仿真沒(méi)有PM2.5傳感器,用可調(diào)電阻代替
2020-3-29 13:59 上傳
- 51單片機(jī) 1602+ADC0832顯示程序,用proteus 7.8仿真通過(guò)。
- #include <reg52.h>
- #include<intrins.h>
- #include<math.h>
- #include <stdio.h>
- char data str[]=" ";
- /**********LCD1602接口程序**********/
- #define DD P2
- sbit Rs=P3^0;
- sbit Rw=P3^1;
- sbit E=P3^2;
- sbit qaz=P1^0;
- sbit wsx=P1^1;
- void delay_1ms(unsigned char i) //最小延時(shí)1ms
- unsigned char j;
- while(i--)
- for(j=0;j<125; j++);
- void delay_10us(unsigned char i) //最小延時(shí)10us
- unsigned char j;
- while(i--)
- for(j=0;j<10; j++);
- void write_com(unsigned char com) //寫(xiě)指令
- delay_10us(5);
- E=0;
- Rs=0;
- Rw=0;
- DD=com;
- delay_10us(50); //>40us
- E=1;
- delay_1ms(2); //>150us
- E=0;
- delay_10us(4); //>25+10us
- void write_data(unsigned char DATA) //寫(xiě)數(shù)據(jù)
- delay_10us(50);
- E=0;
- Rs=1;
- Rw=0;
- DD=DATA;
- delay_10us(50);
- E=1;
- delay_10us(50);
- E=0;
- delay_10us(4);
- void addr_x_y(unsigned char x,bit y) //寫(xiě)坐標(biāo),定位置
- unsigned char temp=0x80; //默認(rèn)最高位:D7為1 即以0x80開(kāi)始。
- if(y) //y :0為第一行 1為第二行
- temp|=0x40;
- temp|=x;
- write_com(temp);
- void Show_Char(unsigned char x,bit y,unsigned char p)
- //在指定位置顯示一個(gè)字符。
- addr_x_y(x,y);
- write_data(p);
- void Show_String(unsigned char x,bit y,char *ptr)
- unsigned char i;
- for (i=0;i<16;i++)
- Show_Char(x++,y,*(ptr+i));//循環(huán)顯示16個(gè)字符
- void init(void) //1602初始化代碼
- delay_1ms(1500);
- write_com(0x38);
- delay_1ms(5);
- write_com(0x38);
- delay_1ms(5);
- write_com(0x38);
- delay_1ms(5);
- write_com(0x38);
- write_com(0x08);
- write_com(0x06);
- write_com(0x0c);
- write_com(0x01);
- void xs_int(unsigned int shuju,bit t) //數(shù)據(jù)顯示
- unsigned char huancun[6]={0};
- unsigned char biaozhi=0,i;
- if (shuju < 10) biaozhi = 1;
- else if(shuju < 100) biaozhi = 2;
- else if(shuju < 1000) biaozhi = 3;
- else if(shuju < 10000) biaozhi = 4;
- else if(shuju < 65535) biaozhi = 5;
- switch(biaozhi) //這里沒(méi)有break,因此從標(biāo)識(shí)匹配的入口直接執(zhí)行到最后,完成整數(shù)各位的提取到數(shù)組。
- case 5:huancun[5] = shuju/10000;
- case 4:huancun[4] = shuju%10000/1000;
- case 3:huancun[3] = shuju%1000/100;
- case 2:huancun[2] = shuju%100/10;
- case 1:huancun[1] = shuju%10; break;
- default:break;
- for(i=0;i<6;i++)
- if(i==3)Show_Char(i,1,'.'); //加入小數(shù)點(diǎn),縮小了10000倍,因此AD采樣后的值需要乘上10000*5V/256=196(V)
- else Show_Char(i,t,0x30+huancun[6-i-1]);
- Show_Char(6,t,'0');
- /**********ADC0832接口程序************************************/
- sbit ADC_CS =P3^4;
- sbit ADC_CLK=P3^5;
- sbit ADC_DO =P3^6;
- sbit ADC_DI =P3^7;
- void Delay(unsigned char j)
- unsigned char i;
- for(i=0;i<j;i++); //延時(shí),脈沖一位持續(xù)的時(shí)間
- unsigned char ADC0832(void) //把模擬電壓值轉(zhuǎn)換成8位二進(jìn)制數(shù)并返回
- unsigned char i,data_c;
- data_c=0;
- ADC_CS=0;
- ADC_CLK=1;
- ADC_DO=0;//片選,DO為高阻態(tài)
- //ADC_DI=0; //先拉低
- for(i=0;i<10;i++)
- ADC_CLK=0;
- Delay(2);
- ADC_CLK=1;
- ADC_DI=1; //啟始位
- Delay(2);
- ADC_CLK=0; //第一個(gè)脈沖下降沿,DI=1為起始位
- Delay(2);
- ADC_CLK=1;
- ADC_DI=1; //1
- Delay(2);
- ADC_CLK=0; //第二個(gè)脈沖下降沿,DI=1
- Delay(2);
- ADC_DI=1; //1 若為0則選擇CH0
- ADC_CLK=1;
- Delay(2);
- ADC_CLK=0; //第三個(gè)脈沖下降沿,DI=1,選擇 ADC0832 的CH1(1 1)
- Delay(2);
- ADC_DI=1; //已不關(guān)心
- ADC_DO=1; //高阻
- ADC_CLK=1;
- Delay(2);
- for (i=0; i<8; i++)
- ADC_CLK=0; //第四個(gè)開(kāi)始讀數(shù)據(jù)
- Delay(2);
- data_c=(data_c<<1)|ADC_DO;//在每個(gè)脈沖的下降沿DO輸出一位數(shù)據(jù),最終ch為8位二進(jìn)制數(shù)
- ADC_CLK=1;
- Delay(2);
- ADC_CS=1;//取消片選,一個(gè)轉(zhuǎn)換周期結(jié)束
- return(data_c);//把轉(zhuǎn)換結(jié)果返回
- void main(void)
- unsigned int data_temp=0;
- qaz=0;
- wsx=0;
- while(1)
- data_temp=ADC0832();
- sprintf(str,"Air quality is:"); //the first line
- init();
- Show_String(0,0,str);
- xs_int(196*data_temp,1); //10000*5V/256=196(V),把采樣值放大10000倍后再處理,移動(dòng)小數(shù)點(diǎn)4位。 4位有效數(shù)字,其實(shí)用不到,因?yàn)?位采樣精度為:0.019V
- delay_1ms(500);
- if(196*data_temp>20000)
- qaz=1;
- else
- qaz=0;
- if(196*data_temp>40000)
- wsx=1;
- else
- wsx=0;
f.zip
(85.41 KB, 下載次數(shù): 51)
2020-3-29 09:18 上傳
點(diǎn)擊文件名下載附件
