查看: 1837|回復(fù): 1
單片機(jī)交通燈實(shí)驗(yàn)中添加LED屏幕后失效
原代碼,能實(shí)現(xiàn)動(dòng)態(tài)數(shù)碼管和LED交通燈的動(dòng)態(tài)顯示。
為增加LED顯示停和行,增加了LED代碼模塊,但增加后數(shù)碼管和LED交通燈均不亮,LED亂碼
請(qǐng)問(wèn)是哪里出問(wèn)題了。
運(yùn)行結(jié)果正常。
修改后代碼,紅色部分,程序無(wú)報(bào)錯(cuò),但數(shù)碼管和LED燈都不亮,LED點(diǎn)陣亂碼
#include "reg52.h"
#include "intrins.h"
typedef unsigned int u16;
typedef unsigned char u8;
#define led P0
#define light P1
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit GREEN00=P0^0;
sbit RED00=P0^1;
sbit GREEN10=P0^2;
sbit YELLOW10=P0^3;
sbit RED10=P0^4;
sbit GREEN11=P0^5;
sbit YELLOW11=P0^6;
sbit RED11=P0^7;
sbit GREEN01=P3^0;
sbit RED01=P3^1;
sbit SER=P2^7;
sbit SRCLK=P2^6;
sbit RCLK1=P2^5;
u8 code smg[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
u8 code duan2[]={0x80,0x60,0xF8,0x07,0x00,0x04,0x74,0x54,0x55,0x56,0x54,0x54,0x74,0x04,0x00,0x00,
0x00,0x00,0xFF,0x00,0x03,0x01,0x05,0x45,0x85,0x7D,0x05,0x05,0x05,0x01,0x03,0x00,};        //?
u8 code duan1[]={0x00,0x10,0x88,0xC4,0x33,0x00,0x40,0x42,0x42,0x42,0xC2,0x42,0x42,0x42,0x40,0x00,
0x02,0x01,0x00,0xFF,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,};        //??
u8 code wei[32]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,};
u8 Second=0;
u8 DisplayData[8];
void delay(u16 t);
void inter0();
void Display();
void LEDDZ(u8 dat1,u8 dat2,u8 dat3,u8 dat4);
void DZdisplay1();
void DZdisplay2();
{ u8 a;
  for(a=0;a<8;a++)
  { SER=dat1>>7;
    dat1=dat1<<1;
SRCLK=0;
_nop_();
SRCLK=1;
  for(a=0;a<8;a++)
  { SER=dat2>>7;
    dat2=dat2<<1;
SRCLK=0;
_nop_();
SRCLK=1;
  for(a=0;a<8;a++)
  { SER=dat3>>7;
    dat3=dat3<<1;
SRCLK=0;
_nop_();
SRCLK=1;
  for(a=0;a<8;a++)
  { SER=dat4>>7;
    dat4=dat4<<1;
SRCLK=0;
_nop_();
SRCLK=1;
  RCLK1=0;
  _nop_();
  RCLK1=1;
void DZdisplay1()
{ u8 i;
   { for(i=0;i<16;i++)
      {LEDDZ(~wei[i+16],~wei[ i],duan1[i+16],duan1[ i]);
    delay(10);}
void DZdisplay2()
{ u8 i;
   { for(i=0;i<16;i++)
      {LEDDZ(~wei[i+16],~wei[ i],duan2[i+16],duan2[ i]);
    delay(10);}
[ i][ i][ i]
void delay(u16 t)
{while(t--);}
void inter0()
{TMOD=0X01;
  TH0=0XFC;
  TL0=0X18;
  EA=1;
  ET0=1;
  TR0=1;
void Display()
{ u8 i;
   light=0x00;
   for(i=0;i<8;i++)
   { switch(i)
     {case(0):LSA=0;LSB=0;LSC=0;break;
   case(1):LSA=1;LSB=0;LSC=0;break;
   case(2):LSA=0;LSB=1;LSC=0;break;
   case(3):LSA=1;LSB=1;LSC=0;break;
   case(4):LSA=0;LSB=0;LSC=1;break;
   case(5):LSA=1;LSB=0;LSC=1;break;
   case(6):LSA=0;LSB=1;LSC=1;break;
   case(7):LSA=1;LSB=1;LSC=1;break;
  light=DisplayData[ i];
  delay(100);
  light=0x00;
{ inter0();
   {if(Second==70)
    Second=0;
if(Second<31)
    DisplayData[0]=0x00;
    DisplayData[1]=0x00;
    DisplayData[2]=smg[(30-Second)%100/10];
    DisplayData[3]=smg[(30-Second)%10];
    DisplayData[4]=0x00;
    DisplayData[5]=0x00;
    DisplayData[6]=DisplayData[2];
    DisplayData[7]=DisplayData[3];
    Display();
    DZdisplay2();
    led=0xff;
    GREEN01=1;
    RED01=1;
    GREEN00=0;
    GREEN10=0;
    RED11=0;
    RED01=0;
else if(Second<36)
    DisplayData[2]=smg[(36-Second)%100/10];
    DisplayData[3]=smg[(36-Second)%10];
    Display();
    led=0xff;
    GREEN01=1;
    RED01=1;
    RED00=0;
    YELLOW10=0;
    RED11=0;
    RED01=0;
else if(Second<66)
    DisplayData[2]=smg[(66-Second)%100/10];
    DisplayData[3]=smg[(66-Second)%10];
    Display();
    DZdisplay1();
    led=0xff;
    GREEN01=1;
    RED01=1;
    RED00=0;
    RED10=0;
    GREEN11=0;
    GREEN01=0;
    DisplayData[2]=smg[(71-Second)%100/10];
    DisplayData[3]=smg[(71-Second)%10];
    Display();
    led=0xff;
    GREEN01=1;
    RED01=1;
    RED00=0;
    RED10=0;
    YELLOW11=0;
    RED01=0;
void inter0in() interrupt 1
{ static u16 i;
   TH0=0XFC;
   TL0=0X18;
   i++;
   if(i==1000)
   {i=0;
    Second++;
ID:584814 發(fā)表于 2020-4-10 22:16 | 只看該作者
你查一下實(shí)驗(yàn)板的電路圖,極有可能是I/O口占用。
