查看: 2666|回復(fù): 6
STC12C5A60S2單片機(jī)控制LCD12864顯示的萬年歷出現(xiàn)顯示問題。求大佬幫助,真捉急!
ID:163090 發(fā)表于 2020-4-3 18:27 | 顯示全部樓層 |閱讀模式
還有就是初始化ds1302以后,讀寫時間函數(shù)好像都沒有問題,但是屏幕上時間總是顯示不對。不知道是程序哪里出了問題,以下是主程序,請大佬幫幫忙看看,下圖就是顯示出現(xiàn)的問題
  名稱:12864字庫液晶顯示
  內(nèi)容:通過顯示字符、數(shù)字、漢字和圖片測試液晶基本功能
------------------------------------------------*/ IMG_20200403_172042.jpg IMG_20200403_172042.jpg
#include <stc12c5a60s2.h>
#include <intrins.h>
#include "delay.h"
sbit RS = P2^5;
sbit RW = P2^6;
sbit E  = P2^7;
sbit RES = P1^7;
sbit PSB = P1^6;
sbit beep = P3^7;
#define DataPort P0        //MCU P0<------> LCM
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           無符號8位整型變量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符號8位整型變量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           無符號16位整型變量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符號16位整型變量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           無符號32位整型變量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符號32位整型變量 */
typedef float          F32;      /* single precision floating point variable (32bits) 單精度浮點數(shù)(32位長度) */
typedef double         F64;      /* double precision floating point variable (64bits) 雙精度浮點數(shù)(64位長度) */
#define   Data_0_time    4
//----------------IO口定義區(qū)--------------------//
sbit  P2_0  = P2^0 ;
//----------------定義區(qū)--------------------//
U8  U8FLAG,k;
U8  U8count,U8temp;
U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8comdata;
U8 flag;
U8 jishi_flag = 0,count_up = 0;
unsigned char count=0,ss=0,sg=0,fs=0,fg=0,ms=0,mg=0,m=0,f=0,s=0,yue=1,ri=1;
unsigned char str1[]={"溫度:00%"},str2[2],str3[]={"濕度:00%"},str4[2],dat=1,cal[10]={"0001-01-01"};
//初始時間定義
uchar  time_buf[9] = {0x20,0x20,0x04,0x02,0x18,0x04,0x00,0x04};
//DS1302引腳定義
sbit RST=P3^5;
sbit IO=P3^4;
sbit SCK=P3^6;
//DS1302地址定義
#define ds1302_sec_add                        0x80                //秒數(shù)據(jù)地址
#define ds1302_min_add                        0x82                //分?jǐn)?shù)據(jù)地址
#define ds1302_hr_add                        0x84                //時數(shù)據(jù)地址
#define ds1302_date_add                        0x86                //日數(shù)據(jù)地址
#define ds1302_month_add                0x88                //月數(shù)據(jù)地址
#define ds1302_day_add                        0x8a                //星期數(shù)據(jù)地址
#define ds1302_year_add                        0x8c                //年數(shù)據(jù)地址
#define ds1302_control_add                0x8e                //控制數(shù)據(jù)地址
#define ds1302_charger_add                0x90
#define ds1302_clkburst_add                0xbe
#define Rds1302_year_add                 0x8d
#define Rds1302_month_add              0x89
#define Rds1302_date_add                 0x87
#define Rds1302_hr_add                    0x85
#define Rds1302_min_add                  0x83
#define Rds1302_sec_add                   0x81
#define Rds1302_day_add                  0x8b
void SetNormalMode();
void Delay18ms()                //@11.0592MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 1;
        j = 194;
        k = 159;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void Delay10us()                //@11.0592MHz
        unsigned char i;
        _nop_();
        _nop_();
        _nop_();
        i = 24;
        while (--i);
//向DS1302寫入一字節(jié)數(shù)據(jù)
void ds1302_write_byte(uchar addr, uchar d)
        uchar i;
        RST=1;                                        //啟動DS1302總線
        _nop_();                                        //寫入目標(biāo)地址:addr
        //addr = addr & 0xFE;   //最低位置零,寄存器0位為0時寫,為1時讀
        for (i = 0; i < 8; i ++)
                IO=addr & 0x01;
                addr = addr >> 1;
                SCK=1;
                SCK=0;      //產(chǎn)生時鐘
        //寫入數(shù)據(jù):d
        for (i = 0; i < 8; i ++) {
                        IO=d & 0x01;
                d = d >> 1;
                        SCK=1;
                        SCK=0;    //產(chǎn)生時鐘
        RST=0;                //停止DS1302總線
                SCK=1;           /*時鐘線拉高*/
                //IO=1;    /*總線釋放*/
//從DS1302讀出一字節(jié)數(shù)據(jù)
uchar ds1302_read_byte(uchar addr) {
        uchar i,dat,temp;
        RST=1;                                        //啟動DS1302總線
        //addr = addr | 0x01;    //最低位置高,寄存器0位為0時寫,為1時讀
                IO=addr & 0x01;
                addr = addr >> 1;
                SCK=1;
                SCK=0;      //產(chǎn)生時鐘
        //輸出數(shù)據(jù):temp
           temp=IO;
           dat = (dat>>1) | (temp<<7);
           SCK=1;
           SCK=0;
        RST=0;                                        //停止DS1302總線
        _nop_();
                _nop_();
        return dat;
//從DS302讀出時鐘數(shù)據(jù)
void ds1302_read_time(void)
        time_buf[1]=ds1302_read_byte(Rds1302_year_add);                //年
        time_buf[2]=ds1302_read_byte(Rds1302_month_add);                //月
        time_buf[3]=ds1302_read_byte(Rds1302_date_add);                //日
        time_buf[4]=ds1302_read_byte(Rds1302_hr_add);                //時
        time_buf[5]=ds1302_read_byte(Rds1302_min_add);                //分
        time_buf[6]=ds1302_read_byte(Rds1302_sec_add);//&0x3f;//秒,屏蔽秒的第7位,避免超出59
        time_buf[7]=ds1302_read_byte(Rds1302_day_add);                //周
//DS1302初始化函數(shù)
void ds1302_init(void)
        //RST=0;                        //RST腳置低
//        SCK=0;                        //SCK腳置低
        //向DS302寫入時鐘數(shù)據(jù)
        ds1302_write_byte(ds1302_control_add,0x00);                        //關(guān)閉寫保護(hù)
        //ds1302_write_byte(ds1302_sec_add,0x80);                                //暫停時鐘
        ds1302_write_byte(ds1302_charger_add,0xa9);            //涓流充電
        ds1302_write_byte(ds1302_year_add,time_buf[1]);                //年
        ds1302_write_byte(ds1302_month_add,time_buf[2]);        //月
        ds1302_write_byte(ds1302_date_add,time_buf[3]);                //日
        ds1302_write_byte(ds1302_hr_add,time_buf[4]);                //時
        ds1302_write_byte(ds1302_min_add,time_buf[5]);                //分
        ds1302_write_byte(ds1302_sec_add,time_buf[6]);                //秒
        ds1302_write_byte(ds1302_day_add,time_buf[7]);                //周
        //ds1302_write_byte(0xc0,0xaa);
        ds1302_write_byte(ds1302_control_add,0x80);                        //打開寫保護(hù)
unsigned char code user16x16[]={ //笑臉圖片
0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
unsigned char code pic1[]=      // 圖片代碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code num[11][64]={
{// 圖片數(shù)字0
0x00,0x00,0x3F,0xFC,0x5F,0xFA,0x6F,0xF6,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x60,0x06,0x40,0x02,0x00,0x00,
0x40,0x02,0x60,0x06,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
0x70,0x0E,0x70,0x0E,0x70,0x0E,0x6F,0xF6,0x5F,0xFA,0x3F,0xFC,0x00,0x00,0x00,0x00},
{// 圖片數(shù)字1
0x00,0x00,0x00,0x20,0x00,0x60,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,
0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x60,0x00,0x20,0x00,0x00,0x00,0x20,
0x00,0x60,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,
0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x60,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00},
{// 圖片數(shù)字2
0x00,0x00,0x3F,0xFC,0x1F,0xFA,0x0F,0xF6,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x1F,0xFA,0x3F,0xFC,
0x5F,0xF8,0x60,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,
0x70,0x00,0x70,0x00,0x70,0x00,0x6F,0xF8,0x5F,0xFC,0x3F,0xFE,0x00,0x00,0x00,0x00},
{// 圖片數(shù)字3
0x1F,0xFA,0x00,0x06,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
0x00,0x0E,0x00,0x0E,0x00,0x0E,0x0F,0xF6,0x1F,0xFA,0x3F,0xFC,0x00,0x00,0x00,0x00},
{// 圖片數(shù)字4
0x00,0x00,0x40,0x02,0x60,0x06,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x60,0x06,0x5F,0xFA,0x3F,0xFC,
0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x00,0x02,0x00,0x00,0x00,0x00},
{// 圖片數(shù)字5
0x00,0x00,0x3F,0xFC,0x5F,0xF8,0x6F,0xF0,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,
0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x60,0x00,0x5F,0xF8,0x3F,0xFC,
{// 圖片數(shù)字6
0x5F,0xFA,0x60,0x06,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
{// 圖片數(shù)字7
0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x00,0x02,0x00,0x00,
0x00,0x02,0x00,0x06,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00},
{// 圖片數(shù)字8
{// 圖片數(shù)字9
0x00,0x0E,0x00,0x0E,0x00,0x0E,0x1F,0xF6,0x3F,0xFA,0x7F,0xFC,0x00,0x00,0x00,0x00},
{// 圖片":"        10
//6X6方點
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x07,0xE0,
0x07,0xE0,0x07,0xE0,0x07,0xE0,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x07,0xE0,0x07,0xE0,0x07,0xE0,
0x07,0xE0,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
unsigned char code kongbai[]=
                    檢測忙位
void init_timer()
        TMOD=0x01;//模式1,16位計時
        TH0=15536/256;
        TL0=15536%256;
        EA=1;
        ET0=1;
        TR0=1;
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙則等待
    E=0;
                   寫命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    寫數(shù)據(jù)
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延時程序
   PSB=1;                 //設(shè)置為8BIT并口工作模式
   DelayMs(1);            //延時
   RES=0;                 //復(fù)位
   DelayMs(1);            //延時
   RES=1;                 //復(fù)位置高
   DelayMs(10);
   Write_Cmd(0x30);       //選擇基本指令集
   DelayUs2x(50);         //延時大于100us
   Write_Cmd(0x30);       //選擇8bit數(shù)據(jù)流
   DelayUs2x(20);         //延時大于37us
   Write_Cmd(0x0c);       //開顯示(無游標(biāo)、不反白)
   Write_Cmd(0x01);       //清除顯示,并且設(shè)定地址指針為00H
   DelayMs(15);           //延時大于10ms
   //Write_Cmd(0x06);       //指定在資料的讀取及寫入時,設(shè)定游標(biāo)的移動方向及指定顯示的移位,光標(biāo)從右向左加1位移動
                   用戶自定義字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
     for(i=0;i<16;i++)
            Write_Data(user16x16[i*2]);
        Write_Data(user16x16[i*2+1]);
                   顯示用戶自定義字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
    Write_Data(00);
    Write_Data(00);
                   顯示字符串
x:橫坐標(biāo)值,范圍0~8
y:縱坐標(biāo)值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char *s)
        SetNormalMode();
switch(y)
      default:break;
while(*s&&s)
      Write_Data(*s);
      s++;
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                   顯示圖片
void LCD_PutGraphic(unsigned char code *img)
int i,j;
//顯示上半屏內(nèi)容設(shè)置
   for(i=0;i<32;i++)
      Write_Cmd(0x80 + i); //SET  垂直地址 VERTICAL ADD
      Write_Cmd(0x80);     //SET  水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
//顯示下半屏內(nèi)容設(shè)置
   for(i=0;i<32;i++)
      Write_Cmd(0x88);     //SET 水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
                 設(shè)置到繪圖模式
void SetGraphicMode()
{   Write_Cmd(0x34);
   Write_Cmd(0x36);       //選擇8bit數(shù)據(jù)流 圖形模式
   DelayUs2x(20);
   Write_Cmd(0x30);       //選擇8bit數(shù)據(jù)流 圖形模式
   DelayUs2x(20);
void huatu(unsigned char x,unsigned char  *img)
        unsigned char i,j;
        SetGraphicMode();
        for(i=0;i<32;i++)
        {        //將屏幕分成上下兩個屏幕,上下兩個半屏幕的起始行列地址都是0x80,地址向后連續(xù)遞增
                if(i<16)                 //先寫入行地址,再寫入列地址 ,在連續(xù)寫入兩個字節(jié)數(shù)據(jù)
                {        //列地址的范圍是0~15,從0x80開始,最后一個列地址是0x80+15
                        Write_Cmd(0x80+16+i);   //行地址的范圍是0~31,從0x80開始,最后一個行地址是0x80+32
                        Write_Cmd(0x80+x);
                if(i>=16)
                        Write_Cmd(0x80+i-16);
                        Write_Cmd(0x88+x);
                for(j=0;j<2;j++)
                        Write_Data(*img);
                img++;
                 主程序
main()
        Init_ST7920();
        ds1302_init();  //DS1302初始化
        init_timer();
        SetGraphicMode();     //設(shè)置成繪圖模式
        LCD_PutGraphic(pic1);           //清屏
        beep = 0;
          ds1302_read_time();  //讀取時間
           cal[0] = (time_buf[0]>>4) + '0'; //年   cal[10]={"0001-01-01"};
           cal[1] = (time_buf[0]&0x0f) + '0';
           cal[2] = (time_buf[1]>>4) + '0';
           cal[3] = (time_buf[1]&0x0f) + '0';
           cal[5] = (time_buf[2]>>4) + '0'; //月
           cal[6] = (time_buf[2]&0x0f) + '0';
           cal[8] = (time_buf[3]>>4) + '0'; //日
           cal[9] = (time_buf[3]&0x0f) + '0';
           dat=(time_buf[7]&0x07); //星期
           ss=(time_buf[4]>>4); //時
           sg=(time_buf[4]&0x0f);
           fs=(time_buf[5]>>4); //分
           fg=(time_buf[5]&0x0f);
           ms=(time_buf[6]>>4); //秒
           mg=(time_buf[6]&0x0f);
        huatu(0,num[ss]);
        huatu(1,num[sg]);
        huatu(3,num[fs]);
        huatu(4,num[fg]);
        huatu(6,num[ms]);
        huatu(7,num[mg]);
         if(count>=5 && count<=15)
                  huatu(2,num[10]);   //繪畫出時鐘的冒號:
                         huatu(5,num[10]);
                 huatu(2,kongbai);
                huatu(5,kongbai);
           LCD_PutString(0,1,cal);
          LCD_PutString(0,4,str1);
          LCD_PutString(4,4,str3);
switch(dat)
                 case 1: LCD_PutString(5,1,"星期一");     break;
                 case 2:    LCD_PutString(5,1,"星期二");   break;
                 case 3:    LCD_PutString(5,1,"星期叁");   break;
                 case 4:    LCD_PutString(5,1,"星期四");   break;
                 case 5:    LCD_PutString(5,1,"星期五");   break;
                 case 6:    LCD_PutString(5,1,"星期六");   break;
                 case 7:    LCD_PutString(5,1,"星期天");   break;
                 default: break;
void Timer0_INT() interrupt 1   //count每次加1,定時50000 us
        TL0 = 0x00;                //設(shè)置定時初值
        TH0 = 0x4C;
        count++;
ID:648281 發(fā)表于 2020-4-4 12:13 | 顯示全部樓層
你好!
應(yīng)該是DS1302數(shù)據(jù)讀取錯誤造成的;
只能慢慢來找問題,一步步的去排查。
ID:163090 發(fā)表于 2020-4-5 17:04 來自手機(jī) | 顯示全部樓層
51hei**1140 發(fā)表于 2020-4-4 12:13
你好!
只能慢慢來找問題,一步步的去排查。
謝謝大佬解答!為什么時鐘和秒鐘的顯示是正常呢?如果1302芯片讀取有問題,那應(yīng)該都不會有顯示的
ID:584814 發(fā)表于 2020-4-6 09:45 | 顯示全部樓層
大概率是DS1302數(shù)據(jù)讀取錯誤造成的;可以在程序啟動時先寫入數(shù)據(jù)(設(shè)置那7個數(shù))然后財讀試試,國產(chǎn)的DS13xx不同批次各自都可能有些莫名其妙的問題(大牌的沒用過高價未必真貨所以沒試)。
ID:201555 發(fā)表于 2020-4-6 15:05 | 顯示全部樓層
你發(fā)個清一屏操作,看看。什么效果。
ID:447439 發(fā)表于 2022-1-2 23:41 | 顯示全部樓層
樓主還有嗎,我也是遇到相同問題了。請問解決了嗎?
ID:679211 發(fā)表于 2022-1-3 00:54 | 顯示全部樓層
根據(jù)經(jīng)驗感覺是時序問題,首先看看你單片機(jī)使用的是內(nèi)部時鐘還是外部時鐘,然后再根據(jù)時鐘來算算你給1302的延時函數(shù)的延時時間是否滿足DateSheet上的時序要求。
