三個IO口驅(qū)動兩片74LS165,拓展為16位按鍵。附件包括Proteus仿真文件及源程序。
2020-3-18 14:03 上傳
- #include <reg52.h>
- #define uint16 unsigned int
- #define uint8 unsigned char
- sbit HC165_nPL = P3 ^ 5;
- sbit HC165_CK = P3 ^ 6;
- sbit HC165_OUT = P3 ^ 7;
- unsigned int HC165(void)
- unsigned char i;
- unsigned int Temp, Temp1, Temp2;
- HC165_CK = 1;
- HC165_nPL = 0; //HC165讀按鍵
- HC165_nPL = 1; //暫停HC165讀按鍵
- Temp1 = 0;
- if(HC165_OUT == 1)
- Temp1 |= 0x01;
- for(i = 0;i < 7;i++)
- HC165_CK = 0;
- HC165_CK = 1;
- Temp1 <<= 1;
- Temp1 |= 0x01;
- HC165_CK = 0;
- HC165_CK = 1;
- Temp2 = 0;
- Temp2 |= 0x01;
- HC165_CK = 0;
- HC165_CK = 1;
- Temp2 <<= 1;
- Temp2 |= 0x01;
- HC165_CK = 0;
- Temp = (Temp2 << 8) + Temp1;
- return(Temp);
- void main( )
- uint16 num;
- while(1)
- num = HC165( );
- switch(num)
- case 0xfffe: P1 = 0xfe; P2 = 0xff; break;
- case 0xfffd: P1 = 0xfd; P2 = 0xff; break;
- case 0xfffb: P1 = 0xfb; P2 = 0xff; break;
- case 0xfff7: P1 = 0xf7; P2 = 0xff; break;
- case 0xffef: P1 = 0xef; P2 = 0xff; break;
- case 0xffdf: P1 = 0xdf; P2 = 0xff; break;
- case 0xffbf: P1 = 0xbf; P2 = 0xff; break;
- case 0xff7f: P1 = 0x7f; P2 = 0xff; break;
- case 0xfeff: P1 = 0xff; P2 = 0xfe; break;
- case 0xfdff: P1 = 0xff; P2 = 0xfd; break;
- case 0xfbff: P1 = 0xff; P2 = 0xfb; break;
- case 0xf7ff: P1 = 0xff; P2 = 0xf7; break;
- case 0xefff: P1 = 0xff; P2 = 0xef; break;
- case 0xdfff: P1 = 0xff; P2 = 0xdf; break;
- case 0xbfff: P1 = 0xff; P2 = 0xbf; break;
- case 0x7fff: P1 = 0xff; P2 = 0x7f; break;
- default: break;
74LS165按鍵.zip
(82.88 KB, 下載次數(shù): 59)
2020-3-18 14:01 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
