查看: 3583|回復(fù): 0
51單片機(jī)智能窗簾設(shè)計(jì) 有程序和硬件電路圖PCB
ID:353033 發(fā)表于 2020-4-7 12:17 | 顯示全部樓層 |閱讀模式
Altium Designer畫的單片機(jī)智能窗簾原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1. #include <reg51.h>//51頭文件
  2. #include<INTRINS.h>
  4. #define uint  unsigned int //變量宏定義
  5. #define ulong  unsigned long //變量宏定義
  6. uchar count,s1num,shi2=0,fen2=0,shi3=10,fen3=10;//全局變量
  7. uchar miao,fen,shi;//時(shí)間變量
  8. uchar c,v,l,i;
  9. ulong AD_ad1,AD_ad2;
  10. float JiZhun_AD=2.5;
  11. float AD_Data=0.0;
  12. ulong AD_ad=0;
  13. uchar dianji;
  14. sbit rs = P0^5;//數(shù)據(jù),命令選擇端(H/L)
  15. sbit rw = P0^6;//讀,寫選擇端(H/L)
  16. sbit e = P0^7;//使能信號(hào)
  17. sbit CLOCK = P1^1; //lcd
  18. sbit D_IN  = P1^2; //lcd
  19. sbit D_OUT = P1^3; //lcd
  20. sbit _CS   = P1^4; //lcd
  21. sbit menu = P1^0;  //按鍵//P1^3
  22. sbit add  = P1^7;  //按鍵//P1^4
  23. sbit cut  = P1^5;  //按鍵
  24. sbit yes  = P1^6;  //按鍵
  25. sbit   ma = P3^0; //步進(jìn)電機(jī)
  26. sbit   mb = P3^1; //步進(jìn)電機(jī)
  27. sbit   mc = P3^2; //步進(jìn)電機(jī)
  28. sbit   md = P3^3; //步進(jìn)電機(jī)
  29. sbit led1 = P3^4; //LED1
  30. sbit led2 = P3^5; //LED2
  31. sbit spek = P3^6; //SPEK
  32. uchar code  table[]="shut-00:00|ray:0";
  33. uchar code table1[]="open-00:00|00:00";//數(shù)據(jù)字符表
  34. uchar data display[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  35. //顯示單元后臺(tái)數(shù)據(jù),1分2時(shí)現(xiàn)在時(shí)間,5分6時(shí)關(guān)閉時(shí)間,3分4時(shí)打開時(shí)間,7亮度級(jí)數(shù) //
  36. //****************延時(shí)*****************
  37. void delay(uint z)
  38. {
  39. uint x,y;
  40.   for(x=z;x>0;x--)
  41.    for(y=110;y>0;y--) ;
  42. }
  43. //****************寫液晶指令*****************
  44. void write_com(uchar com)
  45. {
  46. rs=0;
  47. e=0;
  48. P2=com;
  49. delay(5);
  50. e=1;
  51. delay(5);
  52. e=0;
  53. }
  54. //****************液晶數(shù)據(jù)*****************
  55. void write_date(uchar date)
  56. {
  57. rs=1;
  58. e=0;
  59. P2=date;
  60. delay(5);
  61. e=1;
  62. delay(5);
  63. e=0;
  64. }
  65. //****************初始化液晶定時(shí)器************
  66. void init() //
  67. {
  68. uchar num;
  69. rs=0;
  70. rw=0;
  71. e=0;//鎖存關(guān)閉
  72. write_com(0x38);
  73. delay(5);
  74. write_com(0x0c);//
  75. delay(5);
  76. write_com(0x06);
  77. delay(5);
  78. write_com(0x01);
  79. write_com(0x80);//第一行開始寫
  80.   for(num=0;num<16;num++)
  81.    {
  82.    write_date(table[num]);
  83.    delay(20);
  84.    }
  85.     write_com(0x80+0x40);//第二行前一部分,也就是時(shí)間開始寫
  86.    for(num=0;num<16;num++)
  87.    {
  88.      write_date(table1[num]);
  89.    delay(20);
  90.   }
  91. TMOD=0x01;//定時(shí)器0的方式1
  92. TH0=(65536-50000)/256;//求模
  93. TL0=(65536-50000)%256;//取余
  94. EA=1;//開總中斷
  95. ET0=1;//開定時(shí)器中斷
  96. TR0=1;//啟動(dòng)定時(shí)器
  97. }
  98. //****************地址數(shù)據(jù)變量**************
  99. void write_sfm(uchar add, uchar date)
  100. {
  101. uchar shi,ge;
  102. shi=date/10;
  103. ge=date%10;
  104. write_com(0x80+0x40+add);
  105. write_date(0x30+shi);
  106. write_date(0x30+ge);
  107. }
  108. void write_sfn(uchar add, uchar date)
  109. {
  110. uchar si,g;
  111. si=date/10;
  112. g=date%10;
  113. write_com(0x80+add);
  114. write_date(0x30+si);
  115. write_date(0x30+g);
  116. }
  117. //****************按鍵函數(shù)*****************
  118. void key()
  119. {
  120.   if(c==8)c=0;
  121.   if(menu==0)
  122.                 {
  123.                 delay(50);
  124.                 if(menu==0)
  125.                         {
  126.                         c++;spek=0;delay(50);
  127.                         while(menu==0);spek=1;
  128.                         }
  129.                 }
  130.    if(add==0)
  131.                    {
  132.                    spek=0;delay(50);
  133.                 while(add==0);
  134.                    spek=1;
  135.                    display[c]++;
  136.                 write_sfm(14,display[1]);//分針位置
  137.                 write_sfm(11,display[2]);//時(shí)針位置
  138.                    }
  139.         if(cut==0)
  140.                 {
  141.                 spek=0;delay(50);
  142.                 while(cut==0);
  143.                 spek=1;
  144.                 display[c]--;
  145.                 }
  146.         if(yes==0)
  147.                 {
  148.                 spek=0;delay(50);
  149.                 while(yes==0);
  150.                 spek=1;
  151.                 c=0;
  152.                 }
  153.   write_sfm(14,display[1]);//現(xiàn)在分針位置
  154.   write_sfm(11,display[2]);//現(xiàn)在時(shí)針位置
  155.   write_sfm(8,display[3]);//打開分針位置
  156.   write_sfm(5,display[4]);//打開分針位置
  157.   write_sfn(8,display[5]);//關(guān)閉分針位置
  158.   write_sfn(5,display[6]);//關(guān)閉分針位置
  159.   write_com(0x80+15);          //亮度級(jí)數(shù)
  160.   write_date(0x30+display[7]);//亮度級(jí)數(shù)位置
  161. }
  162. //****************步進(jìn)電機(jī)函數(shù)*****************
  163. void motorzen()
  164. {
  165.    while(v)
  166.                 {
  167.                 led1=0;
  168.                 ma=1,mb=0;mc=0;md=0;delay(3);
  169.                 ma=0,mb=1;mc=0;md=0;delay(3);
  170.                 ma=0,mb=0;mc=1;md=0;delay(3);
  171.                 ma=0,mb=0;mc=0;md=1;delay(3);
  172.                 }
  173.         led1=1;
  174. }
  175. void motorfan()
  176. {
  177.    while(v&l)
  178.                 {
  179.                 led2=0;
  180.                 ma=0,mb=0;mc=0;md=1;delay(3);
  181.                 ma=0,mb=0;mc=1;md=0;delay(3);
  182.                 ma=0,mb=1;mc=0;md=0;delay(3);
  183.                 ma=1,mb=0;mc=0;md=0;delay(3);
  184.                 }
  185.                 led2=1;
  186. }
  187. //****************A/D*****************
  188. uint read1543(uchar port)
  189.         {
  190.         uint ad;
  191.         uint i;
  192.         uchar al=0,ah=0;
  193.         CLOCK=0;
  194.         _CS=0;
  195.         port<<=4;
  196.         for (i=0;i<4;i++) //將四位通道地址送1543
  197.                 {
  198.                 D_IN=(bit)(port&0x80);CLOCK=1;CLOCK=0;
  199.                 port<<=1;
  200.                 }
  201.         for (i=0;i<6;i++) //填6個(gè)CLOCK信號(hào)
  202.                 {
  203.                 CLOCK=1;CLOCK=0;
  204.                 }
  205.         _CS=1;
  206.         _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
  207.         _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
  208.         _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
  209.         _nop_();_nop_();_nop_();
  210.         _CS=0; //等待AD轉(zhuǎn)換結(jié)束
  211.         _nop_();_nop_();_nop_();
  212. for (i=0;i<2;i++) //D9,D8
  213.                 {
  214.                 D_OUT=1;CLOCK=1;ah<<=1;
  215.                 if (D_OUT) ah +=0x01;
  216.                 CLOCK=0;
  217.                 }
  218.         for (i=0;i<8;i++) //取出D7--D0
  219.                 {
  220.                 D_OUT=1;CLOCK=1;al <<= 1;
  221.                 if (D_OUT)
  222.                 al +=0x01;
  223.                 CLOCK=0;
  224.                 }
  225. _CS=1;
  226. ad = (uint)ah;
  227. ad <<= 8;
  228. ad +=(uint)al; //
  229. return(ad);
  230. }
  231. //****************亮度測(cè)試*****************
  232. void liangdu()
  233. {
  234.         i++;
  235.         if(i==30)
  236.                  {
  237.                  i=0;
  238.                  AD_ad1 = read1543(0);   //          (通道0電壓正端)
  239.                  AD_Data = ((float)AD_ad1)*JiZhun_AD*2/1024+0.005;//0.15經(jīng)過實(shí)測(cè)需要加0.15減少誤差
  240.                  AD_ad =(AD_Data*100);
  241.                  if(display[7]>AD_ad%100/10)
  242.                            {
  243.                          if(dianji==0)
  244.                                  {
  245.                                  spek=0;delay(50);spek=1;
  246.                                  motorzen();
  247.                                 dianji=1;
  248.                              }
  249.                             }
  250.                 else
  251.                            {
  252.                          if(dianji==1)
  253.                                  {
  254.                                  spek=0;delay(50);spek=1;
  255.                                  motorfan();
  256.                                 dianji=0;
  257.                             }
  258.                             }
  259.                 }
  260.   }
  261. //****************主函數(shù)*****************
  262. void main()
  263. {
  264. spek=0;delay(50);spek=1;
  265. display[4]=8;
  266. display[6]=20;
  267. display[7]=50;
  268. spek=1;
  269. init();
  270. while(1)
  271.    {
  272.    key();liangdu();
  273.         if(display[2]==display[4])//時(shí)間判斷關(guān)閉窗簾
  274.                 {
  275.                  if(display[1]==display[3])//與打開時(shí)間一致動(dòng)作
  276.                          {
  277.                                 if(miao<5)
  278.                                 {
  279.                                  v=10;
  280.                                  spek=0;delay(50);spek=1;
  281.                                  motorzen();
  282.                                 }
  283.                         }
  284.                 }
  285.         if(display[2]==display[6])//時(shí)間判斷關(guān)閉窗簾
  286.                 {
  287.                  if(display[1]==display[5])//與打開時(shí)間一致動(dòng)作
  288.                           {
  289.                                 if(miao<5)
  290.                                         {
  291.                                          v=10;
  292.                                          spek=0;delay(50);spek=1;
  293.                                          motorfan();
  294.                                         }
  295.                          }
  296.                 }
  297.    }
  298. }
  299.
  300. void timer0() interrupt 1 //定時(shí)器0中斷服程序
  301. {
  302.     TH0=(65536-50000)/256;//求模
  303.     TL0=(65536-50000)%256;//求佘
  304.     count++;//變量
  305.   if(count==20)//此處為時(shí)間基準(zhǔn)調(diào)節(jié),20為走一秒
  306.        {
  307.          count=0;
  308.          miao++;
  309.                  if(v>0)
  310.                  v--;
  311.              if(miao==60)
  312.            {
  313.                     miao=0;
  314.             display[1]++;
  315.              if(display[1]==60)
  316.                     {
  317.                     display[1]=0;//display[0]現(xiàn)在時(shí)間分的存放點(diǎn)
  318.                     display[2]++;
  319.                           if(display[2]==24)//display[1]現(xiàn)在時(shí)間時(shí)的存放點(diǎn)
  320.                                    {
  321.                              display[1]=0;
  322.                              }
  323.                           write_sfm(11,display[2]);//時(shí)針位置
  324.                                 }
  325.                write_sfm(14,display[0]);//分針位置
  326.                        }
  327.             }
  328. }
窗簾控制(陳 玲).rar (1.23 MB, 下載次數(shù): 53)
