查看: 2740|回復(fù): 0
藍(lán)橋杯單片機(jī)開發(fā)第4屆省賽自動售水機(jī)及源代碼
ID:656536 發(fā)表于 2020-3-24 18:59 | 顯示全部樓層 |閱讀模式
#include <stc15f2k60s2.h>
#include <I2C.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
unsigned char code LedChar[] = {
  0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
        0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
  0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char dat_rd1;
unsigned char money;
unsigned int shui_L = 0;  //出水量
unsigned int flag_ns = 0;
bit shui = 0;  // 0停止出水  1打開出水
void InitSystem();
void Timer0Init(void);                //1毫秒@12.000MHz
void ConfigSMG();
void ConfigWorking();
void ScanKeys();
void ScanSMG();
extern unsigned char ReadRd1();
        InitSystem();
  Timer0Init();
                ConfigWorking();
          ConfigSMG();
                ScanKeys();
                ScanSMG();
/******HC573選擇函數(shù)*******/
void SeceltHC573(unsigned char channel)
  switch(channel)
          case 4:P2 = (P2&0x1F)|0x80;break;
                case 5:P2 = (P2&0x1F)|0xA0;break;
                case 6:P2 = (P2&0x1F)|0xC0;break;
                case 7:P2 = (P2&0x1F)|0xE0;break;
                case 0:P2 = (P2&0x1F)|0x00;break;
/*******關(guān)閉LED和蜂鳴器、繼電器******/
void InitSystem()
  SeceltHC573(5);
        P0 = 0x00;
        SeceltHC573(4);
        P0 = 0xFF;
        SeceltHC573(0);
/******工作模式配置******/
  dat_rd1 = ReadRd1();  //采集光敏電阻電壓
        SeceltHC573(4);
        if(dat_rd1>125)      //判斷LED1亮滅
                P0 = 0xFE;
          P0 = 0xFF;
        SeceltHC573(0);
        shui_L = flag_ns;
        money = shui_L*0.5;
        if(shui_L>=999)
          shui = 0;
                flag_ns = 0;
        if(shui)
                EA = 0;
          SeceltHC573(5);    //打開繼電器
                P0 = 0x10;
                SeceltHC573(0);
                EA = 1;
          EA = 0;
          SeceltHC573(5);    //關(guān)閉繼電器
                P0 = 0x00;
                SeceltHC573(0);
                EA = 1;
/******數(shù)碼管動態(tài)顯示*******/
void ConfigSMG()
  if(shui)
          LedBuff[0] = 0xFF;
                LedBuff[1] = (LedChar[0]&LedChar[17]);
                LedBuff[2] = LedChar[5];
                LedBuff[3] = LedChar[0];
                LedBuff[4] = LedChar[shui_L/100];
                LedBuff[5] = (LedChar[shui_L/10%10]&LedChar[17]);
                LedBuff[6] = LedChar[shui_L%10];
                LedBuff[7] = LedChar[0];
          LedBuff[0] = 0xFF;
                LedBuff[4] = LedChar[money/100];
                LedBuff[5] = (LedChar[money/10%10]&LedChar[17]);
                LedBuff[6] = LedChar[money%10];
/******按鍵相關(guān)函數(shù)******/
void Delay1ms()                //@12.000MHz
        unsigned char i, j;
        i = 12;
        j = 169;
        do
                while (--j);
        } while (--i);
void ScanKeys()
  if(S7==0)
                Delay1ms();
          if(S7==0)
                        flag_ns = 0;
                  shui = 1;
                        while(S7==0)
                                ScanSMG();
        if(S6==0)
                Delay1ms();
          if(S6==0)
                  shui = 0;
                        while(S6==0)
                                ScanSMG();
/******數(shù)碼管動態(tài)刷新*****/
void ScanSMG()
  static unsigned char i = 0;
//        P0 = 0xFF;
        SeceltHC573(6);
        P0 = 0x01<<i;
        SeceltHC573(7);
        P0 = LedBuff[i++];
        if(i>=8)
                i = 0;
        SeceltHC573(0);
        P0 = 0xFF;
        Delay1ms();
/******配置定時器0******/
void Timer0Init(void)                //1毫秒@12.000MHz
        AUXR &= 0x7F;                //定時器時鐘12T模式
        TMOD &= 0xF0;                //設(shè)置定時器模式
        TL0 = 0x18;                //設(shè)置定時初值
        TH0 = 0xFC;                //設(shè)置定時初值
        TF0 = 0;                //清除TF0標(biāo)志
        TR0 = 1;                //定時器0開始計時
        ET0 = 1;
        EA = 1;
void InterruptTimer0()  interrupt 1
        static unsigned int cnt = 0;
        if(shui)
                cnt++;
                if(cnt>=1000)
                        cnt = 0;
                        flag_ns++;
                cnt = 0;
省賽試題-第4屆-自動售水機(jī).pdf
546.02 KB, 下載次數(shù): 14, 下載積分: 黑幣 -5
第4屆自動售水機(jī)_1.rar
43.1 KB, 下載次數(shù): 20, 下載積分: 黑幣 -5
