查看: 24452|回復(fù): 7
Proteus8.9 仿真STM32407ZGT6系列005_窗口看門狗
一,    打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
1
二,調(diào)整虛擬器件,另存工程文件。(如下圖2,3所示)
2
3
三,點(diǎn)擊Source Code標(biāo)簽。(如下圖4所示)
4
四,編輯main.c, wwdg.c,wwdg.h, key.c,key.h, led.cled.h 代碼如Proteus8.9 仿真STM32407ZGT6系列001(如下圖5所示)
5
五,Main.c 代碼:
#include "stm32f4xx_conf.h"
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "wwdg.h"
int main (void)
       NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
       delay_init(168);    //初始化延時(shí)函數(shù)
       uart_init(115200);  //串口初始化
       LED_Init();                           //初始化LED端口
       LED0=1;                                 //先點(diǎn)亮燈
       LED1=1;                                 //先點(diǎn)亮燈
       delay_ms(300);
       LED0=0;                                 //先點(diǎn)亮燈
       LED1=0;                                 //先點(diǎn)亮燈
       delay_ms(300);
       WWDG_Init(0x7F,0X5F,WWDG_Prescaler_8);       //計(jì)數(shù)器值為7f,窗口寄存器為5f,分頻數(shù)為8
              if(SET==KEY0){
                     //LED0=~LED0;                                    //先點(diǎn)亮燈
                     WWDG_IRQHandler();
                     LED1=~LED1;                                      //先點(diǎn)亮燈
                     delay_ms(500);
                     delay_ms(500);
wwdg.c代碼:
#include "wwdg.h"
#include "led.h"
#include "delay.h"
u8 WWDG_CNT=0X7F;
void WWDG_Init(u8 tr,u8 wr,u32 fprer)
       NVIC_InitTypeDefNVIC_InitStructure;
       RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG,ENABLE);
       WWDG_CNT=tr&WWDG_CNT;
       WWDG_SetPrescaler(fprer);
       WWDG_SetWindowValue(wr);
       WWDG_SetCounter(WWDG_CNT);
       WWDG_Enable(WWDG_CNT);
       NVIC_InitStructure.NVIC_IRQChannel=WWDG_IRQn;
       NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x02;
       NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x03;
       NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
       NVIC_Init(&NVIC_InitStructure);
       WWDG_ClearFlag();
  WWDG_EnableIT();
void WWDG_IRQHandler(void)
       LED0=~LED0;
       delay_ms(500);
       WWDG_ClearFlag();
       LED1=~LED1;
wwdg.h代碼:
#ifndef _WWDG_H
#define _WWDG_H
#include "sys.h"
void WWDG_Init(u8 tr,u8 wr,u32 fprer);
void WWDG_IRQHandler(void);
#endif
led.c代碼:
#include "led.h"
void LED_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOB時(shí)鐘
  //GPIOF9,F10初始化設(shè)置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6| GPIO_Pin_8;//LED對(duì)應(yīng)引腳
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通輸出模式
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化
led.h代碼:
#ifndef __LED_H
#define __LED_H
#include "sys.h"
//LED端口定義
#define LED0 PBout(6) // LED0
#define LED1 PBout(8) // LED1
void LED_Init(void);//初始化
#endif
key.c代碼:
#include "key.h"
#include "delay.h"
void KEY_Init(void)
       RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);//使能GPIOB時(shí)鐘
       GPIO_InitStructure.GPIO_Pin= GPIO_Pin_3; //KEY0 對(duì)應(yīng)引腳
       GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;//普通輸入模式
       GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100M
       GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_DOWN ;//下拉
       GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化GPIOE4
key.h代碼:
#ifndef __KEY_H
#define __KEY_H
#include "sys.h"
#define KEY0              PBin(3)        //PB3
void KEY_Init(void);    //IO初始化
#endif
六,點(diǎn)擊構(gòu)建工程按鈕,編譯工程。(如下圖6所示)
6
七,點(diǎn)擊窗口左下方仿真按鈕,可見黃燈點(diǎn)亮仿真,按下按鈕,進(jìn)行喂狗,開始跳閃仿真。 (如下圖78,9所示)
7
8
9
八,選擇release,點(diǎn)擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖10所示)
10
九, 系列的001-003虛擬仿真與開發(fā)板對(duì)應(yīng)已證明:虛擬仿真程序?qū)τ陂_發(fā)板有效,之后不再➕上下載到開發(fā)板的介紹。
需要進(jìn)一步了解,請(qǐng)加入QQ群:976235464
Proteus8.9 仿真STM32407ZGT6系列005_窗口看門狗.rar
256.32 KB, 下載次數(shù): 32, 下載積分: 黑幣 -5
附件Proteus8.9 仿真STM32407ZGT6系列005_窗口看門狗在已安裝Proteus8.9的計(jì)算機(jī)文件夾中打開即可
收藏收藏3 分享淘帖 頂 踩
ID:630400 發(fā)表于 2020-4-12 22:37 | 只看該作者
請(qǐng)問8.9版本在哪里下載,我怎么找不到
ID:371233 發(fā)表于 2020-4-13 11:12 | 只看該作者
llx19974122008 發(fā)表于 2020-4-12 22:37
注意論壇上帖子:Proteus8.9安裝軟件網(wǎng)盤地址。
ID:630400 發(fā)表于 2020-4-13 23:46 | 只看該作者
kaillen 發(fā)表于 2020-4-13 11:12
好的,謝謝你,還有我想問一下407是直接用這個(gè)嗎
ID:371233 發(fā)表于 2020-4-14 01:28 | 只看該作者
407大部分功能是可以直接用這個(gè)的。看一下帖子《用Proteus8.9自帶STM32F401VE的Controller仿真STM32F407ZGT6,F429IGT6》
ID:630400 發(fā)表于 2020-4-14 08:39 | 只看該作者
kaillen 發(fā)表于 2020-4-14 01:28
407大部分功能是可以直接用這個(gè)的。看一下帖子《用Proteus8.9自帶STM32F401VE的Controller仿真STM32F407ZGT ...
嗯好的,已看到,謝謝你哈
ID:371233 發(fā)表于 2020-4-14 10:13 | 只看該作者
llx19974122008 發(fā)表于 2020-4-14 08:39
嗯好的,已看到,謝謝你哈
1,安裝Proteus8.9。
2,準(zhǔn)備基礎(chǔ)模板和已有的一個(gè)例證(不包括看門狗的例子)。
3,運(yùn)行例證可看仿真,再同時(shí)打開基礎(chǔ)模板,編碼(也可以從例證的文件復(fù)制),一個(gè)例證仿真完成了。
ID:371233 發(fā)表于 2020-4-14 10:42 | 只看該作者
本帖最后由 kaillen 于 2020-4-14 15:04 編輯
嗯好的,已看到,謝謝你哈
看門狗的或之后的例證,可以與基礎(chǔ)模板對(duì)照文件列表,缺什么文件,補(bǔ)什么(或復(fù)制)(有些例證因?yàn)椴捎酶嗟膸旌瘮?shù),config的.h文件也要添加#include xxxx.h等。有些例證中與基礎(chǔ)模板同名的文件,內(nèi)容有不同。但例證能進(jìn)行運(yùn)行仿真,它的文件更適合編譯?梢杂萌炕蛐枰奈募采w基礎(chǔ)模板同名的文件就可行。) 基礎(chǔ)模板也變成一樣的例證了。為什么不把所有的庫函數(shù)全部加載上去哪?這樣會(huì)大大增加編譯和仿真的時(shí)間。
