查看: 4180|回復(fù): 2
雙51單片機(jī)叫號(hào)系統(tǒng)源程序+Proteus仿真
ID:586708 發(fā)表于 2020-4-12 17:10 | 顯示全部樓層 |閱讀模式
兩個(gè)51單片機(jī)采用串口通信,實(shí)現(xiàn)叫號(hào)系統(tǒng),附加為代碼+Proteus仿真,采用LCD12864顯示
  1. #include <REG51F.H>
  2. #include <stdlib.h>
  3. #include "uart.h"
  4. #include <stdio.h>
  5. #include "12864.h"
  6. #include "tcs_resource.h"
  7. unsigned char hour = 23;
  8. unsigned char mnt = 59;
  9. unsigned char sec = 50;
  10. sbit KEY1 = P1^0;
  11. sbit KEY2 = P1^1;
  12. void delay(uint ms);
  13. void button();
  14. void Delay10ms(uchar u);
  15. void Timer0Init(void);
  16. void show(void);
  17. void main(void)
  18. {
  19.         num=0;
  20.         TMOD=0x01;
  21.         EA = 1;                        //開總中斷
  22.         ES = 1;                        //串口中斷標(biāo)志位
  23.         Timer0Init();
  24.         UartInit();
  25.
  26.         choose12864(2);                //選擇為全屏操作
  27.         init12864();                //初始化12864
  28.         clear12864();                //清屏
  29.         while(1)
  30.         {
  31.                 show();
  32.                 button();
  33.
  34.         }
  35. }
  36. void show(void)
  37. {
  38.         char j = 0;
  39.         play8(0,0,2,letter[13]);
  40.         play8(0,1,2,letter[20]);
  41.         play8(0,2,2,letter[22]);
  42.         play8(0,3,2,fuhao[0]);
  43.         play8(0,4,2,Number[Number1/10]);
  44.         play8(0,5,2,Number[Number1%10]);
  45.
  46.         play8(1,0,2,letter[22]);
  47.         play8(1,1,2,letter[15]);
  48.         play8(1,2,2,fuhao[0]);
  49.         play8(1,3,2,Number[num/10]);
  50.         play8(1,4,2,Number[num%10]);
  51.         //顯示時(shí)分秒
  52.         play8(0,3,1,Number[hour/10]);
  53.         play8(0,4,1,Number[hour%10]);
  54.         play8(0,5,1,fuhao[1]);
  55.         play8(0,6,1,Number[mnt/10]);
  56.         play8(0,7,1,Number[mnt%10]);
  57.         play8(1,0,1,fuhao[1]);
  58.         play8(1,1,1,Number[sec/10]);
  59.         play8(1,2,1,Number[sec%10]);
  60. }
  61. void button()
  62. {
  63.         if(KEY1==0)
  64.         {
  65.                 delay(5);
  66.                 if(KEY1==0)
  67.                 {
  68.                         Number1++;
  69.                         num=Number1-1;
  70.                         choose12864(2);        //選擇為全屏顯示
  71.                         init12864();                //初始化12864
  72.                         clear12864();
  73.                         Delay10ms(1);
  74.                         while(KEY1==0);
  75.                         send();
  76.                 }
  77.         }
  78. }
  79. void delay(uint ms)
  80. {
  81.         uint i,j;
  82.         for(i=ms;i>0;i--)
  83.                 for(j=110;j>0;j--);
  84. }
  85. void Delay10ms(uchar u)
  86. {
  87.         unsigned char i, j;
  88.         i = 108;
  89.         j = 145;
  90.         while(u--)
  91.         {
  92.         do
  93.         {
  94.                 while (--j);
  95.         } while (--i);}
  96. }
  97. void Timer0Init(void)                //62毫秒@11.0592MHz
  98. {
  99.         TMOD |= 0x01;
  100.         ET0 = 1;
  101.         TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
  102. }
  103. void T0ISR() interrupt 1
  104. {
  105.         static char n = 0;
  106.         TH0=(65536-62500)/256;//在65.536ms定時(shí)器允許的最大范圍內(nèi)取最大值,1000/n=62.5ms,n=16
  107.         TL0=(65536-62500)%256;
  108.         n++;
  109.         if(n>15)
  110.         {
  111.                 n = 0;
  112.                 sec++;
  113.                 if(sec>59)
  114.                 {
  115.                         sec = 0;
  116.                         mnt++;
  117.                         if(mnt>59)
  118.                         {
  119.                                 mnt = 0;
  120.                                 hour++;
  121.                                 if(hour>23)
  122.                                         hour = 0;
  123.                         }
  124.                 }
  125.         }
  126. }
叫號(hào)系統(tǒng).7z (43.97 KB, 下載次數(shù): 68)
ID:302325 發(fā)表于 2020-5-13 12:38 | 顯示全部樓層
感謝分享
ID:377614 發(fā)表于 2020-6-15 22:36 | 顯示全部樓層
資料文件不全
