查看: 2073|回復(fù): 1
vhdl數(shù)字頻率計(jì)程序_DDS
數(shù)字頻率計(jì)_DDS
  1. LIBRARY ieee;
  2. USE ieee.std_logic_1164.all;
  3. USE ieee.std_logic_unsigned.all;
  4. USE ieee.std_logic_arith.all;
  5. ENTITY dds_dds IS
  6.         port(ftw: in std_logic_vector(23 downto 0);                                        --頻率控制字
  7.                  clk: in std_logic;        --系統(tǒng)時(shí)鐘
  8.                  rec: in std_logic;        --接收信號(hào)使能
  9.                  out_q:        out std_logic_vector(9 downto 0);                                --幅度值輸出
  10.                  ack: out std_logic);        --接收應(yīng)答信號(hào)
  11. END dds_dds;
  12. ARCHITECTURE beh of dds_dds is
  13. signal phase_adder,frq_reg:std_logic_vector(23 downto 0);
  14. signal rom_address,address:std_logic_vector(9 downto 0);
  15. signal rom_out:std_logic_vector(9 downto 0);
  16. signal s_1,s_2,a_1,a_2:std_logic;
  17. signal a:std_logic;
  18. component dds_dds_rom        --定義ROM元件
  19.         PORT(address        : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
  20.                  q                : OUT STD_LOGIC_VECTOR (9 DOWNTO 0));
  21. end component;
  22. begin
  23.         data: dds_dds_rom port map(address,rom_out);
  24.         datain: process(clk)        --數(shù)據(jù)輸入部分
  25.         begin
  26.         if(clk'event and clk='1') then        --clk上升沿觸發(fā)
  27.                 if(rec='1') then        --rec為1則讀取ftw數(shù)據(jù)并將應(yīng)答信號(hào)ack置1
  28.                         frq_reg<=ftw;
  29.                         ack<='1';
  30.                         a<='1';        --a與ack內(nèi)容相同在判斷時(shí)使用
  31.                 end if;
  32.                 if(a='1') then        --檢測(cè)到上一個(gè)周期ack為1,則將其復(fù)位
  33.                         ack<='0';
  34.                         a<='0';
  35.                 end if;
  36.         end if;
  37.         end process;
  38.         phase_add: process(clk)        --相位累加部分
  39.         begin
  40.                 if(clk'event and clk='1') then                                                        --clk上升沿觸發(fā)
  41.                         phase_adder<=phase_adder+frq_reg;                                        --進(jìn)行相位累加
  42.                         rom_address(0)<=phase_adder(12);
  43.                         rom_address(1)<=phase_adder(13);
  44.                         rom_address(2)<=phase_adder(14);
  45.                         rom_address(3)<=phase_adder(15);
  46.                         rom_address(4)<=phase_adder(16);
  47.                         rom_address(5)<=phase_adder(17);
  48.                         rom_address(6)<=phase_adder(18);
  49.                         rom_address(7)<=phase_adder(19);
  50.                         rom_address(8)<=phase_adder(20);
  51.                         rom_address(9)<=phase_adder(21);
  52.                         s_2<=phase_adder(22);
  53.                         s_1<=phase_adder(23);        --將上一個(gè)累加值的高12位送出
  54.                 end if;
  55.         end process;
  56.
  57.         lookfor_rom: process(clk)        --ROM查找部分
  58.         begin
  59.                 if(clk'event and clk='1') then                                                        --clk上升沿觸發(fā)
  60.                         a_1<=s_1;        --a_1和a_2比s_1和s_2落后一個(gè)周期
  61.                         a_2<=s_2;
  62.                         if(s_1='0' and s_2='0') then                                                  --將各區(qū)間的地址對(duì)應(yīng)到0~π/2的地址
  63.                                 address<=rom_address;
  64.                         elsif(s_1='0' and s_2='1') then
  65.                                 address<=NOT rom_address;
  66.                         elsif(s_1='1' and s_2='0') then
  67.                                 address<=rom_address;
  68.                         elsif(s_1='1' and s_2='1') then
  69.                                 address<=NOT rom_address;
  70.                         end if;        -- NOT rom_address=3FF-rom_address
  71.                         if(a_1='0' and a_2='0') then                                                  --將各區(qū)間的幅度對(duì)應(yīng)到0~π/2的幅度
  72.                                 out_q<=rom_out;        --由于幅度比地址輸出慢一個(gè)周期所以用
  73.        -- a_1和a_2進(jìn)行判斷,a_1和a_2比s_1
  74.        --和s_2落后一個(gè)時(shí)鐘周期
  75.                         elsif(a_1='0' and a_2='1') then
  76.                                 out_q<=rom_out;
  77.                         elsif(a_1='1' and a_2='0') then
  78.                                 out_q<=NOT rom_out+"0000000001";
  79.                         elsif(a_1='1' and a_2='1') then
  80.                                 out_q<=NOT rom_out+"0000000001";
  81.                         end if;        --負(fù)數(shù)通過(guò)正數(shù)取反再加1得到
  82.                 end if;
  83.         end process;
  84. end beh;
數(shù)字頻率計(jì)_DDS.rar (3.31 KB, 下載次數(shù): 13)
ID:984711 發(fā)表于 2021-11-29 14:22 | 只看該作者
頻率測(cè)量的范圍大概在哪一個(gè)階段?
