查看: 2949|回復(fù): 0
51單片機(jī)智能五位隨機(jī)數(shù)中獎抽獎程序設(shè)計(jì) Proteus仿真
ID:346434 發(fā)表于 2020-3-11 20:34 | 顯示全部樓層 |閱讀模式
#include <AT89X52.h>
#include <intrins.h>
#include <stdlib.h>
#define TRUE  1
#define FALSE 0
bit  bT0Flg = FALSE;
//U2 595的驅(qū)動引腳定義
sbit sbSHCP2 = P2^0;
sbit sbDS2 = P2^1;
sbit sbSTCP2 = P2^2;
//U3 595的驅(qū)動引腳定義
sbit sbSHCP3 = P2^3;
sbit sbDS3 = P2^4;
sbit sbSTCP3 = P2^5;
//U4 595的驅(qū)動引腳定義
sbit sbSHCP4 = P2^6;
sbit sbDS4 = P2^7;
sbit sbSTCP4 = P3^0;
//U5 595的驅(qū)動引腳定義
sbit sbSHCP5 = P3^1;
sbit sbDS5 = P3^3;
sbit sbSTCP5 = P3^4;
//U6 595的驅(qū)動引腳定義
sbit sbSHCP6 = P3^5;
sbit sbDS6 = P3^6;
sbit sbSTCP6 = P3^7;
unsigned char temp2,temp3,temp4,temp5,temp6;
bdata unsigned char sw;    //位定義
sbit sw0 = sw ^ 0;
sbit sw1 = sw ^ 1;
sbit sw2 = sw ^ 2;
sbit sw3 = sw ^ 3;
sbit sw4 = sw ^ 4;
sbit sw5 = sw ^ 5;
sbit sw6 = sw ^ 6;
sbit sw7 = sw ^ 7;
unsigned char code SEGtable[]=
  0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
void Delay(unsigned int x)
  unsigned char i;
while(x--)
   for(i=0;i<120;i++);
//595輸入函數(shù)2號
void Input5952()
  unsigned char i;
for(i=0;i<8;i++)
   temp2 <<= 1;
  sbDS2   = CY;
  sbSHCP2 = 1;
  _nop_();
  _nop_();
  sbSHCP2 = 0;
//595輸出函數(shù)2號
void Output5952()
  sbSTCP2 = 0;
_nop_();
sbSTCP2 = 1;
_nop_();
sbSTCP2 = 0;
//595輸入函數(shù)3號
void Input5953()
  unsigned char i;
for(i=0;i<8;i++)
   temp3 <<= 1;
  sbDS3   = CY;
  sbSHCP3 = 1;
  _nop_();
  _nop_();
  sbSHCP3 = 0;
//595輸出函數(shù)3號
void Output5953()
  sbSTCP3 = 0;
_nop_();
sbSTCP3 = 1;
_nop_();
sbSTCP3 = 0;
//595輸入函數(shù)4號
void Input5954()
  unsigned char i;
for(i=0;i<8;i++)
   temp4 <<= 1;
  sbDS4   = CY;
  sbSHCP4 = 1;
  _nop_();
  _nop_();
  sbSHCP4 = 0;
//595輸出函數(shù)4號
void Output5954()
  sbSTCP4 = 0;
_nop_();
sbSTCP4 = 1;
_nop_();
sbSTCP4 = 0;
//595輸入函數(shù)5號
void Input5955()
  unsigned char i;
for(i=0;i<8;i++)
   temp5 <<= 1;
  sbDS5   = CY;
  sbSHCP5 = 1;
  _nop_();
  _nop_();
  sbSHCP5 = 0;
//595輸出函數(shù)5號
void Output5955()
  sbSTCP5 = 0;
_nop_();
sbSTCP5 = 1;
_nop_();
sbSTCP5 = 0;
//595輸入函數(shù)6號
void Input5956()
  unsigned char i;
for(i=0;i<8;i++)
   temp6 <<= 1;
  sbDS6   = CY;
  sbSHCP6 = 1;
  _nop_();
  _nop_();
  sbSHCP6 = 0;
//595輸出函數(shù)6號
void Output5956()
  sbSTCP6 = 0;
_nop_();
sbSTCP6 = 1;
_nop_();
sbSTCP6 = 0;
void initrand(void)
    unsigned char counter=0;
    P1 = 0xff;
    sw = P1;
    counter = 0;  //統(tǒng)計(jì)開關(guān)閉合的數(shù)碼
    if(sw0 == 1)
       counter++;
    if(sw1 == 1)
       counter++;
...................................................................余下代碼仿真圖壓縮包自下
全部資料51hei下載地址:
電子抽獎系統(tǒng).rar (83.16 KB, 下載次數(shù): 25)
