查看: 3553|回復(fù): 0
MC96F6508A測溫程序(含線路圖,原碼,注解)
MC96F6508A測溫電路原理圖如下:
  1. /*****************************************************************
  2. *        *
  3. *   temperature              *
  4. *        *
  5. * MCU 芯片: MC96F6508A      工作頻率: 16MHz                    *
  6. ******************************************************************/
  7. #include <mc96f6508a.h>
  8. #include <intrins.h>
  9. #include        "MC96F6508A.h"
  10. #include        "func_def.h"
  11. #include    "lcd.h"
  12. #include   "temp.h"
  13.
  14. #define uchar unsigned char
  15. #define uint unsigned int
  16. void LcdDisplay(int);
  17. /*******************************************************************************
  18. * 函數(shù)名         : main
  19. * 函數(shù)功能                   : 主函數(shù)
  20. * 輸入           : 無
  21. * 輸出                  : 無
  22. *******************************************************************************/
  23. main()
  24. {
  25.         P1IO                = 0xff;                        // 輸出P1 Direction Register
  26.     P1OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
  27.     P1PU                = 0xff;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  28.     P1DB                = 0xff;                        //消抖
  29.
  30.         P2IO                = 0xf0;                        // 輸出P1 Direction Register
  31.     P2OD                = 0x00;                        //漏極開路輸出 P1 Open-drain Selection Register
  32.     P2PU                = 0xff;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  33.     P2FSR                = 0x00;                        //
  34.         P3IO                = 0xff;                        // 輸出P1 Direction Register
  35.     P3OD                = 0x00;                        //漏極開路輸出 P1 Open-drain Selection Register
  36.     P3PU                = 0xff;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  37.     P3FSR                = 0x00;                        //消抖
  38.
  39.
  40.         P4IO                = 0xff;                        // 輸出P1 Direction Register
  41.     P4OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
  42.     P4PU                = 0xff;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  43.     P4FSR                = 0x00;                        //消抖
  44.         P5IO                = 0xff;                        // 輸出P1 Direction Register
  45.     P5OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
  46.     P5PU                = 0xf0;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  47.     P5FSRH                = 0xff;                        //
  48.         P5FSRL                = 0xff;
  49.                 P6IO                = 0xff;                        // 輸出P1 Direction Register
  50.     P6OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
  51.     P6PU                = 0xff;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  52.     P6FSR                = 0x0f;                        // 設(shè)置為Xin/Xout
  53.
  54.         P0IO                = 0x00;                        // 輸出P1 Direction Register
  55.     P0OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
  56.     P0PU                = 0xff;                        // 內(nèi)部上拉電阻P1 Pull-up Resistor Selection Register
  57.     P0DB                = 0xff;                        //消抖
  58.
  59.         P4=0xff;
  60.                 // internal RC clock (16.000000MHz)
  61.         OSCCR = 0x08;           // Set Int. OSC
  62.         SCCR = 0x00;            // Use Int. OSC
  63.         //P4=0x00;
  64.         //DSPORT=0;
  65.         //OSCCR = 0x28;           // 外部主時鐘
  66.         //SCCR = 0x00;            // 打開外部主時鐘
  67.         LcdInit();                         //初始化LCD1602
  68.         LcdWriteCom(0x88);        //寫地址 80表示初始地址
  69.         LcdWriteData('C');
  70.         while(1)
  71.         {
  72.                 LcdDisplay(Ds18b20ReadTemp());
  73.                 //Delay1ms(1000);//1s鐘刷一次
  74.         }
  75. }
  76. /*******************************************************************************
  77. * 函數(shù)名         : LcdDisplay()
  78. * 函數(shù)功能                   : LCD顯示讀取到的溫度
  79. * 輸入           : v
  80. * 輸出                  : 無
  81. *******************************************************************************/
  82. void LcdDisplay(int temp)          //lcd顯示
  83. {
  84.
  85.           unsigned char datas[] = {0, 0, 0, 0, 0}; //定義數(shù)組
  86.         float tp;
  87.         if(temp< 0)                                //當(dāng)溫度值為負(fù)數(shù)
  88.           {
  89.                   LcdWriteCom(0x80);                //寫地址 80表示初始地址
  90.             LcdWriteData('-');                  //顯示負(fù)
  91.                 //因?yàn)樽x取的溫度是實(shí)際溫度的補(bǔ)碼,所以減1,再取反求出原碼
  92.                 temp=temp-1;
  93.                 temp=~temp;
  94.                 tp=temp;
  95.                 temp=tp*0.0625*100+0.5;
  96.                 //留兩個小數(shù)點(diǎn)就*100,+0.5是四舍五入,因?yàn)镃語言浮點(diǎn)數(shù)轉(zhuǎn)換為整型的時候把小數(shù)點(diǎn)
  97.                 //后面的數(shù)自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進(jìn)1了,小于0.5的就
  98.                 //算由?.5,還是在小數(shù)點(diǎn)后面。
  99.           }
  100.          else
  101.           {
  102.                   LcdWriteCom(0x80);                //寫地址 80表示初始地址
  103.             LcdWriteData('+');                 //顯示正
  104.                 tp=temp;//因?yàn)閿?shù)據(jù)處理有小數(shù)點(diǎn)所以將溫度賦給一個浮點(diǎn)型變量
  105.                 //如果溫度是正的那么,那么正數(shù)的原碼就是補(bǔ)碼它本身
  106.                 temp=tp*0.0625*100+0.5;
  107.                 //留兩個小數(shù)點(diǎn)就*100,+0.5是四舍五入,因?yàn)镃語言浮點(diǎn)數(shù)轉(zhuǎn)換為整型的時候把小數(shù)點(diǎn)
  108.                 //后面的數(shù)自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進(jìn)1了,小于0.5的就
  109.                 //算加上0.5,還是在小數(shù)點(diǎn)后面。
  110.         }
  111.         datas[0] = temp / 10000;
  112.         datas[1] = temp % 10000 / 1000;
  113.         datas[2] = temp % 1000 / 100;
  114.         datas[3] = temp % 100 / 10;
  115.         datas[4] = temp % 10;
  116.         LcdWriteCom(0x82);                  //寫地址 80表示初始地址
  117. ……………………
  118. …………限于本文篇幅 余下代碼請從51黑下載附件…………
temperature.zip (76.23 KB, 下載次數(shù): 16)
temperature.pdf (56.3 KB, 下載次數(shù): 16)
