查看: 1910|回復(fù): 0
軟件 PWM配置 STM32F103
ID:730478 發(fā)表于 2020-4-16 13:36 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include "turn.h"
u8 led0_statelift;
u8 led0_stateright;
u8 pwm_high_counterlift;
u8 pwm_high_counterright;
//配置嵌套中斷控制器
void tim3_nvic_config(void)
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    NVIC_InitTypeDef  NVIC_Init_Struct;
    NVIC_Init_Struct.NVIC_IRQChannel =TIM3_IRQn;    //設(shè)置定時(shí)器 3中斷
    NVIC_Init_Struct.NVIC_IRQChannelPreemptionPriority =0 ;//搶占與優(yōu)先級
    NVIC_Init_Struct.NVIC_IRQChannelSubPriority = 0;        //zi優(yōu)先級
    NVIC_Init_Struct.NVIC_IRQChannelCmd =ENABLE;  //shineng
    NVIC_Init(&NVIC_Init_Struct);
//定時(shí)器初始化配置
void tim3_config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
tim3_nvic_config();
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
TIM_DeInit(TIM3);
TIM_TimeBaseInitStruct.TIM_Prescaler = 36-1;
TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStruct.TIM_Period = 10-1;              // 200khz翻轉(zhuǎn) 100k個(gè)周期
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStruct); //初始化 TIM2 配置
TIM_ClearFlag(TIM3,TIM_FLAG_Update); //清除溢出中斷標(biāo)志
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
TIM_Cmd(TIM3,ENABLE); //開啟時(shí)鐘
//定時(shí)器中斷函數(shù)處理
void set_pwm_highlift(u8 high_pd)
pwm_high_counterlift = high_pd;
void set_pwm_highright(u8 high_pd)
pwm_high_counterright = high_pd;
void TIM3_IRQHandler(void)
     //進(jìn)中斷
   if(TIM_GetITStatus(TIM3, TIM_IT_Update)!= RESET)
        //left
        led0_statelift ++;
        if(led0_statelift <= pwm_high_counterlift)
            LEFT0_ON();
            LEFT1_OFF();
         else if((led0_statelift > pwm_high_counterlift) && (led0_statelift <= 100))
            LEFT0_OFF();
            LEFT1_ON();
            led0_statelift = 0;
   TIM_ClearITPendingBit(TIM3,TIM_FLAG_Update);
   //right
        led0_stateright ++;
           if(led0_stateright <= pwm_high_counterright)
            RIGHT0_ON();
            RIGHT1_OFF();
         else if((led0_stateright > pwm_high_counterright) && (led0_stateright <= 100))
            RIGHT0_OFF();
            RIGHT1_ON();
            led0_stateright = 0;
