDA;                   //讀應(yīng)答信號(hào)
    return CY;
向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
    BYTE i;
    for (i=0; i<8; i++)         //8位計(jì)數(shù)器
        dat <<= 1;              //移出數(shù)據(jù)的最高位
        SDA = CY;               //送數(shù)據(jù)口
    BMP085_RecvACK();
從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
    BYTE i;
    BYTE dat = 0;
    SDA = 1;                    //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
        dat <<= 1;
        dat |= SDA;             //讀數(shù)據(jù)
    return dat;
//單字節(jié)寫入BMP085內(nèi)部數(shù)據(jù)*******************************
    BMP085_Start();                  //起始信號(hào)
    BMP085_SendByte(SlaveAddress);   //發(fā)送設(shè)備地址+寫信號(hào)
    BMP085_SendByte(REG_Address);    //內(nèi)部寄存器地址
    BMP085_SendByte(REG_data);       //內(nèi)部寄存器數(shù)據(jù)
    BMP085_Stop();                   //發(fā)送停止信號(hào)
//單字節(jié)讀取BMP085內(nèi)部數(shù)據(jù)********************************
{  uchar REG_data;
    BMP085_SendByte(BMP085_SlaveAddress);           //發(fā)送設(shè)備地址+寫信號(hào)
    BMP085_SendByte(REG_Address);            //發(fā)送存儲(chǔ)單元地址
    BMP085_SendByte(BMP085_SlaveAddress+1);         //發(fā)送設(shè)備地址+讀信號(hào)
    REG_data=BMP085_RecvByte();              //讀出寄存器數(shù)據(jù)
        BMP085_SendACK(1);
        BMP085_Stop();                           //停止信號(hào)
    return REG_data;
//讀出BMP085內(nèi)部數(shù)據(jù),連續(xù)兩個(gè)
short Multiple_read(uchar ST_Address)
        uchar msb, lsb;
        short _data;
    BMP085_SendByte(ST_Address);             //發(fā)送存儲(chǔ)單元地址
    msb = BMP085_RecvByte();                 //BUF[0]存儲(chǔ)
    BMP085_SendACK(0);                       //回應(yīng)ACK
    lsb = BMP085_RecvByte();
        BMP085_SendACK(1);                       //最后一個(gè)數(shù)據(jù)需要回NOACK
    Delay5ms();
    _data = msb << 8;
        _data |= lsb;
        return _data;
long bmp085ReadTemp(void)
    BMP085_SendByte(0xF4);                  // write register address
        BMP085_SendByte(0x2E);               // write register data for temp 180:0x2E 280:0x22
        delay(10);        // max time is 4.5ms
        return (long) Multiple_read(0xF6); // 180=0xF6 280=0xFa
long bmp085ReadPressure(void)
        long pressure = 0;
    BMP085_SendByte(0x34);                 // write register data for pressure 180=0x34 280=0x22
        pressure = Multiple_read(0xF6);   // 180=0xF6 280=0xF9
        pressure &= 0x0000FFFF;
        return pressure;
        //return (long) bmp085ReadShort(0xF6);
//初始化BMP085,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改**************
void Init_BMP085()
        ac1 = Multiple_read(0xAA);
        ac2 = Multiple_read(0xAC);
        ac3 = Multiple_read(0xAE);
        ac4 = Multiple_read(0xB0);
        ac5 = Multiple_read(0xB2);
        ac6 = Multiple_read(0xB4);
        b1 =  Multiple_read(0xB6);
        b2 =  Multiple_read(0xB8);
        mb =  Multiple_read(0xBA);
        mc =  Multiple_read(0xBC);
        md =  Multiple_read(0xBE);
void bmp085Convert()
        long ut;
        long up;
        long x1, x2, b5, b6, x3, b3, p;
        unsigned long b4, b7;
        long  temperature;
        long  pressure;
        ut = bmp085ReadTemp();
        ut = bmp085ReadTemp();           // 讀取溫度
        up = bmp085ReadPressure();
        up = bmp085ReadPressure();  // 讀取壓強(qiáng)
        x1 = ((long)ut - ac6) * ac5 >> 15;
        x2 = ((long) mc << 11) / (x1 + md);
        b5 = x1 + x2;
         temperature = (b5 + 8) >> 4;
         conversion(temperature);
         DisplayOneChar(3,0,'T');       //溫度顯示
     DisplayOneChar(4,0,':');
     DisplayOneChar(6,0,bai);
     DisplayOneChar(7,0,shi);
     DisplayOneChar(8,0,'.');
         DisplayOneChar(9,0,ge);
         DisplayOneChar(10,0,0XDF);     //溫度單位
         DisplayOneChar(11,0,'C');
        b6 = b5 - 4000;
        x1 = (b2 * (b6 * b6 >> 12)) >> 11;
        x2 = ac2 * b6 >> 11;
        x3 = x1 + x2;
        b3 = (((long)ac1 * 4 + x3) + 2)/4;
        x1 = ac3 * b6 >> 13;
        x2 = (b1 * (b6 * b6 >> 12)) >> 16;
        x3 = ((x1 + x2) + 2) >> 2;
        b4 = (ac4 * (unsigned long) (x3 + 32768)) >> 15;
        b7 = ((unsigned long) up - b3) * (50000 >> OSS);
        if( b7 < 0x80000000)
             p = (b7 * 2) / b4 ;
                    p = (b7 / b4) * 2;
        x1 = (p >> 8) * (p >> 8);
        x1 = (x1 * 3038) >> 16;
        x2 = (-7357 * p) >> 16;
         pressure = p + ((x1 + x2 + 3791) >> 4);
         conversion(pressure);
     DisplayOneChar(3,1,'P');    //顯示壓強(qiáng)
     DisplayOneChar(4,1,':');
         DisplayOneChar(5,1,shiwan);
         DisplayOneChar(6,1,wan);
     DisplayOneChar(7,1,qian);
     DisplayOneChar(8,1,'.');
     DisplayOneChar(9,1,bai);
     DisplayOneChar(10,1,shi);
         DisplayOneChar(11,1,'K');   //氣壓?jiǎn)挝?br />          DisplayOneChar(12,1,'p');
         DisplayOneChar(13,1,'a');
//******主程序********
    delay(50);                           //上電延時(shí)
    InitLcd();                     //液晶初始化
    Init_BMP085();                //初始化BMP085
  while(1)                         //循環(huán)
    bmp085Convert();
        delay(1000);
/*********************LCD.C******開始*******************************/
/*********************LCD.h******開始*******************************/
#include"lcd.h"
* 函 數(shù) 名         : Lcd1602_Delay1ms
* 函數(shù)功能                   : 延時(shí)函數(shù),延時(shí)1ms
* 輸    入         : c
* 輸    出         : 無
* 說    名         : 該函數(shù)是在12MHZ晶振下,12分頻單片機(jī)的延時(shí)。
void Lcd1602_Delay1ms(uint c)   //誤差 0us
    uchar a,b;
        for (; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
* 函 數(shù) 名         : LcdWriteCom
* 函數(shù)功能                   : 向LCD寫入一個(gè)字節(jié)的命令
* 輸    入         : com
* 輸    出         : 無
#ifndef         LCD1602_4PINS         //當(dāng)沒有定義這個(gè)LCD1602_4PINS時(shí)
void LcdWriteCom(uchar com)          //寫入命令
        LCD1602_E = 0;     //使能
        LCD1602_RS = 0;           //選擇發(fā)送命令
        LCD1602_RW = 0;           //選擇寫入
        LCD1602_DATAPINS = com;     //放入命令
        Lcd1602_Delay1ms(1);                //等待數(shù)據(jù)穩(wěn)定
        LCD1602_E = 1;                  //寫入時(shí)序
        Lcd1602_Delay1ms(5);          //保持時(shí)間
        LCD1602_E = 0;
#else
        LCD1602_E = 0;         //使能清零
        LCD1602_RS = 0;         //選擇寫入命令
        LCD1602_DATAPINS = com;        //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
        LCD1602_E = 0;
//        Lcd1602_Delay1ms(1);
        LCD1602_DATAPINS = com << 4; //發(fā)送低四位
        LCD1602_E = 0;
#endif
* 函 數(shù) 名         : LcdWriteData
* 函數(shù)功能                   : 向LCD寫入一個(gè)字節(jié)的數(shù)據(jù)
* 輸    入         : dat
* 輸    出         : 無
void LcdWriteData(uchar dat)                        //寫入數(shù)據(jù)
        LCD1602_RS = 1;        //選擇輸入數(shù)據(jù)
        LCD1602_DATAPINS = dat; //寫入數(shù)據(jù)
        LCD1602_E = 0;
#else
        LCD1602_RS = 1;          //選擇寫入數(shù)據(jù)
        LCD1602_DATAPINS = dat;        //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
        LCD1602_E = 0;
        LCD1602_DATAPINS = dat << 4; //寫入低四位
        LCD1602_E = 0;
#endif
* 函 數(shù) 名       : LcdInit()
* 函數(shù)功能                 : 初始化LCD屏
* 輸    入       : 無
* 輸    出       : 無
void LcdInit()                                                  //LCD初始化子程序
        LcdWriteCom(0x38);  //開顯示
        LcdWriteCom(0x0c);  //開顯示不顯示光標(biāo)
        LcdWriteCom(0x06);  //寫一個(gè)指針加1
        LcdWriteCom(0x01);  //清屏
        LcdWriteCom(0x80);  //設(shè)置數(shù)據(jù)指針起點(diǎn)
#else
        LcdWriteCom(0x32);         //將8位總線轉(zhuǎn)為4位總線
        LcdWriteCom(0x28);         //在四位線下的初始化
#endif
/*********************LCD.C******結(jié)束*******************************/
#ifndef __LCD_H_
#define __LCD_H_
當(dāng)使用的是4位數(shù)據(jù)傳輸?shù)臅r(shí)候定義,
使用8位取消這個(gè)定義
//#define LCD1602_4PINS
包含頭文件
#include<reg51.h>
//---重定義關(guān)鍵詞---//
#ifndef uchar
#endif
#ifndef uint
#endif
PIN口定義
#define LCD1602_DATAPINS P0
sbit LCD1602_E=P2^7;
sbit LCD1602_RW=P2^5;
sbit LCD1602_RS=P2^6;
函數(shù)聲明
/*在51單片機(jī)12MHZ時(shí)鐘下的延時(shí)函數(shù)*/
void Lcd1602_Delay1ms(uint c);   //誤差 0us
/*LCD1602寫入8位命令子函數(shù)*/
void LcdWriteCom(uchar com);
/*LCD1602寫入8位數(shù)據(jù)子函數(shù)*/
void LcdWriteData(uchar dat)        ;
/*LCD1602初始化子程序*/
void LcdInit();
#endif
/*********************LCD.h******結(jié)束*******************************/
收藏收藏3 分享淘帖 頂 踩
ID:705277 發(fā)表于 2020-3-15 09:34 | 只看該作者
樓主,可以互相留個(gè)聯(lián)系方式嗎?我最近也在做這個(gè),我是純小白  陷入了困境。
ID:214276 發(fā)表于 2020-3-16 01:12 | 只看該作者
幻想就youth 發(fā)表于 2020-3-15 09:34
我自己現(xiàn)在編個(gè)定時(shí)程序都搞不定,小白的很,你有什么問題估計(jì)我也幫不上什么忙呀。
ID:975054 發(fā)表于 2021-11-21 22:30 | 只看該作者
剛搞清楚,我用的是STC8 硬件I2C+BMP280方案,暫時(shí)只需要?dú)鈮鹤x數(shù)。不知道你們具體用的什么MCU? 軟硬件I2C又不同,具體細(xì)節(jié)太多。。。。
testBMP280ID:
bmp280 id is right...
0101 1000
temp                    press
0000 0000 0000 0001 1000 1011 1000 1111
ID:975054 發(fā)表于 2021-11-21 22:36 | 只看該作者
不喜歡用【Arduino】了,那么多驅(qū)動(dòng)模塊搭積木。喜歡直接在最簡(jiǎn)小核心板上試驗(yàn)
