一, 打開模板文件(可以隨文下載放置在文檔中打開)。(如下圖1所示) 圖1 二,另存工程文件,添加虛擬仿真Buttons。(如下圖2,3所示) 圖2 圖3 三,點擊Source Code標(biāo)簽。(如下圖4所示) 圖4 四,編輯main.c, key.c, key.h代碼。led.c, led.h代碼如Proteus8.9 仿真STM32407ZGT6系列001(如下圖5所示) 圖5 五,Main.c 代碼: #include "stm32f4xx_conf.h" #include "sys.h" #include "delay.h" #include "usart.h" #include "led.h" #include "key.h" #define Oppsit(A) (A!=0)?0:1 u8 i, k=1, t=0; u8 str[8][17]={ "紅燈亮!!!...\r\n", "紅亮滅!!!...\r\n", "黃燈亮!!!...\r\n", "黃亮滅!!!...\r\n", "綠燈亮!!!...\r\n", "綠亮滅!!!...\r\n", "燈閃亮!!!...\r\n", "燈閃滅!!!...\r\n", }; u8 ReadKey(u16 IoBit){ if(0==GPIO_ReadInputDataBit(GPIOC,IoBit)){ return 0; } else{ delay_us(10); if(1==GPIO_ReadInputDataBit(GPIOC,IoBit)) { return1; } else{ return0; } } } int main (void) { NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2 delay_init(168); //初始化延時函數(shù) uart_init(9600); //串口初始化 LED_Init(); //初始化LED端口 KEY_Init(); //按鍵初始化 while(1) { if(1==ReadKey(0x0020))k=0; if(1==k){ for(t=0;t<16;t++){ USART_SendData(USART1,(u16) str[6][t]); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET); } for(i=0; i<6; i++){ PCout((i/2+1))=Oppsit((i%2)); for(t=0;t<16;t++){ USART_SendData(USART1,(u16) str[ i][t]); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET); } delay_ms(500); } } else{ for(t=0;t<16;t++){ USART_SendData(USART1,(u16) str[7][t]); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET); } while(1!=ReadKey(0x0010)); k=1; delay_ms(50); } } } key.c 代碼: #include "key.h" #include "delay.h" void KEY_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);//使能GPIOC時鐘 GPIO_InitStructure.GPIO_Pin= GPIO_Pin_4| GPIO_Pin_5; //KEY0 對應(yīng)引腳 GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;//普通輸入模式 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100M GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_DOWN ;//下拉 GPIO_Init(GPIOC,&GPIO_InitStructure);//初始化GPIOE4 } key.h 代碼: #ifndef __KEY_H #define __KEY_H #include "sys.h" #define KEY0 PCin(4) //PC4 #define KEY1 PCin(5) //PC5 void KEY_Init(void); //IO初始化 #endif 六,點擊構(gòu)建工程按鈕,編譯工程。(如下圖6所示) 圖6 七,點擊窗口左下方仿真按鈕,可見紅黃綠燈每個0.5s跳閃仿真,按下KEYSTOP鍵,停止跳閃仿真;按下KEYSTART鍵,開始跳閃仿真。虛擬串口仿真將單片機紅黃綠等亮滅情況打印顯示。(如下圖7,8,9所示) 圖7 圖8 圖9 八,選擇release,點擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖10所示) 圖10 九,筆者準(zhǔn)備的是普中F407ZGT6的核心板,通過普中自動下載軟件將Proteus VSM Studio生成的Hex文件下載到開發(fā)板上。可見開發(fā)板連接的紅黃綠燈模塊每個0.5s紅黃綠燈跳閃,按下7鍵,停止跳閃仿真;按下1鍵,開始跳閃仿真(模塊接線定義的)。電腦串口將單片機紅黃綠等亮滅情況打印顯示。(如下圖11,12,13,14所示) 圖11 圖12 圖13 圖14 .
附件Proteus8.9 仿真STM32407ZGT6系列基礎(chǔ)模板t00在已安裝Proteus8.9的計算機文件夾中打開即可。需要進一步了解,請加入QQ群:976235464 |
