這是PT100溫度測試程序- #include<reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit dula=P2^6; // 數(shù)碼管的
- sbit wela=P2^7;
- sbit dclk=P1^0; // 串行時鐘
- sbit din=P1^1; // 串行數(shù)據(jù)輸入
- sbit dout=P1^2; // 串行數(shù)據(jù)輸出
- sbit cs=P1^4; // 片選
- sbit busy=P1^5; // 轉換狀態(tài)信號
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- uchar code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd, //帶小數(shù)點
- 0x87,0xff,0xef};
- uint wendu;
- void start() //啟動ad芯片
- dclk=0;
- cs=1;
- din=1;
- dclk=1;
- cs=0;
- /*void xieshuju(unsigned char num) //SPI寫數(shù)據(jù)
- unsigned char count=0;
- dclk=0;
- for(count=0;count<16;count++)
- num<<=1;
- din=CY;
- _nop_();
- dclk=0; _nop_();_nop_();_nop_(); //上升沿有效 ??????0
- dclk=1; _nop_();_nop_();_nop_();
- void xieshuju(unsigned char num) //寫數(shù)據(jù) 16位
- dclk=0;
- num<<=1;
- _nop_();
- din=CY;
- _nop_();
- dclk=1; _nop_();_nop_();_nop_(); //
- void xiemingling(uchar num) // 寫命令8位
- uchar count=0;
- dclk=0;
- for(count=0;count<8;count++)
- num<<=1;
- _nop_();
- din=CY;
- _nop_();
- uint dushuju() // 讀數(shù)據(jù) 16位
- unsigned int Num=0;
- dclk=0;
- Num=(Num<<=1)|dout;
- _nop_(); ////
- return(Num);
- void delay(uchar x) //延遲
- uchar i,j;
- for(i=x;i>0;i--)
- for(j=110;j>0;j--);
- void display(unsigned int wendu) //數(shù)碼管顯示程序
- unsigned int A1,A2,A3,A4;
- A1=wendu/1000;
- A2=wendu%1000/100;
- A3=wendu%100/10;
- A4=wendu%10;
- dula=1;
- P0=table[A1]; //顯示千位
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfe;
- wela=0;
- delay(10);
- dula=1;
- P0=table[A2]; //顯示百位
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfd;
- wela=0;
- delay(10);
- dula=1;
- P0=table[A3]; //顯示十位
- dula=0;
- wela=1;
- P0=0xfb;
- wela=0;
- delay(10);
- dula=1;
- P0=table[A4]; //顯示個位
- dula=0;
- wela=1;
- P0=0x77;
- wela=0;
- delay(10);
- int jzzh(int a ) // 進制轉換 2進制轉換成10進制
- int b=0;
- while(a)
- if(a%2)
- b++;
- a=a/2;
- return b;
- void main()
- uint w,ady,sdy;
- start();
- xiemingling(0x08); // 寫模式寄存器
- delay(10);
- xieshuju(0x000a); // 默認值 復位值
- delay(10);
- xiemingling(0x10); // 寫配置寄存器
- delay(10);
- xieshuju(0x1100); //
- delay(10);
- xiemingling(0x28); // 寫 io寄存器
- delay(10);
- xiemingling(0x01); // 10uA電流
- delay(10);
- xiemingling(0x5c); // 連續(xù)讀取模式
- delay(10);
- while(1)
- // if(dout==0)
- sdy=dushuju();//}
- delay(20);
- sdy=jzzh(sdy);
- ady=sdy/65536;
- w=2.5806*ady-258.1234;
- display(w);
- delay (10);
- xiemingling(0xff); //// 復位
復制代碼
