查看: 3005|回復(fù): 0
ABOV單片機(jī)的四路按鍵中斷源程序
ID:285534 發(fā)表于 2020-3-21 10:10 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
這是好東西,請珍惜這等寶貝,絕對是惜世珍寶,ABOV單片機(jī)資料太少,如有有緣人,拿去(硬貨)//======================================================
// Used ABOV Semiconductor's code generator
// Device name : A31G111/112
#include "A31G11x_pcu.h"
#include "A31G11x_scucg.h"
#include "A31G11x_uartn.h"
#include "A31G11x_int.h"
#include "A31G11x_adc.h"
#include "debug_frmwrk.h"
// Main Clock Selection
//#define USED_HIRC
//#define USED_WDTRC
//#define USED_MOSC
//#define USED_SOSC
//Clock Out Selection ( Monitoring )
#define USED_CLKO
volatile uint32_t msec;
volatile uint32_t test;
void mainloop(void);
//uint32_t bo;
//uint32_t bi;
void delay (void)
        uint32_t i;
        for (i = 0; i < 0x100000; i++) ;
// PE0 port interrupt
void EXTINT0_Handler(void)
        uint32_t j;
        uint32_t status;
        status = EIntPE_GetIntStatus();
        if(status & (_BIT(0)))
                for (j= 0; j<5; j++)
                        GPIO_SetValue(PE, _BIT(5));
                        delay();
                        GPIO_ClearValue(PE, _BIT(5));
                        delay();
                EIntPE_ClearIntStatus(0xFF);
// PE1 port interrupt
void EXTINT1_Handler(void)
        uint32_t j;
        uint32_t status;
        if(status & (_BIT(1)))
                        delay();
                        delay();
// PE2 port interrupt
void EXTINT2_Handler(void)
        uint32_t j;
        uint32_t status;
        if(status & (_BIT(2)))
                        GPIO_SetValue(PE, _BIT(6));
                        delay();
                        GPIO_ClearValue(PE, _BIT(6));
                        delay();
// PE3 port interrupt
void EXTINT3_Handler(void)
        uint32_t j;
        uint32_t status;
        if(status & (_BIT(3)))
                        GPIO_SetValue(PE, _BIT(7));
                        delay();
                        GPIO_ClearValue(PE, _BIT(7));
                        delay();
    // Main
int main()
        init();                        // 初始化
  mainloop();//主程序
  return (0);
} //main
void mainloop(void)
//  uint32_t tmp=0x0;
//   AD_Init();         //AD管腳初始化
// Test Pin setting PE5
        PCU_SetDirection(PE, 5, PUSH_PULL_OUTPUT);
        PCU_ConfigurePullupdown(PE, 5, DISPUPD);
        // Test Pin setting PE6
        PCU_SetDirection(PE, 6, PUSH_PULL_OUTPUT);
        PCU_ConfigurePullupdown(PE, 6, DISPUPD);
        // Test Pin setting PE7
        PCU_SetDirection(PE, 7, PUSH_PULL_OUTPUT);
        PCU_ConfigurePullupdown(PE, 7, DISPUPD);
//        // external interrupt test pin PE0
        PCU_SetDirection(PE, 0, INPUT);
        PCU_ConfigurePullupdown(PE, 0, ENPU);
        PCU_SetDebounce(PE,0,HCLK_1024);
        // external interrupt test pin PE1
        PCU_SetDirection(PE, 1, INPUT);
        PCU_ConfigurePullupdown(PE, 1, ENPU);
        PCU_SetDebounce(PE,1,HCLK_1024);
//        // external interrupt test pin PE2
        PCU_SetDirection(PE, 2, INPUT);
        PCU_ConfigurePullupdown(PE, 2, ENPU);
        PCU_SetDebounce(PE,2,HCLK_1024);
        // external interrupt test pin PE3
        PCU_SetDirection(PE, 3, INPUT);
        PCU_ConfigurePullupdown(PE, 3, ENPU);
        PCU_SetDebounce(PE,3,HCLK_1024);
        EIntPx_SetReg(PORTE, 0, 0, 1); //使能GPIO中斷
        EIntPx_SetReg(PORTE, 1, 0, 1); //使能GPIO中斷
        EIntPx_SetReg(PORTE, 2, 0, 1); //使能GPIO中斷
        EIntPx_SetReg(PORTE, 3, 0, 1); //使能GPIO中斷
        EIntCfg(EINT0_SEL,PORTE,0);         //外部中斷配置
        EIntCfg(EINT1_SEL,PORTE,1);  //外部中斷配置
        EIntCfg(EINT2_SEL,PORTE,2);         //外部中斷配置
        EIntCfg(EINT3_SEL,PORTE,3);  //外部中斷配置
        NVIC_EnableIRQ(EXINT0_IRQn);  //使能外部中斷
        NVIC_EnableIRQ(EXINT1_IRQn);  //使能外部中斷
        NVIC_EnableIRQ(EXINT2_IRQn);  //使能外部中斷
        NVIC_EnableIRQ(EXINT3_IRQn);  //使能外部中斷
        EInt_MaskDisable(EXINT0_MASK|EXINT1_MASK|EXINT2_MASK|EXINT3_MASK); //中斷源掩碼配置
  while(1){
//     AD_scan();              //按鍵掃描
//     AD_Handle();                        //按鍵處理
//                for(tmp = 0; tmp < 1000000; tmp++);
                delay();
                GPIO_SetValue(PB, _BIT(0));
                delay();
                GPIO_ClearValue(PB, _BIT(0));
        }  //while
} //mainloop
全部資料51hei下載地址:
abov-四路按鍵中斷-.7z (219.92 KB, 下載次數(shù): 11)
admin + 50 共享資料的黑幣獎勵!
