#include <stc15f2k60s2.h>
#include <I2C.h>
#include <DS1302.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
sbit S5 = P3^2;
sbit S4 = P3^3;
unsigned char code LedChar[] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char time[7]; //獲取時(shí)鐘芯片時(shí)間
unsigned char value_fz = 50; //濕度閾值
unsigned char value_shidu; //濕度
bit mode_auto = 1; // 0 手動(dòng)模式 1 自動(dòng)模式
bit mode_buzz = 1; // 0 蜂鳴器關(guān)閉 1 蜂鳴器打開(kāi)
bit mode_sys = 0; // 0 關(guān)閉灌溉系統(tǒng) 1 打開(kāi)灌溉系統(tǒng)
bit set_value = 0; // 0 關(guān)閉濕度閾值設(shè)置 1 打開(kāi)濕度閾值設(shè)置
bit flag500ms = 0;
void InitSystem();
void Timer0Init(void); //1毫秒@12.000MHz
void ScanKeys();
void ConfigSMG();
void SysWorking();
void Delay1ms(); //@12.000MHz
extern void I2CWrite(unsigned char addr,unsigned char dat);
extern unsigned char I2CRead(unsigned char addr);
extern unsigned char ReadRb2();
Timer0Init();
InitSystem();
InitDS1302(); //1302初始化
value_fz=I2CRead(0x03); //讀取濕度閾值
ConfigSMG();
ScanKeys();
SysWorking();
/******HC573選擇函數(shù)*******/
void SeceltHC573(unsigned char channel)
switch(channel)
case 4:P2 = (P2&0x1F)|0x80;break;
case 5:P2 = (P2&0x1F)|0xA0;break;
case 6:P2 = (P2&0x1F)|0xC0;break;
case 7:P2 = (P2&0x1F)|0xE0;break;
default:P2 = (P2&0x1F)|0x00;break;
/*******關(guān)閉LED和蜂鳴器、繼電器******/
void InitSystem()
SeceltHC573(5);
P0 = 0x00;
SeceltHC573(4);
P0 = 0xFF;
SeceltHC573(0);
/******數(shù)碼管顯示********/
void ConfigSMG()
if(flag500ms)
value_shidu = ReadRb2(); //讀取濕度
if((mode_auto==1)&&(set_value==1)) //閾值設(shè)置界面
LedBuff[0] = LedChar[16];
LedBuff[1] = LedChar[16];
LedBuff[2] = 0xFF;
LedBuff[3] = 0xFF;
LedBuff[4] = 0xFF;
LedBuff[5] = 0xFF;
LedBuff[6] = LedChar[value_fz/10];
LedBuff[7] = LedChar[value_fz%10];
else //時(shí)間及濕度顯示界面
DS1302SingRead(time);
LedBuff[0] = LedChar[time[2]>>4];
LedBuff[1] = LedChar[time[2]&0x0F];
LedBuff[2] = LedChar[16];
LedBuff[3] = LedChar[time[1]>>4];
LedBuff[4] = LedChar[time[1]&0x0F];
LedBuff[5] = 0xFF;
LedBuff[6] = LedChar[value_shidu/10];
LedBuff[7] = LedChar[value_shidu%10];
/******按鍵相關(guān)函數(shù)*******/
void Delay1ms() //@12.000MHz
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
void ScanKeys()
if(S7==0) //系統(tǒng)工作狀態(tài)切換按鍵
Delay1ms();
if(S7==0)
mode_auto = ~mode_auto;
while(S7==0)
ConfigSMG();
if(S6==0)
Delay1ms();
if(S6==0)
if(mode_auto) //自動(dòng)模式
set_value = ~set_value; //進(jìn)入和退出濕度閾值調(diào)整界面
else //手動(dòng)模式
mode_buzz = ~mode_buzz; //蜂鳴器打開(kāi)和關(guān)閉
while(S6==0)
ConfigSMG();
if(S5==0)
Delay1ms();
if(S5==0)
if(set_value)
if(value_fz<99) //濕度閾值加1
value_fz++;
value_fz = 99;
else //手動(dòng)模式
mode_sys = 1; //打開(kāi)灌溉系統(tǒng)
while(S5==0)
ConfigSMG();
if(S4==0)
Delay1ms();
if(S4==0)
if(set_value)
if(value_fz>0) //濕度閾值減1
value_fz--;
value_fz = 0;
else //手動(dòng)模式
mode_sys = 0; //關(guān)閉灌溉系統(tǒng)
while(S4==0)
ConfigSMG();
/*****系統(tǒng)工作狀態(tài)顯示******/
void SysWorking()
SeceltHC573(4); //點(diǎn)亮LED1
P0 = 0xFE;
SeceltHC573(0);
if(value_shidu<value_fz) //灌溉設(shè)備自動(dòng)打開(kāi)
EA = 0;
SeceltHC573(5);
P0 = 0x10;
SeceltHC573(0);
EA = 1;
else //灌溉設(shè)備自動(dòng)關(guān)閉
EA = 0;
SeceltHC573(5);
P0 = 0x00;
SeceltHC573(0);
EA = 1;
else //手動(dòng)模式
SeceltHC573(4); //點(diǎn)亮LED2
P0 = 0xFD;
SeceltHC573(0);
if(mode_sys) //灌溉設(shè)備打開(kāi)
EA = 0;
SeceltHC573(5);
P0 = 0x10;
SeceltHC573(0);
EA = 1;
else //灌溉設(shè)備關(guān)閉
EA = 0;
SeceltHC573(5);
P0 = 0x00;
SeceltHC573(0);
EA = 1;
if(mode_buzz) //開(kāi)啟蜂鳴器標(biāo)志位
if(value_shidu<value_fz) //濕度小于閾值蜂鳴器打開(kāi)
SeceltHC573(5);
P0 = 0x40;
SeceltHC573(0);
if(set_value) //保存濕度閾值
I2CWrite(0x03,value_fz);
Delay1ms();
/******數(shù)碼管動(dòng)態(tài)刷新*****/
void ScanSMG()
static unsigned char i = 0;
P0 = 0xFF;
SeceltHC573(6);
P0 = 0x01<<i;
SeceltHC573(7);
P0 = LedBuff[i++];
if(i>=8)
i = 0;
SeceltHC573(0);
/******配置定時(shí)器0******/
void Timer0Init(void) //1毫秒@12.000MHz
AUXR &= 0x7F; //定時(shí)器時(shí)鐘12T模式
TMOD &= 0xF0; //設(shè)置定時(shí)器模式
TL0 = 0x18; //設(shè)置定時(shí)初值
TH0 = 0xFC; //設(shè)置定時(shí)初值
TF0 = 0; //清除TF0標(biāo)志
TR0 = 1; //定時(shí)器0開(kāi)始計(jì)時(shí)
ET0 = 1;
EA = 1;
void InterruptTimer0() interrupt 1
static unsigned int cnt = 0;
ScanSMG();
cnt++;
if(cnt>=500)
cnt = 0;
flag500ms = ~flag500ms;
