查看: 2500|回復(fù): 0
N76E003AT20單片機(jī)串口0調(diào)試
ID:723138 發(fā)表于 2020-4-10 09:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
一個(gè)按鍵1 如果按下,就使 N76E003串口0 發(fā)送1到串口調(diào)試助手,但是老是有問(wèn)題,哪位大神幫幫我。代碼如下:
#include "n76e003.h"
#include "stdio.h"
#define uint32 unsigned int
//typedef unsigned int uint32;
void delay_us(int n)
  int m;
  for(m=0;m<n;m++);
void delay_ms(int j)
  int k;
  for(k=0;k<j;k++);
  delay_us(1000);
void P0_P1_Mode(void)
  P0M1=0x3A;  P0M2=0x3B;  //設(shè)置P0
  P1M1=0xA0;  P1M2=0xBF;  //設(shè)置P1
sbit s1 = P0^0;
sbit s2 = P1^0;
sbit s3 = P1^1;
sbit s4 = P1^2;
sbit s5 = P1^3;
sbit s6 = P1^4;
void UART0_Init(uint32 Baud)        //設(shè)置串口0
   P0_P1_Mode();
   ES=1;                                //使能所有中斷
   ES=1;                //串口0中斷使能
   ET1=0;                                //關(guān)閉定時(shí)器1中斷
   SCON = 0x52;         //串口0選擇模式1 SM0=0 SM1=1  REN=1  TI=1
   T3CON|=0x00;                 //選擇定時(shí)器1                     BRCK=0
   PCON |=0x80;                    //定時(shí)器1的波特率加倍             SMOD=1
   CKCON|=0x10;                        //定時(shí)器1的時(shí)鐘源為系統(tǒng)時(shí)鐘         T1M=1
   TMOD |=0x20;         //定時(shí)器1選擇模式2 8位計(jì)數(shù)器,數(shù)值從TH1自動(dòng)重裝載入TL1        M1=1 M0=0  2^8=256
   #ifdef FOSC_160000
   TH1 = 256 - (1000000/Baud+1);                         /*16 MHz */
   #endif
   TCON |=0x40;                   //定時(shí)器1啟動(dòng)                TR1=1
void Send_Data_UART0(int a)
  TI=0;
  SBUF=a;                     //串口0數(shù)據(jù)緩存寄存器
  while(TI==0);
int main()
   s1=1;
   s2=1;
   s3=1;
   s4=1;
   s5=1;
   s6=1;
   UART0_Init(9600);
            if(s1=0)
         { Send_Data_UART0(1); }
         delay_ms(10);
         if(s2=0)
         { Send_Data_UART0(2); }
         delay_ms(10);
         if(s3=0)
         { Send_Data_UART0(3); }
         delay_ms(10);
         if(s4=0)
         { Send_Data_UART0(4); }
         delay_ms(10);
         if(s5=0)
         { Send_Data_UART0(5); }
         delay_ms(10);
         if(s6=0)
     { Send_Data_UART0(6); }
         delay_ms(10);
