查看: 2316|回復: 0
藍橋杯單片機開發(fā)第8屆省賽-電子鐘
ID:656536 發(fā)表于 2020-3-24 18:40 | 顯示全部樓層 |閱讀模式
#include <stc15f2k60s2.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
sbit S5 = P3^2;
sbit S4 = P3^3;
unsigned char code LedChar[] = {
  0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
        0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
  0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char InitTime[7] = {
        0x50,0x59,0x23,0x07,0x03,0x06,0x20
unsigned char clock[7] = {
  0x00,0x00,0x00,0x07,0x03,0x06,0x20
unsigned char set_time[7] = {0,0,0,0,0,0,0};
unsigned int temp;
unsigned char time[7];
unsigned char mode_time = 0;    //設置時間標志位
unsigned char mode_clock = 0;  //設置鬧鐘標志位
unsigned char mode_SMG = 1;   // 1 顯示時間 2 設置時間 3 設置鬧鐘 4 顯示溫度
bit mode_T = 0;  //溫度顯示標志位
bit flag5s = 0;
bit share_Led = 0;
void InitSystem();
void Timer0Init(void);                //1毫秒@12.000MHz
void SMGWroking();
void ScanKeyS();
void InitDS1302();
void SetClock();
extern unsigned char Get18B20Temp();
extern bit Start18B20();
extern void DS1302SingWrite(unsigned char addr,unsigned char dat);
extern unsigned char DS1302ByteRead(unsigned char addr);
  InitSystem();
        Timer0Init();
        InitDS1302();
          SMGWroking();
                ScanKeyS();
                SetClock();
/******HC573選擇函數*******/
void Select74HC573(unsigned char channel)
  switch(channel)
          case 4:P2 = (P2&0x1F)|0x80;break;
                case 5:P2 = (P2&0x1F)|0xA0;break;
                case 6:P2 = (P2&0x1F)|0xC0;break;
                case 7:P2 = (P2&0x1F)|0xE0;break;
                default:P2 = (P2&0x1F)|0x00;break;
/*******關閉LED和蜂鳴器、繼電器******/
void InitSystem()
  Select74HC573(5);
        P0 = 0x00;
        Select74HC573(4);
        P0 = 0xFF;
        Select74HC573(0);
/*********DS1302********/
void DS1302SingRead()
  unsigned char i,addr = 0x81;
        DS1302SingWrite(0x8E,0x00);
        for(i=0;i<7;i++)
          time[i] = DS1302ByteRead(addr);
                addr = addr + 2;
        DS1302SingWrite(0x8E,0x80);
void InitDS1302()  //初始化時鐘芯片
  unsigned char i,addr = 0x80;
        for(i=0;i<7;i++)
          DS1302SingWrite(addr,InitTime[i]);
                addr = addr + 2;
/*******DS18B20*********/
void Config18B20()
  Start18B20();
        temp = Get18B20Temp();
/********數碼管********/
void SMGWroking()
  switch(mode_SMG)
                case 1:DS1302SingRead();  //顯示時間
                                         LedBuff[0] = LedChar[time[2]>>4];
                                         LedBuff[1] = LedChar[time[2]&0x0F];
                                   LedBuff[2] = LedChar[16];
                                         LedBuff[3] = LedChar[time[1]>>4];
                                         LedBuff[4] = LedChar[time[1]&0x0F];
                                         LedBuff[5] = LedChar[16];
                                         LedBuff[6] = LedChar[time[0]>>4];
                                         LedBuff[7] = LedChar[time[0]&0x0F];
           break;
                case 2:LedBuff[0] = LedChar[set_time[2]/10];  //設置時間
                                         LedBuff[1] = LedChar[set_time[2]%10];
                                         LedBuff[3] = LedChar[set_time[1]/10];
                                         LedBuff[4] = LedChar[set_time[1]%10];
                                         LedBuff[6] = LedChar[set_time[0]/10];
                                         LedBuff[7] = LedChar[set_time[0]%10];
                       break;
                case 3:LedBuff[0] = LedChar[clock[2]/10];
                                         LedBuff[1] = LedChar[clock[2]%10];
                                         LedBuff[3] = LedChar[clock[1]/10];
                                         LedBuff[4] = LedChar[clock[1]%10];
                                         LedBuff[6] = LedChar[clock[0]/10];
                                         LedBuff[7] = LedChar[clock[0]%10];
                                         break;
                case 4:Config18B20();    //顯示溫度
                                         LedBuff[0] = 0xFF;
                                         LedBuff[1] = 0xFF;
                                         LedBuff[2] = 0xFF;
                                         LedBuff[3] = 0xFF;
                                         LedBuff[4] = 0xFF;
                                         LedBuff[5] = LedChar[temp/10];
                                         LedBuff[6] = LedChar[temp%10];
                                         LedBuff[7] = LedChar[12];
                                         break;
/*****十進制轉BCD碼*****/
unsigned char NumToBCD(unsigned char num)
  unsigned char low,high,bcd;
        low = (num%10)&0x0F;
        high = ((num/10)<<4)&0xF0;
        bcd = low|high;
        return bcd;
/*****傳遞設置時間數值*******/
void Setnum_time()
  unsigned char i;
        for(i=0;i<3;i++)
          InitTime[i] = NumToBCD(set_time[i]);
/*******鬧鐘提示功能******/
void SetClock()
        if((clock[0]==time[0])&&(clock[1]==time[1])&&(clock[2]==time[2]))
                flag5s = 1;
        if(flag5s)
                        if(share_Led)
                                Select74HC573(4);
                                P0 = 0xFE;
                                Select74HC573(0);
                                P0 = 0xFF;
                                Select74HC573(4);
                                P0 = 0xFF;
                                Select74HC573(0);
                                P0 = 0xFF;
                  Select74HC573(4);
                        P0 = 0xFF;
                        Select74HC573(0);
/******設置鬧鐘*******/
void SetClock_jia()
  if(mode_clock==1)
          clock[0]++;
                if(clock[0]>=59)
                        clock[0] = 59;
        else if(mode_clock==2)
          clock[1]++;
                if(clock[1]>=59)
                        clock[1] = 59;
        else if(mode_clock==3)
          clock[2]++;
                if(clock[2]>=23)
                        clock[2] = 23;
void SetClock_jian()
  if(mode_clock==1)
                if(clock[0]>0)
                        clock[0]--;
                        clock[0] = 0;
          if(clock[1]>0)
                        clock[1]--;
                        clock[1] = 0;
          if(clock[2]>0)
                        clock[2]--;
                        clock[2] = 0;
/******設置時間*******/
void SetTime_jia()
  if(mode_time==1)
          set_time[0]++;
                if(set_time[0]>=59)
                        set_time[0] = 59;
        else if(mode_time==2)
          set_time[1]++;
                if(set_time[1]>=59)
                        set_time[1] = 59;
        else if(mode_time==3)
          set_time[2]++;
                if(set_time[2]>=23)
                        set_time[2] = 23;
void SetTime_jian()
  if(mode_time==1)
                if(set_time[0]>0)
                        set_time[0]--;
                        set_time[0] = 0;
          if(set_time[1]>0)
                        set_time[1]--;
                        set_time[1] = 0;
          if(set_time[2]>0)
                        set_time[2]--;
                        set_time[2] = 0;
/*******按鍵處理******/
void Delay1ms()                //@12.000MHz
        unsigned char i, j;
        i = 12;
        j = 169;
        do
                while (--j);
        } while (--i);
void ScanKeyS()
  if(S7==0)  //時鐘設置
          Delay1ms();
                if(S7==0)
                        flag5s = 0;
                        if((mode_clock==0)&&(mode_T==0))
                                switch(mode_time)
                                        case 0:mode_time = 1;mode_SMG = 2;
                                                DS1302SingWrite(0x8E,0x00);break;
                                        case 1:mode_time = 2;mode_SMG = 2;break;
                                        case 2:mode_time = 3;mode_SMG = 2;break;
                                        case 3:mode_time = 0;mode_SMG = 1;
                                          Setnum_time();
                                          InitDS1302();break;
                  while(S7==0)
                          SMGWroking();
        if(S6==0)  //鬧鐘設置
          Delay1ms();
                if(S6==0)
                        flag5s = 0;
                        if((mode_time==0)&&(mode_T==0))
                                switch(mode_clock)
                                        case 0:mode_clock = 1;mode_SMG = 3;break;
                                        case 1:mode_clock = 2;mode_SMG = 3;break;
                                        case 2:mode_clock = 3;mode_SMG = 3;break;
                                        case 3:mode_clock = 0;mode_SMG = 1;break;
                  while(S6==0)
                          SMGWroking();
        if(S5==0)       //“加”按鍵,在“時鐘設置”或“鬧鐘設置”狀態(tài)下,
        {              //每次按下該按鍵當前選擇的單元(時、分或秒)增加 1 個單位。
          Delay1ms();
                if(S5==0)
                        flag5s = 0;
                        SetTime_jia();
                        SetClock_jia();
                  while(S5==0)
                          SMGWroking();
        if(S4==0)        //“減”按鍵,在“時鐘設置”或“鬧鐘設置”狀態(tài)下,
        {               //每次按下該按鍵當前選擇的單元(時、分或秒)減少 1 個單位。
          Delay1ms();
                if(S4==0)
                        flag5s = 0;
                        SetTime_jian();
                        SetClock_jian();
                        if((mode_time==0)&&(mode_clock==0)) //在 “時鐘顯示”狀態(tài)下,按下 S4 按鍵,
                        {                                  //顯示溫度數據,松開按鍵,返回“時鐘顯示”界面。
                          mode_T = ~mode_T;
                                if(mode_T)
                                        mode_SMG = 4; //顯示溫度
                                        mode_SMG = 1; //顯示時間
                  while(S4==0)
                          SMGWroking();
/******數碼管刷新*****/
void ScanSMG()
  static unsigned char i = 0;
        P0 = 0xFF;
        Select74HC573(6);
        P0 = 0x01<<i;
        Select74HC573(7);
        P0 = LedBuff[i++];
        if(i>=8)
                i = 0;
        Select74HC573(0);
void Timer0Init(void)                //1毫秒@12.000MHz
        AUXR &= 0x7F;                //定時器時鐘12T模式
        TMOD &= 0xF0;                //設置定時器模式
        TL0 = 0x18;                //設置定時初值
        TH0 = 0xFC;                //設置定時初值
        TF0 = 0;                //清除TF0標志
        TR0 = 1;                //定時器0開始計時
        ET0 = 1;
        EA = 1;
void IterruptTime0()  interrupt 1
        static unsigned int cnt = 0;
        static unsigned char share = 0;
  ScanSMG();
        if(flag5s)
                share++;
                if(share>=200)
                        share_Led = ~share_Led;
                        cnt++;
                        share = 0;
                if(cnt>=25)
                        flag5s = 0;
第8屆電子鐘_1.rar
54.68 KB, 下載次數: 12, 下載積分: 黑幣 -5
省賽試題-第8屆-基于單片機的電子鐘.pdf
150.36 KB, 下載次數: 11, 下載積分: 黑幣 -5
Powered by 單片機教程網
