這是我的代碼
#include "reg52.h"
#include "main.h"
#include "mfrc522.h"
#include <string.h>
//M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
//4字節(jié)金額(低字節(jié)在前)+4字節(jié)金額取反+4字節(jié)金額+1字節(jié)塊地址+1字節(jié)塊地址取反+1字節(jié)塊地址+1字節(jié)塊地址取反
unsigned char code data2[4] = {0x12,0,0,0};
unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
unsigned char g_ucTempbuf[20];
unsigned char idata MLastSelectedSnr[4];
unsigned char idata RevBuffer[30];
unsigned char data SerBuffer[20];
bit CmdValid;
void iccardcode()
unsigned char cmd;
unsigned char status;
cmd = RevBuffer[0];
switch(cmd)
case 1: // Halt the card //終止卡的操作
status= PcdHalt();;
RevBuffer[0]=1;
RevBuffer[1]=status;
break;
case 2: // Request,Anticoll,Select,return CardType(2 bytes)+CardSerialNo(4 bytes)
// 尋卡,防沖突,選擇卡 返回卡類型(2 bytes)+ 卡系列號(4 bytes)
status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
if(status!=0)
if(status!=0)
RevBuffer[0]=1;
break;
RevBuffer[0]=3;
break;
case 3: // 防沖突 讀卡的系列號 MLastSelectedSnr
status = PcdAnticoll(&RevBuffer[2]);
if(status!=0)
RevBuffer[0]=1;
break;
memcpy(MLastSelectedSnr,&RevBuffer[2],4);
RevBuffer[0]=5;
break;
case 4: // 選擇卡 Select Card
status=PcdSelect(MLastSelectedSnr);
if(status!=MI_OK)
RevBuffer[0]=1;
break;
RevBuffer[0]=3;
break;
case 5: // Key loading into the MF RC500's EEPROM
status = PcdAuthState(RevBuffer[1], RevBuffer[3], DefaultKey, MLastSelectedSnr);// 校驗卡密碼
RevBuffer[0]=1;
break;
case 6:
RevBuffer[0]=1;
break;
case 7:
RevBuffer[0]=1;
break;
case 8: // Read the mifare card
// 讀卡
status=PcdRead(RevBuffer[1],&RevBuffer[2]);
if(status==0)
{RevBuffer[0]=17;}
{RevBuffer[0]=1;}
break;
case 9: // Write the mifare card
// 寫卡 下載密碼
status=PcdWrite(RevBuffer[1],&RevBuffer[2]);
RevBuffer[0]=1;
break;
case 10:
PcdValue(RevBuffer[1],RevBuffer[2],&RevBuffer[3]);
RevBuffer[0]=1;
break;
case 12: // 參數(shù)設(shè)置
PcdBakValue(RevBuffer[1], RevBuffer[2]);
RevBuffer[0]=1; //contact
RevBuffer[1]=0;
break;
//系統(tǒng)初始化
void InitializeSystem()
P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
ET2 = 0;
T2CON = 0x04;
PCON = 0x80;
SCON = 0x70;
TMOD = 0x21; //TMOD = 0x22;
TH1 = BAUD_9600;
TL1 = TH1;
TR1 = 1; // 波特率發(fā)生器
TH0 = 0x60;
TL0 = 0x60;
TR0 = 0;
ET0=0;
ET1=0;
EA=1;
EX0=1;
IT0 = 1;
TR2=0;
ES = 1;
CmdValid=0;
LED_GREEN = 1;
PcdReset();
PcdAntennaOff();
PcdAntennaOn();
M500PcdConfigISOType( 'A' );
LED_GREEN = 0;
delay_10ms(10);
LED_GREEN = 1;
delay_10ms(10);
LED_GREEN = 0;
//用T2做延時子程序
// 接收和發(fā)送中斷
void isr_UART(void) interrupt 4 using 1
unsigned char len, i;
unsigned int j=0;
if(RI)
len=SBUF;
RI=0;
for(i=0;i<len;i++)
while(!RI)
j++;
if(j>1000)
break;
if(j<1000)
RevBuffer[i]=SBUF;
RI=0;
j=0;
break;
if(i==len)
REN=0;
CmdValid=1;
else if(!RI && TI)
TI=0;
len=RevBuffer[0];
for(i=0;i<len+1;i++)
SBUF=RevBuffer[i];
while(!TI);
TI=0;
REN=1;
void main( )
unsigned char baud;
InitializeSystem( );
while (1)
if (CmdValid)
CmdValid = FALSE;
if(RevBuffer[0]==11) //為了加快相應(yīng)速度 測試風(fēng)鳴器
RevBuffer[2]=RevBuffer[1];
RevBuffer[1]=0;
CALL_isr_UART();
LED_GREEN = 1;
delay_10ms(RevBuffer[2]);
LED_GREEN = 0;
else if(RevBuffer[0]==13) //設(shè)置通訊波特率
switch(RevBuffer[1])
case 0:
baud=BAUD_9600;
break;
case 1:
baud=BAUD_14400;
break;
case 2:
baud=BAUD_19200;
break;
case 3:
baud=BAUD_28800;
break;
case 4:
baud=BAUD_38400;
break;
case 5:
baud=BAUD_57600;
break;
case 6:
baud=BAUD_115200;
break;
default:
baud=BAUD_9600;
break;
RevBuffer[1]=0;
CALL_isr_UART();
delay_10ms(5);
TR1 = 0;
TH1 = baud;
TL1 = TH1;
delay_10ms(2);
TR1 = TRUE;
iccardcode();
CALL_isr_UART();
