我的燒錄后顯示特別雜,根本看不清顯示的是啥,大佬們請(qǐng)看看我的代碼,我比較菜,希望大佬們指點(diǎn)指點(diǎn)。
代碼:
* LED點(diǎn)陣--顯示漢字實(shí)驗(yàn) *
實(shí)現(xiàn)現(xiàn)象:下載程序后,按照光盤內(nèi)操作視頻接線,LED點(diǎn)陣顯示漢字
注意事項(xiàng):必須將74HC595模塊的JP595短接片短接,否則不會(huì)出現(xiàn)現(xiàn)象
#include "reg51.h" //此文件中定義了單片機(jī)的一些特殊功能寄存器
#include "intrins.h"
typedef unsigned int u16; //對(duì)數(shù)據(jù)類型進(jìn)行聲明定義
typedef unsigned char u8;
//--定義使用的IO口--//
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
//定義LED點(diǎn)陣的位選,也就是類似于數(shù)碼管的位選,因?yàn)橐獙?duì)其動(dòng)態(tài)掃描操作
//數(shù)組前16位和后16位數(shù)據(jù)正好是相反的,也就是說先讓第3個(gè)595輸出低電平,然后再讓第4個(gè)595輸出低電平
u8 code ledwei[]=
0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f,
u8 code ledduan[]=
/*-- 文字: 溫 --*/
/*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
0x10,0x60,0x02,0x8C,0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
0x04,0x04,0x7E,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00,
/*-- 文字: 度 --*/
0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0x25,0x26,0x24,0xFC,0x24,0x24,0x24,0x04,0x00,
0x40,0x30,0x8F,0x80,0x84,0x4C,0x55,0x25,0x25,0x25,0x55,0x4C,0x80,0x80,0x80,0x00,
/*-- 文字: 過 --*/
0x40,0x40,0x42,0xCC,0x00,0x08,0x48,0x88,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x00,
0x00,0x40,0x20,0x1F,0x20,0x40,0x40,0x41,0x40,0x48,0x50,0x4F,0x40,0x40,0x40,0x00,
/*-- 文字: 高 --*/
0x04,0x04,0x04,0x04,0xF4,0x94,0x95,0x96,0x94,0x94,0xF4,0x04,0x04,0x04,0x04,0x00,
0x00,0xFE,0x02,0x02,0x7A,0x4A,0x4A,0x4A,0x4A,0x4A,0x7A,0x02,0x82,0xFE,0x00,0x00,
/*-- 文字: ! --*/
0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
* 函 數(shù) 名 : delay
* 函數(shù)功能 : 延時(shí)函數(shù),i=1時(shí),大約延時(shí)10us
void delay(u16 i)
while(i--);
* 函 數(shù) 名 : Hc595SendByte(u8 dat1,u8 dat2,u8 dat3,u8 dat4)
* 函數(shù)功能 : 通過595發(fā)送四個(gè)字節(jié)的數(shù)據(jù)
* 輸 入 : dat1:第4個(gè)595輸出數(shù)值
* * dat2: 第3個(gè)595輸出數(shù)值
* * dat3:第2個(gè)595輸出數(shù)值
* * dat4:第1個(gè)595輸出數(shù)值
* 輸 出 : 無(wú)
void Hc595SendByte(u8 dat1,u8 dat2,u8 dat3,u8 dat4)
u8 a;
SRCLK = 1;
RCLK = 1;
for(a=0;a<8;a++) //發(fā)送8位數(shù)
SER = dat1 >> 7; //從最高位開始發(fā)送
dat1 <<= 1;
SRCLK = 0; //發(fā)送時(shí)序
_nop_();
_nop_();
SRCLK = 1;
SER = dat2 >> 7; //從最高位開始發(fā)送
dat2 <<= 1;
_nop_();
_nop_();
SRCLK = 1;
SER = dat3 >> 7; //從最高位開始發(fā)送
dat3 <<= 1;
_nop_();
_nop_();
SRCLK = 1;
SER = dat4 >> 7; //從最高位開始發(fā)送
dat4 <<= 1;
_nop_();
_nop_();
SRCLK = 1;
RCLK = 0;
_nop_();
_nop_();
RCLK = 1;
* 函 數(shù) 名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無(wú)
* 輸 出 : 無(wú)
u8 i=0;
u8 j=0;
u16 count=0;
u8 offset=0;
for(i=0;i<80;i++)
Hc595SendByte(ledwei[j+16],ledwei[j],ledduan[i+16+offset],ledduan[i+offset]);
delay(10);
j++;count++;
if(j>15)
j=0;
if(count>100)
count=0;
offset++;
if(offset>32)
offset=0;
