四路尋跡小車仿真,液晶顯示小車行駛狀態(tài)
包括直行,小右轉(zhuǎn),大右轉(zhuǎn),小左轉(zhuǎn),大左轉(zhuǎn)
仿真界面
主程序流程圖
- #include <reg52.h>//52頭文件
- #include <lcd.h>//液晶顯示配置文件
- unsigned char pwm_left_val; //左電機(jī)占空比值 取值范圍0-170,0最快
- unsigned char pwm_right_val; //右電機(jī)占空比值取值范圍0-170 ,0最快
- unsigned char pwm_t;//周期
- void delay(unsigned int z)//毫秒級延時
- unsigned int x,y;
- for(x = z; x > 0; x--)
- for(y = 114; y > 0 ; y--);
- /*小車前進(jìn)*/
- int forward()
- pwm_left_val=100;
- pwm_right_val=100;
- left_motor_go; //左電機(jī)前進(jìn)
- right_motor_go; //右電機(jī)前進(jìn)
- /*小車小左轉(zhuǎn)*/
- int xiaoleft_run()
- pwm_left_val=170;
- /*小車大左轉(zhuǎn)*/
- void daleft_run()
- left_motor_stops; //左電機(jī)停止
- /*小車小右轉(zhuǎn)*/
- int xiaoright_run()
- pwm_left_val=100;
- pwm_right_val=170;
- /*小車大右轉(zhuǎn)*/
- void daright_run()
- right_motor_stops;//右電機(jī)停止
- //定時器0中斷
- void timer0() interrupt 1
- pwm_t++;//周期計時加
- if(pwm_t == 255)
- pwm_t = EN1 = EN2 = 0;
- if(pwm_left_val == pwm_t)//左電機(jī)占空比
- EN1 = 1;
- if(pwm_right_val == pwm_t)//右電機(jī)占空比
- EN2 = 1;
- void main()
- for(;;) //死循環(huán)
- if(key == 0)// 實時檢測S2按鍵是否被按下
- delay(5); //軟件消抖
- LCDInit();
- DisplayString(0x0,0,"Left's Go");
- break; //退出FOR死循環(huán)
- delay(1000);//延時1秒
- TMOD |= 0x02;//8位自動重裝模塊
- TH0 = 220;
- TL0 = 220;//11.0592M晶振下占空比最大比值是256,輸出100HZ
- TR0 = 1;//啟動定時器0
- ET0 = 1;//允許定時器0中斷
- EA = 1;//總中斷允許
- while(1)
- //為0 沒有識別到黑線 為1識別到黑線
- if(left2_led == right1_led)
- forward();//前進(jìn)
- WriteCmd(LCD_CLS);
- DisplayString(0x0,0,"forward");
- delay(200);
- else if(left1_led == 0 && left2_led == 1 && right1_led== 0 && right2_led== 0 )//左邊觸線,小左轉(zhuǎn)修正
- xiaoleft_run();
- DisplayString(0x0,0,"Turn Left small");
- delay(200);
- else if(left1_led == 1 && left2_led == 1 && right1_led== 0 && right2_led== 0 )//最左邊觸線,大左轉(zhuǎn)修正
- daleft_run();
- DisplayString(0x0,0,"Turn Left big");
- delay(200);
- else if(left1_led == 0 && left2_led == 0 && right1_led== 1 && right2_led== 0 )//右邊觸線,小右轉(zhuǎn)修正
- xiaoright_run();
- DisplayString(0x0,0,"Turn Right small");
- delay(200);
- else if(left1_led == 0 && left2_led == 0 && right1_led== 1 && right2_led== 1 ) //最右邊觸線,大右轉(zhuǎn)修正
- daright_run();
- DisplayString(0x0,0,"Turn Right big");
- delay(200);
尋跡小車.rar
(132 KB, 下載次數(shù): 195)
2020-3-28 01:03 上傳
點(diǎn)擊文件名下載附件
程序及仿真
