查看: 6908|回復(fù): 3
紅外接收程序問(wèn)題!幫忙看看
ID:8704 發(fā)表于 2009-6-5 11:56 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <lcd.h>
#include <epprom.h>
unsigned int temp_low_pulse1;
unsigned int temp_low_pulse0;
unsigned int temp_high_pulse1;
unsigned int temp_high_pulse0;
unsigned int count;
unsigned char write_enable;
sbit led8=P0^7;
sbit key=P0^0;
sbit key1=P0^1;
sbit key2=P0^2;
/*********      延時(shí)1S     ******************************************/
void delay_1s()
 unsigned int i,j;
 for(i=5;i>0;i--)
  for(j=110;j>0;j--);
void initial()
 EA=1; //開(kāi)啟總中斷
 EX1=1; //開(kāi)啟外部中斷1
 IT1=1; //外部中斷1為下降沿有效
 TMOD=0x19; //定時(shí)器1,2 方式為1,且T0 GATE位有效
 TH0=0x00;
 TL0=0x00;
 TH1=0x00;
 TL1=0x00;
 count=0;
 unsigned char temp,temp_ge,temp_shi,temp_bai,num_ge,num_shi,num_bai,num_qian;
 unsigned int  count_qian,count_bai,count_shi,count_ge,num;
 initial();
 init();
 lcd_int();
 num=0;
  if(key==0)
   num++;
   if(num==2048)
   num=0;
   while(!key);
  if(key1==0)
   if(num==0)
    num=2048;
     num--;
   while(!key1);
 if(count>=2048)
  count=0;
 temp=read_add(num);
 temp_bai=temp/100;
 temp_shi=temp%100/10;
 temp_ge=temp%10;
 num_qian=num/1000;
 num_bai=num%1000/100;
 num_shi=num%100/10;
 num_ge=num%10;
 count_qian=count/1000;
 count_bai=count%1000/100;
 count_shi=count%100/10;
 count_ge=count%10;
 write_com(0x80);
 write_date(0x30+temp_bai);
 write_com(0x81);
 write_date(0x30+temp_shi);
 write_com(0x82);
 write_date(0x30+temp_ge);
 write_com(0x84);
 write_date(0x30+num_qian);
 write_com(0x85);
 write_date(0x30+num_bai);
 write_com(0x86);
 write_date(0x30+num_shi);
 write_com(0x87);
 write_date(0x30+num_ge);
 write_com(0x89);
 write_date(0x30+count_qian);
 write_com(0x8a);
 write_date(0x30+count_bai);
 write_com(0x8b);
 write_date(0x30+count_shi);
 write_com(0x8c);
 write_date(0x30+count_ge);
 if (write_enable==1)
 write_add(count,5);   //將紅外信號(hào)的低電平的值寫(xiě)入儲(chǔ)存器COUNT地址內(nèi)
 delay_1s();
 write_add(count+1,6);   //將紅外信號(hào)的低電平的值寫(xiě)入儲(chǔ)存器COUNT+1地址內(nèi)
 delay_1s();
 write_add(count+2,7);  //將紅外信號(hào)的高電平的值寫(xiě)入儲(chǔ)存器COUNT+2地址內(nèi)
 delay_1s();
 write_add(count+3,8);  //將紅外信號(hào)的高電平的值寫(xiě)入儲(chǔ)存器COUNT+3地址內(nèi)
 delay_1s();
 write_enable=0;
void int1() interrupt 2
    EX1=0;          //關(guān)外部中斷1
 TR0=0;          //關(guān)閉定時(shí)器0
 TR1=0;          //關(guān)閉定時(shí)器1
 temp_low_pulse1=TH1-TH0;     //將TH1減去TL0的值(即紅外信號(hào)的低電平)賦予temp_low_pulse1
 temp_low_pulse0=TL1-TL0;         //將TL1減去TL0的值(即紅外信號(hào)的低電平)賦予temp_low_pulse0
 temp_high_pulse1=TH0;      //將TH0值(即紅外信號(hào)的高電平值)賦予temp_high_pulse1
 temp_high_pulse0=TL0;      //將TL0值(即紅外信號(hào)的高電平值)賦予temp_high_pulse0
 write_enable=1;
 TH0=0x00;         //TH0清零
 TL0=0x00;         //TL0清零
 TH1=0x00;         //TH1清零
 TL1=0x00;         //TL1清零
 TR0=1;          //啟動(dòng)定時(shí)器0
 TR1=1;          //啟動(dòng)定時(shí)器1
 led8=!led8;
 count=count+4;
 EX1=1;          //開(kāi)外部中斷1
本人編寫(xiě)了一個(gè)紅外接收的程序,紅外接收管接收端接單片機(jī)中斷1,接收的紅外波形以后,開(kāi)啟T0,T1定時(shí)器,對(duì)紅外波形的高低電平及時(shí),其中中斷下降沿開(kāi)啟T1計(jì)時(shí),電平升高后開(kāi)啟T0計(jì)時(shí),T1-T0的時(shí)間就是紅外波形的低電平時(shí)間,我利用AT24C16芯片保存定時(shí)時(shí)間,根據(jù)寫(xiě)的程序,在兩次中斷間隙時(shí)間過(guò)短了,沒(méi)有足夠的時(shí)間寫(xiě)進(jìn)存儲(chǔ)芯片,怎么解決啊?
ID:8704 發(fā)表于 2009-6-10 11:34 | 顯示全部樓層
ID:16415 發(fā)表于 2009-8-28 11:32 | 顯示全部樓層
 頂一下,我也在弄紅外呢呵呵
ID:16651 發(fā)表于 2009-8-28 20:08 | 顯示全部樓層
不知道你的問(wèn)題解決了嗎  我前一段時(shí)間也謝了一個(gè)簡(jiǎn)單的紅外程序  傳到http://sjcxlab.5d6d.com/thread-46-1-1.html  這里了  有興趣的可以去看一下~~~~
