- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "key.h"
- #include "beep.h"
- #include "w25qxx.h"
- #include "ff.h"
- #include "exfuns.h"
- #include "text.h"
- #include "2214.h"
- #include "myiic.h"
- #define count_t 35 //紙張上限
- u8 w=0,K;
- int main(void)
- delay_init(); //延時函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置中斷優(yōu)先級分組為組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
- uart_init(115200); //串口初始化為115200
- LED_Init(); //LED初始化
- KEY_Init(); //初始化按鍵
- LCD_Init(); //初始化LCD
- font_init(); //漢字初始化
- LCD_Clear(WHITE); //屏幕清空
- BEEP_Init(); //蜂鳴器初始化
- IIC_Init(); //IIC通訊
- InitMultiFDC2214(); //多通道設(shè)置
- POINT_COLOR=BLUE;
- Show_Str(120,30,240,24,"2019年 電子設(shè)計(jì)大賽",24,0);
- Show_Str(140,98,200,24,"紙張計(jì)數(shù)顯示裝置",24,0);
- POINT_COLOR=BLACK;
- LCD_DrawRectangle(20,70,460,150); //畫表格
- LCD_DrawRectangle(20,70,460,350);
- LCD_DrawRectangle(20,150,240,350);
- Show_Str(30,180,200,24,"通道1:",24,0);
- Show_Str(30,240,200,24,"通道2:",24,0);
- Show_Str(30,300,200,24,"當(dāng)前模式為:",24,0);
- Show_Str(250,180,200,24,"極板狀態(tài):",24,0);
- Show_Str(250,240,200,24,"紙張數(shù):",24,0);
- Show_Str(250,300,200,24,"總重:",24,0);
- POINT_COLOR=RED;
- LCD_ShowxNum(355,300,0,1,24,0); //默認(rèn)紙重
- Show_Str(170,300,200,24,"待機(jī)",24,0);
- Show_Str(90,380,300,24,"學(xué)習(xí)+檢測",24,0); //KEY0
- Show_Str(315,380,300,24,"紙重檢測",24,0); //KEY1
- Show_Str(90,430,300,24,"進(jìn)入學(xué)習(xí)",24,0); //KEY2
- Show_Str(315,430,300,24,"紙張規(guī)格",24,0); //KEY2
- POINT_COLOR=RED;
- Show_Str(30,380,300,24,"KEY0:",24,0); //學(xué)習(xí)模式
- Show_Str(250,380,300,24,"KEY1:",24,0); //重量檢測模式
- Show_Str(30,430,300,24,"KEY2:",24,0);
- Show_Str(250,430,300,24,"KEY3:",24,0);
- Show_Str(30,480,300,24,"紙張規(guī)格",24,0); //紙張規(guī)格
- Show_Str(30,530,300,24,"重量",24,0);
- Show_Str(30,580,300,24,"厚度",24,0);
- while(1)
- u8 key;
- FDC2214Check(); //檢測系統(tǒng)工作狀態(tài)
- just_test(); //顯示通道值
- delay_ms(10);
- key = KEY_Scan(0); //獲得鍵值
- if(key == KEY0_PRES) //進(jìn)入學(xué)習(xí)模式
- StudyMode();//學(xué)習(xí)模式
- K++;
- Show_Str(30,680,300,24,"K 按下次數(shù):",24,0);
- POINT_COLOR=RED;
- LCD_ShowxNum(170,680,K,1,24,0);
- /***********************學(xué)習(xí)模式***********************/
- u16 StudyMode()//獲取數(shù)據(jù),計(jì)算
- u8 keyd,Count;
- double Ch1,Ch2;
- int i,j; //獲取數(shù)據(jù),計(jì)算
- static double ab[4][count_t] /*分別對應(yīng)一通道左值右值二通道左值右值*/;
- long double sum1 = 0,sum2 = 0,a[2][count_t] = {0};
- double adf[2][(count_t-1)] /*對應(yīng)臨時差值*/;
- keyd=KEY_Scan(1);
- for(i = 0;i<count_t;)
- keyd=KEY_Scan(0);
- if(keyd==KEY0_PRES) //按鍵KEY0按下錄入數(shù)據(jù)
- K++;
- POINT_COLOR=RED;
- for(j=0;j<100;j++) //取平均值
- sum1= sum1+ReadRegfdc2214(0x02);//讀取的通道1的值
- sum2= sum2+ReadRegfdc2214(0x04);//讀取的通道2的值
- a[0][i]=sum1/100;
- a[1][i]=sum2/100;
- Show_Str(170,300,200,24,"學(xué)習(xí)",24,0);
- Show_Str(160,500,200,24,"正在學(xué)習(xí)",24,0);
- Show_Str(30,530,200,24,"學(xué)習(xí)次數(shù):",24,0);
- Show_Str(30,500,300,24,"學(xué)習(xí)狀態(tài):",24,0);
- POINT_COLOR=RED;
- LCD_ShowxNum(100,180,a[0][i],8,24,0); //通道一學(xué)習(xí)參數(shù)
- LCD_ShowxNum(100,240,a[1][i],8,24,0); //通道二學(xué)習(xí)參數(shù)
- LCD_ShowxNum(160,530,i+1,2,24,0); //學(xué)習(xí)次數(shù)
- sum1 = 0;
- sum2 = 0;
- i++;
- keyd = 0;
- delay_ms(1);
- for(i=1;i<count_t;i++)
- adf[0][i-1] = (a[0][i] - a[0][i-1])/2;
- adf[1][i-1] = (a[1][i] - a[1][i-1])/2;
- ab[0][0] = a[0][0] - adf[0][0];
- ab[2][0] = a[1][0] - adf[1][0];
- ab[0][i] = a[0][i] - adf[0][i-1];
- ab[1][i-1] = a[0][i-1]+adf[0][i-1];
- ab[2][i]=a[1][i]-adf[1][i-1];
- ab[3][i-1]=a[1][i-1]+adf[1][i-1];
- ab[1][count_t-1] = a[0][count_t-1]+adf[0][count_t-2];
- ab[3][count_t-1] = a[1][count_t-1]+adf[1][count_t-2];
- //上下限
- **********************************************分割線***************************************************************************
- Show_Str(150,500,300,24,"正在學(xué)習(xí)",24,0);
- while(1) //學(xué)習(xí)模式
- POINT_COLOR=RED;
- Show_Str(150,500,300,24,"已完成學(xué)習(xí)",24,0);
- keyd=KEY_Scan(0);
- if(keyd == KEY0_PRES) // 錄入數(shù)值
- K++;
- POINT_COLOR=RED;
- Ch2 = ReadRegfdc2214(0x04); //通道二
- Ch1 = ReadRegfdc2214(0x02); //通道一
- Count=0;
- if((Ch1<1873) || (Ch2<1792))Count=0; //零張
- for(i=0;i<count_t;i++)
- if(((ab[0][i]<Ch1)&&(Ch1<ab[1][i])) || ((ab[2][i]<Ch2)&&(Ch2<ab[3][i]))) //i張紙
- Count = i+1;
- break;
- LCD_ShowxNum(350,240,Count,4,24,0); //顯示被測紙張數(shù)
- delay_ms(500);
- BEEP=1; //發(fā)出蜂鳴聲
- LED0=0; //伴隨紅燈閃爍
- delay_ms(500);
- BEEP=0;
- LED0=1;
- if(keyd == KEY2_PRES) //按下KEY2進(jìn)行紙張標(biāo)準(zhǔn)重量調(diào)節(jié) 一共分為4擋
- u8 z;
- w++;
- if(w==5) w=0;
- z=Count*PaperWeight(w); //計(jì)算后的紙張重
- LCD_ShowxNum(355,300,z,5,24,0); //紙重
- LCD_ShowxNum(286,600,PaperWeight(w),3,24,0); //顯示規(guī)格
2019F紙張檢測程序.7z
(1.26 MB, 下載次數(shù): 42)
2020-3-24 17:59 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
