查看: 3026|回復: 1
為什么stm32一直卡死在發(fā)送中斷
ID:328334 發(fā)表于 2020-3-30 23:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
問題: 發(fā)送完信息后,卡死在發(fā)送中斷,無法返回主程序
配置程序如下
  1. #include "busart.h"
  2. static void NVIC_Configuration(void)
  3. {
  4.     NVIC_InitTypeDef NVIC_InitStructure;
  5.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  6.     NVIC_InitStructure.NVIC_IRQChannel = DEBUG_USART_IRQ;
  7.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  8.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  9.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  10.     NVIC_Init(&NVIC_InitStructure);
  11. }
  12. void USART_Config(void)
  13. {
  14.         GPIO_InitTypeDef GPIO_InitStructure;
  15.         USART_InitTypeDef USART_InitStructure;
  16.         DEBUG_USART_GPIO_APBxClkCmd(DEBUG_USART_GPIO_CLK, ENABLE);
  17.         DEBUG_USART_APBxClkCmd(DEBUG_USART_CLK, ENABLE);
  18.         GPIO_InitStructure.GPIO_Pin = DEBUG_USART_TX_GPIO_PIN;
  19.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  20.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  21.         GPIO_Init(DEBUG_USART_TX_GPIO_PORT, &GPIO_InitStructure);
  22.         GPIO_InitStructure.GPIO_Pin = DEBUG_USART_RX_GPIO_PIN;
  23.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  24.         GPIO_Init(DEBUG_USART_RX_GPIO_PORT, &GPIO_InitStructure);
  25.
  26.         USART_InitStructure.USART_BaudRate = DEBUG_USART_BAUDRATE;
  27.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  28.         USART_InitStructure.USART_StopBits = USART_StopBits_1;
  29.         USART_InitStructure.USART_Parity = USART_Parity_No ;
  30.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  31.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  32.         USART_Init(DEBUG_USARTx, &USART_InitStructure);
  33.         NVIC_Configuration();
  34.         USART_ITConfig(DEBUG_USARTx, USART_IT_RXNE, ENABLE);
  35.         USART_Cmd(DEBUG_USARTx, ENABLE);
  36. }
  37. void Usart_SendByte(USART_TypeDef* pUSARTx, uint8_t data)
  38. {
  39.         USART_SendData(pUSARTx, data);
  40.         while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET );
  41. }
  42. void Usart_SendHalfWord(USART_TypeDef* pUSARTx, uint16_t data)
  43. {
  44.         uint8_t temp_h,temp_l;
  45.
  46.         temp_h = (data&0xff00) >> 8 ;
  47.         temp_l = data&0xff;
  48.
  49.         USART_SendData(pUSARTx, temp_h);
  50.         while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET );
  51.
  52.         USART_SendData(pUSARTx, temp_l);
  53.         while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET );
  54. }
  55. void Usart_SendArray(USART_TypeDef* pUSARTx, uint8_t *array,uint8_t num)
  56. {
  57.         uint8_t i;
  58.         for( i=0; i<num; i++ )
  59.   {
  60.                 Usart_SendByte(pUSARTx, array[i]);
  61.         }
  62.         while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TC) == RESET );
  63. }
  64. void Usart_SendStr(USART_TypeDef* pUSARTx, uint8_t *str)
  65. {
  66.         uint8_t i=0;
  67.         do
  68.   {
  69.                 Usart_SendByte(pUSARTx, *(str+i));
  70.                 i++;
  71.         }while(*(str+i) != '\0');
  72.         while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TC) == RESET );
  73. }
復制代碼
中斷服務程序如下:
  1. void DEBUG_USART_IRQHandler(void)
  2. {
  3.   uint8_t ucTemp;
  4.         if(USART_GetITStatus(DEBUG_USARTx,USART_IT_RXNE)!=RESET)
  5.         {
  6.                 ucTemp = USART_ReceiveData(DEBUG_USARTx);
  7.     USART_SendData(DEBUG_USARTx,ucTemp);
  8.         }
  9. }
復制代碼
ID:719370 發(fā)表于 2020-3-31 11:12 | 只看該作者
沒有清除發(fā)送中斷標志
