查看: 5048|回復: 3
RGB stm32單片機ws2812 PWM+DMA LED控制程序
ID:710273 發(fā)表于 2020-3-17 17:41 | 顯示全部樓層 |閱讀模式
RGB stm32單片機ws2812LED控制,使用的是硬件驅(qū)動PWM + DMA
單片機源程序如下:
  1. #include "ws2812b.h"
  2. #include "stdlib.h"
  3. #include "delay.h"
  4. void WS2812_Send(uint8_t (*color)[3], uint16_t len)
  5. {
  6.         uint8_t i;
  7.         uint16_t memaddr;
  8.         uint16_t buffersize;
  9.         buffersize = (len*24)+43;        // number of bytes needed is #LEDs * 24 bytes + 42 trailing bytes
  10.         memaddr = 0;                                // reset buffer memory index
  11.         while (len)
  12.         {
  13.
  14.                 for(i=0; i<8; i++) // RED
  15.                 {
  16.                         LED_BYTE_Buffer[memaddr] = ((color[len-1][1]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  17.                         memaddr++;
  18.                 }
  19.
  20.                 for(i=0; i<8; i++) // GREEN data
  21.                 {
  22.                         LED_BYTE_Buffer[memaddr] = ((color[len-1][0]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  23.                         memaddr++;
  24.                 }
  25.
  26.                 for(i=0; i<8; i++) // BLUE
  27.                 {
  28.                         LED_BYTE_Buffer[memaddr] = ((color[len-1][2]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
  29.                         memaddr++;
  30.                 }
  31.                 len--;
  32.         }
  33. //===================================================================//
  34. //bug:最后一個周期波形是高電平,故增加一個低電平的波形
  35.                 LED_BYTE_Buffer[memaddr] = 0;
  36. //===================================================================//
  37.           memaddr++;
  38.                 while(memaddr < buffersize)
  39.                 {
  40.                         LED_BYTE_Buffer[memaddr] = 0;
  41.                         memaddr++;
  42.                 }
  43.                 DMA_SetCurrDataCounter(DMA1_Channel7, buffersize);         // load number of bytes to be transferred
  44.                 DMA_Cmd(DMA1_Channel7, ENABLE);                         // enable DMA channel 7
  45.                 TIM_Cmd(TIM2, ENABLE);                                                 // enable Timer 2
  46.                 while(!DMA_GetFlagStatus(DMA1_FLAG_TC7)) ;         // wait until transfer complete
  47.                 DMA_Cmd(DMA1_Channel7, DISABLE);                         // disable DMA channel 7
  48.                 DMA_ClearFlag(DMA1_FLAG_TC7);                                 // clear DMA1 Channel 7 transfer complete flag
  49.                 TIM_Cmd(TIM2, DISABLE);         // disable Timer 2
  50. }
  51. void WS2812_Random()        //隨機閃燈
  52. {
  53.                 uint8_t rgb0[1][3];
  54.           rgb0[0][0] = rand()%256;
  55.                 rgb0[0][1] = rand()%256;
  56.                 rgb0[0][2] = rand()%256;
  57.                 WS2812_Send(&rgb0[0],1);
  58.                 delay_s(1);
  59. }
  60. void WS2812_Red_BLN()        //紅色呼吸燈
  61. {
  62.         u16 i;
  63.         uint8_t rgb0[256][3] ={0,0,0};
  64.         for(i=0;i<=255;i++)
  65.         {
  66.                 rgb0[i][0] = i;
  67.         }
  68.         for(i=0;i<=255;i++)
  69.         {
  70.                 WS2812_Send(&rgb0[i],1);
  71.                 delay_ms(5);
  72.         }
  73.         for(i=0;i<=255;i++)
  74.         {
  75.                 rgb0[i][0] = (255 - i);
  76.         }
  77.         for(i=0;i<=255;i++)
  78.         {
  79.                 WS2812_Send(&rgb0[i],1);
  80.                 delay_ms(5);
  81.         }
  82.         delay_ms(500);
  83.
  84. }
  85. void WS2812_Green_BLN()        //綠色呼吸燈
  86. {
  87.         u16 i;
  88.         uint8_t rgb0[256][3] ={0,0,0};
  89.         for(i=0;i<=255;i++)
  90.         {
  91.                 rgb0[i][1] = i;
  92.         }
  93.         for(i=0;i<=255;i++)
  94.         {
  95.                 WS2812_Send(&rgb0[i],1);
  96.                 delay_ms(5);
  97.         }
  98.         for(i=0;i<=255;i++)
  99.         {
  100.                 rgb0[i][1] = (255 - i);
  101.         }
  102.         for(i=0;i<=255;i++)
  103.         {
  104.                 WS2812_Send(&rgb0[i],1);
  105.                 delay_ms(5);
  106.         }
  107.         delay_ms(500);
  108. }
  109. void WS2812_Blue_BLN()        //藍色呼吸燈
  110. {
  111.         u16 i;
  112.         uint8_t rgb0[256][3] ={0,0,0};
  113.         for(i=0;i<=255;i++)
  114.         {
  115.                 rgb0[i][2] = i;
  116. ……………………
  117. …………限于本文篇幅 余下代碼請從51黑下載附件…………
復制代碼
WS2812B(PWM+DMA).7z (185.22 KB, 下載次數(shù): 211)
admin + 50 共享資料的黑幣獎勵!
ID:807323 發(fā)表于 2021-10-13 19:25 | 顯示全部樓層
單個燈的
ID:311400 發(fā)表于 2021-7-29 10:32 | 顯示全部樓層
這里的問號是什么意思?
ID:578423 發(fā)表于 2020-5-3 17:51 | 顯示全部樓層
STC能用?
