#include "2214.h"
* 硬件連接:------------------
* | PB3 - SDIN |
* | PB4 - SCLK |
/**********************************用法********************************/
//#include "stm32f10x.h"
//#include "LED.h"
//#include "delay.h"
//#include "KEY.h"
//#include "OLED_IIC.h"
//#include "usart.h"
//#include "ADC.h"
//#include "DAC.h"
//#include "TIM.h"
//#include "2214.h"
//void FDC2214_GetData(void);
//u32 ch0,ch1,ch2,ch3;
//int main(void)
// u32 t = 0;
// delay_init(); //延時函數(shù)初始化
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置 NVIC 中斷分組 2
// uart_init(115200); //串口初始化波特率為 115200
// OLED_Init();
// OLED_Clear();
// LED_Pin_Init(); //LED 端口初始化
// OLED_ShowCHinese(90,0,7);//贊
// FDC2214_init();
// while(1)
// FDC2214_GetData();
// //printf("\r\nCH0~3(%d , %d , %d , %d)",ch0,ch1,ch2,ch3);
// OLED_ShowNum(0,0,ch0,16,16);
// OLED_ShowNum(0,2,ch1,16,16);
// OLED_ShowNum(0,4,ch2,16,16);
// OLED_ShowNum(0,6,ch3,16,16);
// delay_ms(500); //延時300ms
// FDC2214_GetChannelData(FDC2214_Channel_0, &ch0);
// FDC2214_GetChannelData(FDC2214_Channel_1, &ch1);
// FDC2214_GetChannelData(FDC2214_Channel_2, &ch2);
// FDC2214_GetChannelData(FDC2214_Channel_3, &ch3);
#define PI 3.14159265358979323846
#define ClockFrequency 36000000 //時鐘頻率
uint8_t CHx_FIN_SEL[4];
double fREFx[4];
void FDC_IIC_Init(void)
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE ); //使能GPIOB時鐘
RCC_APB2PeriphClockCmd( RCC_APB2Periph_AFIO, ENABLE );
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);//關(guān)閉JTAG,釋放PB3,PB4,PA15
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽輸出
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_SetBits(GPIOB,GPIO_Pin_3|GPIO_Pin_4); //輸出高
void delay_2us(void)
//一個NOP是1/72us 所以72個NOP是1us
u32 i=0;
for(i=0;i<2;i++)
__NOP();__NOP();__NOP();__NOP();__NOP();__NOP();__NOP();__NOP();__NOP();
void FDC_IIC_Start(void)
SDA_OUT();
FDC_IIC_SDA_OUT=1;
FDC_IIC_SCL=1;
delay_2us();
FDC_IIC_SDA_OUT=0;
delay_2us();
FDC_IIC_SCL=0;
delay_2us();
void FDC_IIC_Stop(void)
SDA_OUT();
FDC_IIC_SCL=0;
delay_2us();
FDC_IIC_SDA_OUT=0;
delay_2us();
FDC_IIC_SCL=1;
delay_2us();
FDC_IIC_SDA_OUT=1;
delay_2us();
u8 FDC_IIC_Wait_Ack(void)
u8 waitTime=0;
SDA_IN();
FDC_IIC_SDA_OUT=1;
delay_2us();
FDC_IIC_SCL=1;
delay_2us();
while(FDC_IIC_SDA_IN)
waitTime++;
if(waitTime>250)
FDC_IIC_Stop();
return 1;
FDC_IIC_SCL=0;
return 0;
void FDC_IIC_Ack(void)
FDC_IIC_SCL=0;
delay_2us();
SDA_OUT();
FDC_IIC_SDA_OUT=0;//發(fā)送0是ACK
delay_2us();
FDC_IIC_SCL=1;
delay_2us();
FDC_IIC_SCL=0;
delay_2us();
void FDC_IIC_NAck(void)
FDC_IIC_SCL=0;
delay_2us();
SDA_OUT();
FDC_IIC_SDA_OUT=1;//發(fā)送1是nACK
delay_2us();
FDC_IIC_SCL=1;
delay_2us();
FDC_IIC_SCL=0;
delay_2us();
void FDC_IIC_Send_Byte(u8 dat)
u8 t;
SDA_OUT();
FDC_IIC_SCL=0;
for(t=0;t<8;t++)
delay_2us();
FDC_IIC_SDA_OUT=(dat&0x80)>>7;
dat<<=1;
FDC_IIC_SCL=1;
delay_2us();
FDC_IIC_SCL=0;
delay_2us();
//FDC_IIC_SCL=0;
u8 FDC_IIC_Read_Byte(u8 ack)
u8 i,receive=0;
FDC_IIC_SDA_OUT=1;
SDA_IN();
for(i=0;i<8;i++ )
receive<<=1;
FDC_IIC_SCL=0;
delay_2us();
FDC_IIC_SCL=1;
delay_2us();
if(FDC_IIC_SDA_IN)receive++;//最低位置1
FDC_IIC_SCL=0;
if (!ack)
FDC_IIC_NAck();
FDC_IIC_Ack();
return receive;
* @brief FDC_IIC寫FDC2214
* @param Slve_Addr 器件地址
* @param reg 寄存器
* @param data 數(shù)據(jù)
* @since v1.0
* Sample usage: FDC2214_Write16(FDC2214_Addr, FDC2214_CONFIG, 0xFFFF);
void FDC2214_Write16(uint8_t Slve_Addr, uint8_t reg, uint16_t data)
u8 dat;
FDC_IIC_Start();
FDC_IIC_Send_Byte(Slve_Addr << 1);
FDC_IIC_Wait_Ack();
FDC_IIC_Send_Byte(reg);
FDC_IIC_Wait_Ack();
dat=(data >> 8);
FDC_IIC_Send_Byte(dat);
FDC_IIC_Wait_Ack();
dat=data & 0xFF;
FDC_IIC_Wait_Ack();
FDC_IIC_Stop();
* @brief FDC_IIC讀FDC2214
* @param reg 寄存器
* @return 寄存器值
* @since v1.0
* Sample usage: FDC2214_Read16(FDC2214_Addr, FDC2214_CONFIG);
uint16_t FDC2214_Read16(uint8_t Slve_Addr, uint8_t reg)
uint16_t temp;
FDC_IIC_Start();
FDC_IIC_Wait_Ack();
FDC_IIC_Wait_Ack();
FDC_IIC_Start();
FDC_IIC_Send_Byte((Slve_Addr << 1) | 0x01);
FDC_IIC_Wait_Ack();
temp = (uint16_t)(FDC_IIC_Read_Byte(1) << 8);
temp |= FDC_IIC_Read_Byte(0);
FDC_IIC_Stop();
return temp;
* @brief 讀取FDC2214一個通道的轉(zhuǎn)換值
* @param channel 通道
* @param *data 讀取的數(shù)據(jù)
* @return 0:失;1:成功
* @since v1.0
* Sample usage: FDC2214_GetChannelData(FDC2214_Channel_0, &CH0_DATA);
uint8_t FDC2214_GetChannelData(FDC2214_channel_t channel, uint32_t *data)
int16_t timeout = 100;
uint8_t dateReg_H;
uint8_t dateReg_L;
uint8_t bitUnreadConv;
uint16_t status;
uint32_t dataRead;
switch(channel)
case FDC2214_Channel_0:
dateReg_H = FDC2214_DATA_CH0;
dateReg_L = FDC2214_DATA_LSB_CH0;
bitUnreadConv = 0x0008;
break;
case FDC2214_Channel_1:
dateReg_H = FDC2214_DATA_CH1;
dateReg_L = FDC2214_DATA_LSB_CH1;
bitUnreadConv = 0x0004;
break;
case FDC2214_Channel_2:
dateReg_H = FDC2214_DATA_CH2;
dateReg_L = FDC2214_DATA_LSB_CH2;
bitUnreadConv = 0x0002;
break;
case FDC2214_Channel_3:
dateReg_H = FDC2214_DATA_CH3;
dateReg_L = FDC2214_DATA_LSB_CH3;
bitUnreadConv = 0x0001;
break;
status = FDC2214_Read16(FDC2214_Addr, FDC2214_STATUS);//讀取狀態(tài)寄存器的值
while(timeout && !(status & bitUnreadConv))//檢查是否有未讀數(shù)據(jù)
timeout--;
if(timeout)
dataRead = (uint32_t)(FDC2214_Read16(FDC2214_Addr, dateReg_H) << 16);
dataRead |= FDC2214_Read16(FDC2214_Addr, dateReg_L);
*data = dataRead;
return 1;
//超時
return 0;
* @brief 設置FDC2214一個通道的轉(zhuǎn)換時間,轉(zhuǎn)換時間(tCx)=(CHx_RCOUNT?16) / fREFx。
* @param channel 通道
* @param rcount CHx_RCOUNT
* @since v1.0
* Sample usage: FDC2214_SetRcount(FDC2214_Channel_0, 0x0FFF);
void FDC2214_SetRcount(FDC2214_channel_t channel, uint16_t rcount)
if(rcount <= 0x00FF) return;
switch(channel)
FDC2214_Write16(FDC2214_Addr, FDC2214_RCOUNT_CH0, rcount);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_RCOUNT_CH1, rcount);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_RCOUNT_CH2, rcount);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_RCOUNT_CH3, rcount);
break;
* @brief 設置FDC2214一個通道的建立時間,使LC傳感器可以在通道x開始轉(zhuǎn)換之前穩(wěn)定下來,建立時間(tSx) = (CHx_SETTLECOUNT?16) ÷ fREFx。
CHx_SETTLECOUNT = 0x00, 0x01時(tSx) = 32 ÷ fREFx。
* @param channel 通道
* @param count CHx_SETTLECOUNT
* @since v1.0
* @note CHx_SETTLECOUNT > Vpk × fREFx × C × π^2 / (32 × IDRIVEX)
* Sample usage: FDC2214_SetSettleCount(FDC2214_Channel_0, 0x00FF);
void FDC2214_SetSettleCount(FDC2214_channel_t channel, uint16_t count)
switch(channel)
FDC2214_Write16(FDC2214_Addr, FDC2214_SETTLECOUNT_CH0, count);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_SETTLECOUNT_CH1, count);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_SETTLECOUNT_CH2, count);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_SETTLECOUNT_CH3, count);
break;
* @brief 設置FDC2214一個通道的的時鐘頻率,
差分傳感器配置:
0x01 -- 傳感器頻率0.01MHz和8.75MHz
0x02 -- 傳感器頻率5MHz和10MHz
單端傳感器配置:
0x01 -- 傳感器頻率0.01MHz和10MHz
* @param channel 通道
* @param frequency_select 時鐘選擇
* @param divider 分頻器,fREFx = fCLK / CHx_FREF_DIVIDER,
* @note fREFx is > 4 × fSENSOR(外部LC振蕩器頻率)
* @since v1.0
* Sample usage: FDC2214_SetChannelClock(FDC2214_Channel_0, 0x01, 0xFF);
void FDC2214_SetChannelClock(FDC2214_channel_t channel, uint8_t frequency_select, uint16_t divider)
uint16_t temp = 0;
temp = (uint16_t)(frequency_select << 12) | (divider & 0x03FF);
CHx_FIN_SEL[channel] = frequency_select;//記錄時鐘選擇
fREFx[channel] = (double)ClockFrequency / divider;//記錄時鐘頻率
switch(channel)
FDC2214_Write16(FDC2214_Addr, FDC2214_CLOCK_DIVIDERS_CH0, temp);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_CLOCK_DIVIDERS_CH1, temp);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_CLOCK_DIVIDERS_CH2, temp);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_CLOCK_DIVIDERS_CH3, temp);
break;
* @brief 配置INTB引腳中斷功能
* @param mode 1:開中斷;0:關(guān)中斷
* @since v1.0
* Sample usage: FDC2214_SetDriveCurrent(FDC2214_Channel_0, FDC2214_Drive_Current_0_025);
void FDC2214_SetINTB(uint8_t mode)
uint16_t temp = 0;
temp = FDC2214_Read16(FDC2214_Addr, FDC2214_CONFIG);
temp &= 0xFF7F;
if(mode)
temp |= 0x0080;
FDC2214_Write16(FDC2214_Addr, FDC2214_CONFIG, temp);
temp = FDC2214_Read16(FDC2214_Addr, FDC2214_ERROR_CONFIG);
temp &= 0xFFFE;
if(mode)
temp |= 0x0001;
FDC2214_Write16(FDC2214_Addr, FDC2214_ERROR_CONFIG, temp);
* @brief 激活FDC2214的一個通道,單通道模式
* @param channel 通道
* @since v1.0
* Sample usage: FDC2214_SetActiveChannel(FDC2214_Channel_0);
void FDC2214_SetActiveChannel(FDC2214_channel_t channel)
uint16_t temp = 0;
temp &= 0x3FFF;
temp |= (uint16_t)(channel << 14);
* @brief 設置FDC2214的工作模式:正常、睡眠。
* @param mode 0:正常工作;1:睡激活模式選擇。眠
* @since v1.0
* Sample usage: FDC2214_SetSleepMode(0);
void FDC2214_SetSleepMode(uint8_t mode)
uint16_t temp = 0;
temp &= 0xDFFF;
if(mode)temp |= 0x2000;
* @brief FDC2214激活模式選擇。
* @param mode 0:全電流激活模式;1:低功率激活模式
* @since v1.0
* Sample usage: FDC2214_SetCurrentMode(1);
void FDC2214_SetCurrentMode(uint8_t mode)
uint16_t temp = 0;
temp &= 0xF7FF;
if(mode)
temp |= 0x800;
* @brief 設置FDC2214時鐘源
* @param src 0:內(nèi)部時鐘源;1:外部時鐘源
* @since v1.0
* Sample usage: FDC2214_SetClockSource(1);
void FDC2214_SetClockSource(uint8_t src)
uint16_t temp = 0;
temp &= 0xFDFF;
if(src)
temp |= 0x200;
* @brief 高電流傳感器驅(qū)動,只適用于單通道模式。
* @param mode 0:正常(最大1.5mA);1:高電流傳感器驅(qū)動(>1.5mA)
* @since v1.0
* Sample usage: FDC2214_SetHighCurrentMode(0);
void FDC2214_SetHighCurrentMode(uint8_t mode)
uint16_t temp = 0;
temp &= 0xFFBF;
if(mode)
temp |= 0x40;
* @brief 設置FDC2214的MUX CONFIG寄存器
* @param autoscan 自動掃描模式 0:關(guān)閉,1:打開
* @param channels 自動掃描通道
* @param bandwidth 數(shù)字濾波器帶寬,大于外部LC振蕩器頻率
* @since v1.0
* Sample usage: FDC2214_SetMUX_CONFIG(1, FDC2214_Channel_Sequence_0_1_2, FDC2214_Bandwidth_10M);
void FDC2214_SetMUX_CONFIG(uint8_t autoscan, FDC2214_channel_sequence_t channels, FDC2214_filter_bandwidth_t bandwidth)
uint16_t temp = 0;
if(autoscan)
temp = (uint16_t)(autoscan << 15) | (channels << 13) | 0x0208 | bandwidth;
temp = 0x0208 | bandwidth;
FDC2214_Write16(FDC2214_Addr, FDC2214_MUX_CONFIG, temp);
* @brief 傳感器復位
* @since v1.0
* Sample usage: FDC2214_Reset();
void FDC2214_Reset(void)
FDC2214_Write16(FDC2214_Addr, FDC2214_RESET_DEV, 0x8000);
* @brief 設置FDC2214的一個通道傳感器驅(qū)動電流,確保振蕩幅度在1.2V和1.8V之間。
* @param channel 通道
* @param current 電流大小
* @since v1.0
void FDC2214_SetDriveCurrent(FDC2214_channel_t channel, FDC2214_drive_current_t current)
uint16_t temp = 0;
temp = (uint16_t)(current << 11);
switch(channel)
FDC2214_Write16(FDC2214_Addr, FDC2214_DRIVE_CURRENT_CH0, temp);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_DRIVE_CURRENT_CH1, temp);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_DRIVE_CURRENT_CH2, temp);
break;
FDC2214_Write16(FDC2214_Addr, FDC2214_DRIVE_CURRENT_CH3, temp);
break;
* @brief 計算頻率
* @param channel 通道
* @param datax 讀取的轉(zhuǎn)換值
* @return 頻率,單位Hz
* @since v1.0
* Sample usage: FDC2214_CalculateFrequency(FDC2214_Channel_0, 0xFF);
double FDC2214_CalculateFrequency(FDC2214_channel_t channel, uint32_t datax)
double frequency = 0.0;
frequency = (double)(CHx_FIN_SEL[channel] * fREFx[channel] * datax) / 268435456.0;//2^28
return frequency;
* @brief 計算外部電容大小
* @param frequency 頻率大小,單位Hz
* @param inductance 板載電感大小,單位uH
* @param capacitance 板載電容大小,單位pF
* @return 外部電容大小,單位pF
* @since v1.0
* Sample usage: FDC2214_CalculateCapacitance(FDC2214_Channel_0, 6000000, 18, 33);
double FDC2214_CalculateCapacitance(double frequency, float inductance, float capacitance)
double cap = 0.0;
cap = (double)(1.0 / (inductance * (2 * PI * frequency) * (2 * PI * frequency)));
return cap;
* @brief FDC2214初始化函數(shù)
* @return 1:成功;0:失敗
* @since v1.0
* Sample usage: FDC2214_Init();
uint8_t FDC2214_Init(void)
uint16_t deviceID = 0;
deviceID = FDC2214_Read16(FDC2214_Addr, FDC2214_DEVICE_ID);//讀器件ID
if(deviceID == FDC2214_ID)
printf("\r\nFDC2214 ID:%d",deviceID);
FDC2214_Reset();
FDC2214_SetRcount(FDC2214_Channel_0, 5000);//2000us 轉(zhuǎn)換周期
FDC2214_SetRcount(FDC2214_Channel_1, 5000);//2000us 轉(zhuǎn)換周期
FDC2214_SetRcount(FDC2214_Channel_2, 5000);//2000us 轉(zhuǎn)換周期
FDC2214_SetRcount(FDC2214_Channel_3, 5000);//2000us 轉(zhuǎn)換周期
FDC2214_SetSettleCount(FDC2214_Channel_0, 200);//200 cycles 等待時間
FDC2214_SetSettleCount(FDC2214_Channel_1, 200);//200 cycles 等待時間
FDC2214_SetSettleCount(FDC2214_Channel_2, 200);//200 cycles 等待時間
FDC2214_SetSettleCount(FDC2214_Channel_3, 200);//200 cycles 等待時間
FDC2214_SetChannelClock(FDC2214_Channel_0, 2, 1);//設置時鐘分頻,1分頻,40MHz
FDC2214_SetChannelClock(FDC2214_Channel_1, 2, 1);//設置時鐘分頻,1分頻,40MHz
FDC2214_SetChannelClock(FDC2214_Channel_2, 2, 1);//設置時鐘分頻,1分頻,40MHz
FDC2214_SetChannelClock(FDC2214_Channel_3, 2, 1);//設置時鐘分頻,1分頻,40MHz
FDC2214_SetINTB(0);//關(guān)閉INTB中斷
//FDC2214_SetActiveChannel(FDC2214_Channel_0);//開啟通道0
FDC2214_SetCurrentMode(0);//全電流激活模式
FDC2214_SetClockSource(1);//外部時鐘源
FDC2214_SetHighCurrentMode(0);//正常電流傳感器驅(qū)動
FDC2214_SetMUX_CONFIG(1, FDC2214_Channel_Sequence_0_1_2_3, FDC2214_Bandwidth_10M);//打開自動掃描,10MHz帶寬
FDC2214_SetDriveCurrent(FDC2214_Channel_0, FDC2214_Drive_Current_0_081);//通道0驅(qū)動電流0.081mA
FDC2214_SetDriveCurrent(FDC2214_Channel_1, FDC2214_Drive_Current_0_081);//通道1驅(qū)動電流0.081mA
FDC2214_SetDriveCurrent(FDC2214_Channel_2, FDC2214_Drive_Current_0_081);//通道2驅(qū)動電流0.081mA
FDC2214_SetDriveCurrent(FDC2214_Channel_3, FDC2214_Drive_Current_0_081);//通道3驅(qū)動電流0.081mA
FDC2214_SetSleepMode(0);//退出睡眠狀態(tài),開始工作
delay_ms(100);
return 1;
printf("\r\nFDC2214 Init Failed!!\r\n");
return 0;
void FDC2214_init(void)
FDC_IIC_Init();
FDC2214_Init();
#ifndef __2214_H
#define __2214_H
#include "sys.h"
#include "stdio.h"
#include "delay.h"
#define FDC_IIC_SCL PBout(4)
#define FDC_IIC_SDA_OUT PBout(3)
#define FDC_IIC_SDA_IN PBin(3)
#define SDA_OUT() {GPIOB->CRL&=0XFFFF0FFF;GPIOB->CRL|=(u32)3<<12;}//推挽輸出
#define SDA_IN() {GPIOB->CRL&=0XFFFF0FFF;GPIOB->CRL|=(u32)8<<12;}//上拉輸入
#define SWAP16(data) (uint32_t)((((uint16_t)(data) & (0xFF<<0 ))<<8)|(((uint32_t)(data) & (0xFF<<8))>>8))
#define FDC2214_Addr (0x2A)
#define FDC2214_DATA_CH0 (0x00)
#define FDC2214_DATA_LSB_CH0 (0x01)
#define FDC2214_DATA_CH1 (0x02)
#define FDC2214_DATA_LSB_CH1 (0x03)
#define FDC2214_DATA_CH2 (0x04)
#define FDC2214_DATA_LSB_CH2 (0x05)
#define FDC2214_DATA_CH3 (0x06)
#define FDC2214_DATA_LSB_CH3 (0x07)
#define FDC2214_RCOUNT_CH0 (0x08)
#define FDC2214_RCOUNT_CH1 (0x09)
#define FDC2214_RCOUNT_CH2 (0x0A)
#define FDC2214_RCOUNT_CH3 (0x0B)
#define FDC2214_SETTLECOUNT_CH0 (0x10)
#define FDC2214_SETTLECOUNT_CH1 (0x11)
#define FDC2214_SETTLECOUNT_CH2 (0x12)
#define FDC2214_SETTLECOUNT_CH3 (0x13)
#define FDC2214_CLOCK_DIVIDERS_CH0 (0x14)
#define FDC2214_CLOCK_DIVIDERS_CH1 (0x15)
#define FDC2214_CLOCK_DIVIDERS_CH2 (0x16)
#define FDC2214_CLOCK_DIVIDERS_CH3 (0x17)
#define FDC2214_STATUS (0x18)
#define FDC2214_ERROR_CONFIG (0x19)
#define FDC2214_CONFIG (0x1A)
#define FDC2214_MUX_CONFIG (0x1B)
#define FDC2214_RESET_DEV (0x1C)
#define FDC2214_DRIVE_CURRENT_CH0 (0x1E)
#define FDC2214_DRIVE_CURRENT_CH1 (0x1F)
#define FDC2214_DRIVE_CURRENT_CH2 (0x20)
#define FDC2214_DRIVE_CURRENT_CH3 (0x21)
#define FDC2214_MANUFACTURER_ID (0x7E)
#define FDC2214_DEVICE_ID (0x7F)
#define FDC2214_ID (0x3055)
typedef enum
FDC2214_Channel_0 = 0x00,
FDC2214_Channel_1 = 0x01,
FDC2214_Channel_2 = 0x02,
FDC2214_Channel_3 = 0x03
}FDC2214_channel_t;
typedef enum
FDC2214_Channel_Sequence_0_1 = 0x00,
FDC2214_Channel_Sequence_0_1_2 = 0x01,
FDC2214_Channel_Sequence_0_1_2_3 = 0x02,
}FDC2214_channel_sequence_t;
typedef enum
FDC2214_Bandwidth_1M = 0x01, //1MHz
FDC2214_Bandwidth_3_3M = 0x04, //3.3MHz
FDC2214_Bandwidth_10M = 0x05, //10MHz
FDC2214_Bandwidth_33M = 0x07 //33MHz
}FDC2214_filter_bandwidth_t;
typedef enum
FDC2214_Drive_Current_0_016 = 0x00, //0.016mA
FDC2214_Drive_Current_0_018 = 0x01, //0.018mA
FDC2214_Drive_Current_0_021 = 0x02, //0.021mA
FDC2214_Drive_Current_0_025 = 0x03, //0.025mA
FDC2214_Drive_Current_0_028 = 0x04, //0.028mA
FDC2214_Drive_Current_0_033 = 0x05, //0.033mA
FDC2214_Drive_Current_0_038 = 0x06, //0.038mA
FDC2214_Drive_Current_0_044 = 0x07, //0.044mA
FDC2214_Drive_Current_0_052 = 0x08, //0.052mA
FDC2214_Drive_Current_0_060 = 0x09, //0.060mA
FDC2214_Drive_Current_0_069 = 0x0A, //0.069mA
FDC2214_Drive_Current_0_081 = 0x0B, //0.081mA
FDC2214_Drive_Current_0_093 = 0x0C, //0.093mA
FDC2214_Drive_Current_0_108 = 0x0D, //0.108mA
FDC2214_Drive_Current_0_126 = 0x0E, //0.126mA
FDC2214_Drive_Current_0_146 = 0x0F, //0.146mA
FDC2214_Drive_Current_0_169 = 0x10, //0.169mA
FDC2214_Drive_Current_0_196 = 0x11, //0.196mA
FDC2214_Drive_Current_0_228 = 0x12, //0.228mA
FDC2214_Drive_Current_0_264 = 0x13, //0.264mA
FDC2214_Drive_Current_0_307 = 0x14, //0.307mA
FDC2214_Drive_Current_0_356 = 0x15, //0.356mA
FDC2214_Drive_Current_0_413 = 0x16, //0.413mA
FDC2214_Drive_Current_0_479 = 0x17, //0.479mA
FDC2214_Drive_Current_0_555 = 0x18, //0.555mA
FDC2214_Drive_Current_0_644 = 0x19, //0.644mA
FDC2214_Drive_Current_0_747 = 0x1A, //0.747mA
FDC2214_Drive_Current_0_867 = 0x1B, //0.867mA
FDC2214_Drive_Current_1_006 = 0x1C, //1.006mA
FDC2214_Drive_Current_1_167 = 0x1D, //1.167mA
FDC2214_Drive_Current_1_354 = 0x1E, //1.354mA
FDC2214_Drive_Current_1_571 = 0x1F //1.571mA
}FDC2214_drive_current_t;
void FDC2214_Write16(uint8_t Slve_Addr, uint8_t reg, uint16_t data);
uint16_t FDC2214_Read16(uint8_t Slve_Addr, uint8_t reg);
uint8_t FDC2214_GetChannelData(FDC2214_channel_t channel, uint32_t *data);
void FDC2214_SetRcount(FDC2214_channel_t channel, uint16_t rcount);
void FDC2214_SetSettleCount(FDC2214_channel_t channel, uint16_t count);
void FDC2214_SetChannelClock(FDC2214_channel_t channel, uint8_t frequency_select, uint16_t divider);
void FDC2214_SetINTB(uint8_t mode);
void FDC2214_SetActiveChannel(FDC2214_channel_t channel);
void FDC2214_SetSleepMode(uint8_t mode);
void FDC2214_SetCurrentMode(uint8_t mode);
void FDC2214_SetClockSource(uint8_t src);
void FDC2214_SetHighCurrentMode(uint8_t mode);
void FDC2214_SetMUX_CONFIG(uint8_t autoscan, FDC2214_channel_sequence_t channels, FDC2214_filter_bandwidth_t bandwidth);
void FDC2214_Reset(void);
void FDC2214_SetDriveCurrent(FDC2214_channel_t channel, FDC2214_drive_current_t current);
double FDC2214_CalculateFrequency(FDC2214_channel_t channel, uint32_t datax);
double FDC2214_CalculateCapacitance(double frequency, float inductance, float capacitance);
uint8_t FDC2214_Init(void);
void FDC2214_init(void);
void FDC_IIC_Init(void);
void FDC_IIC_Start(void);
void FDC_IIC_Stop(void);
u8 FDC_IIC_Wait_Ack(void);
void FDC_IIC_Ack(void);
void FDC_IIC_NAck(void);
void FDC_IIC_Send_Byte(u8 dat);
u8 FDC_IIC_Read_Byte(u8 ack);
void delay_2us(void);
#endif
2214.zip
2020-3-28 09:31 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
5.99 KB, 下載次數(shù): 9, 下載積分: 黑幣 -5
