溫濕度傳感SHT3x
單片機源程序如下:
- //-- Includes -----------------------------------------------------------------
- #include "system.h"
- #include "sht3x.h"
- //-- Static function prototypes -----------------------------------------------
- static void EvalBoardPower_Init(void);
- static void Led_Init(void);
- static void UserButton_Init(void);
- static void LedBlueOn(void);
- static void LedBlueOff(void);
- static void LedGreenOn(void);
- static void LedGreenOff(void);
- static u8t ReadUserButton(void);
- int main(void)
- etError error; // error code
- u32t serialNumber;// serial number
- regStatus status; // sensor status
- ft temperature; // temperature [癈]
- ft humidity; // relative humidity [%RH]
- bt heater; // heater, false: off, true: on
- SystemInit();
- Led_Init();
- UserButton_Init();
- EvalBoardPower_Init();
- SHT3X_Init(0x45); // Address: 0x44 = Sensor on EvalBoard connector
- // 0x45 = Sensor on EvalBoard
- // wait 50ms after power on
- DelayMicroSeconds(50000);
- error = SHT3x_ReadSerialNumber(&serialNumber);
- if(error != NO_ERROR){} // do error handling here
- // demonstrate a single shot measurement with clock-stretching
- error = SHT3X_GetTempAndHumi(&temperature, &humidity, REPEATAB_HIGH, MODE_CLKSTRETCH, 50);
- // demonstrate a single shot measurement with polling and 50ms timeout
- error = SHT3X_GetTempAndHumi(&temperature, &humidity, REPEATAB_HIGH, MODE_POLLING, 50);
- // loop forever
- while(1)
- error = NO_ERROR;
- // loop while no error
- while(error == NO_ERROR)
- // read status register
- error |= SHT3X_ReadStatus(&status.u16);
- if(error != NO_ERROR) break;
- // check if the reset bit is set after a reset or power-up
- if(status.bit.ResetDetected)
- //override default temperature and humidity alert limits (red LED)
- error = SHT3X_SetAlertLimits( 70.0f, 50.0f, // high set: RH [%], T [癈]
- 68.0f, 48.0f, // high clear: RH [%], T [癈]
- 32.0f, -2.0f, // low clear: RH [%], T [癈]
- 30.0f, -4.0f); // low set: RH [%], T [癈]
- // clear reset and alert flags
- error = SHT3X_ClearAllAlertFlags();
- //start periodic measurement, with high repeatability and 1 measurements per second
- error = SHT3X_StartPeriodicMeasurment(REPEATAB_HIGH, FREQUENCY_1HZ);
- //switch green LED on
- LedGreenOn();
- // read measurment buffer
- error = SHT3X_ReadMeasurementBuffer(&temperature, &humidity);
- if(error == NO_ERROR)
- // flash blue LED to signalise new temperature and humidity values
- LedBlueOn();
- DelayMicroSeconds(10000);
- LedBlueOff();
- else if (error == ACK_ERROR)
- // there were no new values in the buffer -> ignore this error
- error = NO_ERROR;
- else break;
- // read heater status
- heater = status.bit.HeaterStatus ? TRUE : FALSE;
- // if the user button is not pressed ...
- if(ReadUserButton() == 0)
- // ... and the heater is on
- if(heater)
- // switch off the sensor internal heater
- error |= SHT3X_DisableHeater();
- else
- // if the user button is pressed ...
- // ... and the heater is off
- if(!heater)
- // switch on the sensor internal heater
- error |= SHT3X_EnableHeater();
- // wait 100ms
- DelayMicroSeconds(100000);
- // in case of an error ...
- // ... switch green and blue LED off
- LedGreenOff();
- LedBlueOff();
- // ... try first a soft reset ...
- error = SHT3X_SoftReset();
- // ... if the soft reset fails, do a hard reset
- SHT3X_HardReset();
- // flash green LED to signalise an error
- LedGreenOn();
- LedGreenOff();
- static void EvalBoardPower_Init(void) /* -- adapt this code for your platform -- */
- RCC->APB2ENR |= 0x00000008; // I/O port B clock enabled
- GPIOB->CRH &= 0x0FFF0FFF; // set push-pull output for Vdd & GND pins
- GPIOB->CRH |= 0x10001000; //
- GPIOB->BSRR = 0x08008000; // set Vdd to High, set GND to Low
- static void Led_Init(void) /* -- adapt this code for your platform -- */
- RCC->APB2ENR |= 0x00000010; // I/O port C clock enabled
- GPIOC->CRH &= 0xFFFFFF00; // set general purpose output mode for LEDs
- GPIOC->CRH |= 0x00000011; //
- GPIOC->BSRR = 0x03000000; // LEDs off
- static void UserButton_Init(void) /* -- adapt this code for your platform -- */
- RCC->APB2ENR |= 0x00000004; // I/O port A clock enabled
- GPIOA->CRH &= 0xFFFFFFF0; // set general purpose input mode for User Button
- GPIOA->CRH |= 0x00000004; //
- static void LedBlueOn(void) /* -- adapt this code for your platform -- */
- GPIOC->BSRR = 0x00000100;
溫濕度傳感官方.zip
(33.84 KB, 下載次數(shù): 31)
2020-3-25 09:12 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
