查看: 1743|回復(fù): 1
為什么達到指定的溫度和感應(yīng)到有人后,顯示屏就會定住不刷新了,而且也發(fā)不出信息
ID:455529 發(fā)表于 2020-4-18 12:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    static uchar value;
        Uart_Init();
        chushihua_kz();
        phone(phoneNumber);
        init_1602();                    //1602初始化
        time_init();                    //初始化定時器
//        init_int0();
         if(flag_200ms == 1)                //300ms 處理一次溫度程序
                        flag_200ms = 0;
                        value ++;
                        if(value >= 4)
                                value = 0;
                                if(miao != 0)
                                        miao --;    //時間減1
                                if(miao == 0)
                                        flag_en = 0;
                        if(hw == 1)  //感應(yīng)到人
                                miao = 30;
                                write_string(1,14,"Y ");
                                flag_en = 1;
                                write_string(1,14,"N ");
                                write_sfm2(1,0,miao);
                        temperature = read_temp();        //先讀出溫度的值
                        fengshan_kz();        //風(fēng)扇控制函數(shù)
                        write_sfm3_18B20(1,8,temperature);
                        if((flag_en == 1)&&(temperature >= t_high))
                         sendMessage(phoneNumber,msg);
ID:342451 發(fā)表于 2020-4-18 23:35 | 只看該作者
應(yīng)該是sendMessage(phoneNumber,msg);這里了,你還不貼出來。。?纯催@個函數(shù)里是不是有哪里沒執(zhí)行過去
