查看: 3548|回復(fù): 1
關(guān)于外部中斷0的低電平觸發(fā)
ID:49363 發(fā)表于 2013-4-21 10:34 | 顯示全部樓層 |閱讀模式
當(dāng)我把GND用杜邦線和P3^2連起來時(shí),為什么還在執(zhí)行主程序 只是顯示數(shù)字的間隔變慢了 # include sbit led=P1^0; sbit dula=P2^6; sbit wela=P2^7; unsigned char t,num; unsigned char code table[] = {0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; void delay(unsigned int z) { unsigned int x,y; for(x=z;x>0;x--) for(y=100;y>0;y--); } void main() { EA=1;//開總中斷 EX0=1; while(1) { for(num=0;num<16;num++) //讓數(shù)碼管顯示0到F { led="1; dula=1; P0=table[num]; dula=0; wela=1; P0=0xc0; wela=0; delay(200); } " } } void exter0() interrupt 0 { led="0; }"
[此貼子已經(jīng)被作者于2013-4-21 10:38:14編輯過]
ID:49363 發(fā)表于 2013-4-21 10:39 | 顯示全部樓層
這咋發(fā)成一堆了,暈
