查看: 2342|回復(fù): 5
單片機(jī)+MCP3201+oled12864(iic)顯示 測量電壓表源程序
ID:337109 發(fā)表于 2020-3-14 01:44 | 顯示全部樓層 |閱讀模式
效果如下圖
#include <reg52.h>
#define high 1
#define low 0
//oled引腳定義
sbit SCL = P3^5;
sbit SDA = P3^6;
void Initial_LY096BG30();
void fill_picture(unsigned char fill_Data);
void Picture_1();
void IIC_Start();
void IIC_Stop();
void Write_IIC_Command(unsigned char IIC_Command);
void Write_IIC_Data(unsigned char IIC_Data);
void Write_IIC_Byte(unsigned char IIC_Byte);
/***********************Initial code*********************/
        Write_IIC_Command(0xAE);   //display off
        Write_IIC_Command(0x20);        //Set Memory Addressing Mode
        Write_IIC_Command(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        Write_IIC_Command(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        Write_IIC_Command(0xc8);        //Set COM Output Scan Direction
        Write_IIC_Command(0x02);//---set low column address
        Write_IIC_Command(0x10);//---set high column address
        Write_IIC_Command(0x40);//--set start line address
        Write_IIC_Command(0x81);//--set contrast control register
        Write_IIC_Command(0x7f);
        Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
        Write_IIC_Command(0xa6);//--set normal display
        Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
        Write_IIC_Command(0x3F);//
        Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        Write_IIC_Command(0xd3);//-set display offset
        Write_IIC_Command(0x00);//-not offset
        Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
        Write_IIC_Command(0xf0);//--set divide ratio
        Write_IIC_Command(0xd9);//--set pre-charge period
        Write_IIC_Command(0x22); //
        Write_IIC_Command(0xda);//--set com pins hardware configuration
        Write_IIC_Command(0x12);
        Write_IIC_Command(0xdb);//--set vcomh
        Write_IIC_Command(0x20);//0x20,0.77xVcc
        Write_IIC_Command(0x8d);//--set DC-DC enable
        Write_IIC_Command(0x14);//
        Write_IIC_Command(0xaf);//--turn on oled panel
/***********************Picture Code**************************/
unsigned char code show1[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x90,0x52,0x34,0x10,0xFF,0x10,0x34,0x52,0x80,0x70,0x8F,0x08,0x08,0xF8,0x08,0x00,
0x82,0x9A,0x56,0x63,0x22,0x52,0x8E,0x00,0x80,0x40,0x33,0x0C,0x33,0x40,0x80,0x00,/*"數(shù)",0*/
0x10,0x0C,0x04,0x24,0x24,0x24,0x25,0x26,0xA4,0x64,0x24,0x04,0x04,0x14,0x0C,0x00,
0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,/*"字",1*/
0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,
0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00,/*"電",2*/
0x00,0x00,0xFE,0x02,0x82,0x82,0x82,0x82,0xFA,0x82,0x82,0x82,0x82,0x82,0x02,0x00,
0x80,0x60,0x1F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x44,0x58,0x40,0x40,0x00,/*"壓",3*/
0x00,0x04,0x24,0x24,0x24,0x24,0x24,0xFF,0x24,0x24,0x24,0x24,0x24,0x04,0x00,0x00,
0x21,0x21,0x11,0x09,0xFD,0x83,0x41,0x23,0x05,0x09,0x11,0x29,0x25,0x41,0x41,0x00,/*"表",4*/
0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,/*"Y",0*/
0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,/*"S",1*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"5",0*/
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,/*"1",2*/
0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0",3*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,/*" ",4*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"1",5*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"5",6*/
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",7*/
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,/*"2",8*/
0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,/*" ",10*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,/*"2",11*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"5",12*/
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",13*/
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,/*"3",14*/
0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0",15*/
0x00,0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,
0x00,0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,/*"電"*/
0x00,0x00,0x00,0xFE,0x02,0x82,0x82,0x82,0x82,0xFA,0x82,0x82,0x82,0x82,0x82,0x02,
0x00,0x80,0x60,0x1F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x44,0x58,0x40,0x40,/*"壓"*/
0x00,0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*":"*/
0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"V"*/
0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x40,0x42,0x44,0x58,0x40,0x40,0x7F,0x40,0x40,0x50,0x48,0xC6,0x00,0x00,0x00,
0x00,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,0x00,/*"當(dāng)",0*/
0x08,0x08,0xE8,0x29,0x2E,0x28,0xE8,0x08,0x08,0xC8,0x0C,0x0B,0xE8,0x08,0x08,0x00,
0x00,0x00,0xFF,0x09,0x49,0x89,0x7F,0x00,0x00,0x0F,0x40,0x80,0x7F,0x00,0x00,0x00,/*"前",1*/
0x10,0x10,0xD0,0xFF,0x90,0x10,0x40,0x42,0x5C,0x40,0x7F,0x40,0x50,0xCE,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x01,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,/*"檔",2*/
0x00,0x80,0x60,0xF8,0x07,0x10,0x90,0x10,0x11,0x16,0x10,0x10,0xD0,0x10,0x00,0x00,
0x01,0x00,0x00,0xFF,0x40,0x40,0x41,0x5E,0x40,0x40,0x70,0x4E,0x41,0x40,0x40,0x00,/*"位",3*/
0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*":",4*/
0x04,0x03,0x00,0xFF,0x00,0x01,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,/*"檔",7*/
unsigned char code show2[]=
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0"*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"1"*/
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,/*"2"*/
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,/*"3"*/
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,/*"4"*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,/*"5"*/
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,/*"6"*/
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,/*"7"*/
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,/*"8"*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,/*"9"*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,/*"."*/
//IIC Start
void IIC_Start()
   SCL = high;
   SDA = high;
   SDA = low;
   SCL = low;
//IIC Stop
void IIC_Stop()
   SCL = low;
   SDA = low;
   SCL = high;
   SDA = high;
// IIC Write byte
        unsigned char i;
        for(i=0;i<8;i++)
                if(IIC_Byte & 0x80)                //1?0?
                SDA=high;
                SDA=low;
                SCL=high;
                SCL=low;
                IIC_Byte<<=1;                        //loop
        SDA=1;
        SCL=1;
        SCL=0;
// IIC Write Command
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
   Write_IIC_Byte(0x00);                        //write command
   Write_IIC_Byte(IIC_Command);
   IIC_Stop();
// IIC Write Data
   IIC_Start();
   Write_IIC_Byte(0x40);                        //write data
   Write_IIC_Byte(IIC_Data);
   IIC_Stop();
// fill_Picture
        unsigned char m,n;
        for(m=0;m<8;m++)
                Write_IIC_Command(0xb0+m);                //page0-page1
                Write_IIC_Command(0x00);                //low column start address
                Write_IIC_Command(0x10);                //high column start address
                for(n=0;n<130;n++)
                                Write_IIC_Data(fill_Data);
// picture
void picture_1()
        unsigned char x,y,z,k;
        unsigned int i=0;
        for(k=0;k<4;k++)
                for(z=0;z<8;z++)
                        for(y=2*k;y<2*(k+1);y++)
                                Write_IIC_Command(0xb0+y);
                                Write_IIC_Command(0x10+z);
                                for(x=0;x<16;x++)
                                        Write_IIC_Data(show1[i++]);
void xssz(int k,int z,int sz)          //k=行; z=個;
  unsigned char x,y;
  unsigned int i=sz*16;
      for(x=0;x<8;x++)
          Write_IIC_Data(show2[i++]);
ID:337109 發(fā)表于 2020-3-14 01:47 | 顯示全部樓層
定時喂食   沒用
ID:328014 發(fā)表于 2020-3-16 00:47 | 顯示全部樓層
好東東,樓主能分享下仿真工程嗎?
ID:467922 發(fā)表于 2020-3-16 09:43 | 顯示全部樓層
好代碼,有電路圖嗎
ID:337109 發(fā)表于 2020-9-9 08:58 | 顯示全部樓層
另外發(fā)了一個帖子,里面有程序和仿真電路   全都是源文件直接可以使用
ID:337109 發(fā)表于 2020-9-9 08:59 | 顯示全部樓層
51hei團(tuán)團(tuán) 發(fā)表于 2020-3-16 00:47
好東東,樓主能分享下仿真工程嗎?
看另一個帖子   重新發(fā)的   里面有
