2020-3-31 14:51 上傳
- #include <reg52.h>
- #include <intrins.h>
- #include <lcd12864.h>
- #include <delay.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define Dataport P1 //LCD數(shù)據(jù)線(xiàn)
- sbit RS=P2^2; // 數(shù)據(jù)\指令 選擇
- sbit RW=P2^1; // 讀\寫(xiě) 選擇
- sbit EN=P2^0; // 讀\寫(xiě)使能
- sbit cs1=P2^4; // 片選1
- sbit cs2=P2^3; // 片選2
- /* 定義中文字庫(kù) */
- unsigned char code Hzk[]={
- ///*-- 文字: 中 --*/
- ///*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- //0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
- //0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- void CheckState() //狀態(tài)檢查,LCD是否忙?
- uchar dat;
- RS=0;
- RW=1;
- do{
- Dataport=0x00;
- EN=1;
- dat=Dataport;
- EN=0;
- dat=0x80 & dat; //僅當(dāng)?shù)?位為0時(shí)才可操作(判別busy信號(hào))
- }while(!(dat==0x00));
- SendCommandToLCD(uchar command) //寫(xiě)命令到LCD中
- CheckState();
- RS=0; //向LCD發(fā)送命令
- RW=0;
- Dataport=command; //command :命令
- EN=1;
- EN=0;
- void SetLine(uchar page) //設(shè)置頁(yè) 0xb8是頁(yè)的首地址
- page=0xb8|page; //1011 1xxx 0<=page<=7 設(shè)定頁(yè)地址--X 0-7,8行為一頁(yè)64/8=8,共8頁(yè)
- SendCommandToLCD(page);
- void SetStartLine(uchar startline) //設(shè)定顯示開(kāi)始行,0xc0是行的首地址
- startline=0xc0|startline; //1100 0000
- SendCommandToLCD(startline); //設(shè)置從哪行開(kāi)始:0--63,一般從0 行開(kāi)始顯示
- void SetColumn(uchar column) //設(shè)定列地址--Y 0-63 ,0x40是列的首地址
- column=column &0x3f; //column最大值為64,越出 0=<column<=63
- column= 0x40|column; //01xx xxxx
- SendCommandToLCD(column);
- void SetOnOff(uchar onoff) //開(kāi)關(guān)顯示,0x3f是開(kāi)顯示,0x3e是關(guān)顯示
- onoff=0x3e|onoff; //0011 111x,onoff只能為0或者1
- SendCommandToLCD(onoff);
- void WriteByte(uchar dat) //寫(xiě)顯示數(shù)據(jù)
- CheckState();
- RS=1;
- RW=0;
- Dataport=dat;//dat:顯示數(shù)據(jù)
- EN=1;
- EN=0;
- void SelectScreen(uchar screen) //選擇屏幕screen: 0-全屏,1-左屏,2-右屏
- switch(screen)
- { case 0: cs1=0;//全屏
- _nop_(); _nop_(); _nop_();
- cs2=0;
- break;
- case 1: cs1=0;//左屏
- cs2=1;
- break;
- case 2: cs1=1;//右屏
- cs2=0;
- break;
- void ClearScreen(uchar screen) //清屏screen: 0-全屏,1-左屏,2-右
- unsigned char i,j;
- SelectScreen(screen);
- for(i=0;i<8;i++) //控制頁(yè)數(shù)0-7,共8頁(yè)
- SetLine(i);
- SetColumn(0);
- for(j=0;j<64;j++) //控制列數(shù)0-63,共64列
- WriteByte(0x00); //寫(xiě)點(diǎn)內(nèi)容,列地址自動(dòng)加1
- void lcd_rol() //向上滾屏
- uint i;
- for(i = 0; i < 64; i++)
- cs1=0; // 片選1
- SendCommandToLCD(0xc0+i);
- cs1=1;
- cs2=0;// 片選2
- SendCommandToLCD(0xc0+62-i);
- cs2=0; // 片選2
- delay_ms(6);
- void InitLCD( ) //初始化LCD
- CheckState();
- SelectScreen(0);
- SetOnOff(0); //關(guān)顯示
- SelectScreen(0);
- SetOnOff(1); //開(kāi)顯示
- SelectScreen(0);
- ClearScreen(0);//清屏
- SetStartLine(0); //開(kāi)始行:0
- //顯示全角漢字
- void Display(uchar ss,uchar page,uchar column,uchar number) //Display(2,0,i*16,i);
- uint i; //選屏參數(shù),pagr選頁(yè)參數(shù),column選列參數(shù),number選第幾漢字輸出
- SelectScreen(ss);
- column=column&0x3f;
- SetLine(page); //寫(xiě)上半頁(yè)
- SetColumn(column); //控制列
- for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
- WriteByte(Hzk[i+32*number]); //i+32*number漢字的前16個(gè)數(shù)據(jù)輸出
- SetLine(page+1); //寫(xiě)下半頁(yè)
- WriteByte(Hzk[i+32*number+16]); //i+32*number+16漢字的后16個(gè)數(shù)據(jù)輸出
- //顯示半角漢字和數(shù)字和字母
- void Displayen(uchar ss,uchar page,uchar column,uchar number)
- SelectScreen(ss);
- for(i=0;i<8;i++)
- WriteByte(Ezk[i+16*number]);
- for(i=0;i<8;i++)
- WriteByte(Ezk[i+16*number+8]);
- void Dis_Play()
- uchar i;
- SetStartLine(0);
- for(i=0;i<4;i++)
- Display(0,0,i*16,i);
- Display(1,0,i*16,i+4);
- Display(2,0+2,i*16,i+8);
- Display(1,0+2,i*16,i+12);
- Display(2,0+2+2,i*16,i+16);
- Display(1,0+2+2,i*16,i+20);
- // Display(2,0+2+2+2,i*16,i+24);
- // Display(1,0+2+2+2,i*16,i+28);
- for(i=0;i<8;i++)
- Displayen(2,0+2+2+2,i*8,i);
- Displayen(1,0+2+2+2,i*8,i+8);
- while(1)
- lcd_rol();
- for(i=0;i<2*5;i++)
- delay_ms(500);
LCD12864.rar
(101.36 KB, 下載次數(shù): 34)
2020-3-31 14:28 上傳
點(diǎn)擊文件名下載附件
51LCD仿真與C程序 下載積分: 黑幣 -5
