查看: 25603|回復: 0
Proteus8.9 仿真STM32407ZGT6系列007_定時器中斷
ID:371233 發(fā)表于 2020-4-24 17:40 | 顯示全部樓層 |閱讀模式
一,    打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調整虛擬器件,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點擊Source Code標簽。(如下圖5所示)
圖5
四,編輯main.c,timer.c,timer.h, key.c,key.h, led.c,led.h 代碼如Proteus8.9 仿真STM32407ZGT6系列001(如下圖6所示)
圖6
五,Main.c 代碼:
/* Main.c file generated by New Project wizard
* Author:   Ziegler Yin
* Created:   周四 一月 16 2020
* Processor: STM32F407ZGT6ZGT6
* Compiler:  GCC for ARM
#include "mfuncs.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "timer.h"
char *dstr[5] = { "系統(tǒng)啟動...\r\n",
                                                "定時器又清零...\r\n",
                                                "\r\n定時器進行中...\r\n",
                                                "Test!\r\n",
                                                "\r\n"
u16 w,md;
u32 rd;
u8 s;
char *bt;
char ntr[]= "1234";
int main(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置系統(tǒng)中斷優(yōu)先級分組2
        delay_init(168);      //初始化延時函數(shù)
        uart_init(9600);      //串口初始化
        LED_Init();           //初始化LED端口
        KEY_Init();           //按鍵初始化
        LED1= 1;                          //先點亮燈
        u8print(dstr[0]);                 //系統(tǒng)啟動
         TIM3_Int_Init(5000-1,8400-1);        //定時器時鐘84M,分頻系數(shù)8400,所以84M/84000=10Khz的計數(shù)頻率,計數(shù)5000次為0.5
        for(w= 0; w< 600; w++){
                        if(1==ReadKey(GPIOC, GPIO_Pin_4)){
                                w=0;
                                u8print(dstr[1]);
                                TIM_SetCounter(TIM3, 2);
                                rd= TIM_GetCounter(TIM3);
                                md=(u16) rd;
                                u16toa(bt, md);
                u8print("\r\n定時器清零后計數(shù)器的值: ");
                                u8print(bt);
                                u8print(dstr[4]);
                                delay_ms(100);
            else{
                                u8print(dstr[2]);
                                md=(u16) rd;
                                u16toa(bt, md);
                u8print("\r\n定時器計數(shù)器的值: ");
                                u8print(bt);
                                delay_ms(100);
timer.c代碼:
#include "mfuncs.h"
#include "timer.h"
#include "delay.h"
#include "led.h"
void TIM3_Int_Init(u16 rear,u16 psc)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    TIM_TimeBaseInitStructure.TIM_Period = rear;
        TIM_TimeBaseInitStructure.TIM_Prescaler= psc;
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStructure);
        //TIM_ClearFlag(TIM1,TIM_FLAG_Update);                                                //清除中斷,以免一啟用就中斷
        TIM_ITConfig(TIM3,TIM_IT_Update, ENABLE);
        TIM_Cmd(TIM3, ENABLE);
        NVIC_InitStructure.NVIC_IRQChannel= TIM3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority= 0x01;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority= 0x03;
        NVIC_InitStructure.NVIC_IRQChannelCmd= ENABLE;
        NVIC_Init(& NVIC_InitStructure);
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3, TIM_IT_Update)== SET)
                LED1= !LED1;
                u8print("定時器時間中斷黃燈暫停...\r\n");
                u8print(".......................\r\n");
                delay_ms(1000);
                LED1= !LED1;
        TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
timer.h代碼
#ifndef _TIMER_H
#define _TIMER_H
#include "sys.h"
void TIM3_Int_Init(u16 arr,u16 psc);
#endif
key.c,key.h, led.c led.h之前的代碼都可借鑒,不在多列,以后不再一一羅列,只列main.c 與相關功能的.c, .h代碼。
六,點擊構建工程按鈕,編譯工程。(如下圖7所示)
圖7
七,點擊窗口左下方仿真按鈕,可見黃燈點亮仿真,按下按鈕,將定時器清零為數(shù)值2中斷仿真,延長定時器中斷時間。虛擬串口將定時器的數(shù)值變化顯示在屏。 (如下圖8,9,10所示)
圖8
圖9
圖10
八,選擇release,點擊構建工程按鈕,編譯工程生成Hex文件。(如下圖11所示)
圖11
九, 系列的001-003虛擬仿真與開發(fā)板對應已證明:虛擬仿真程序對于開發(fā)板有效,之后不再➕上下載到開發(fā)板的介紹。
附件Proteus8.9 仿真STM32407ZGT6系列007_定時器中斷在已安裝Proteus8.9的計算機文件夾中打開即可
需要進一步了解,請加入QQ群:976235464
Proteus8.9 仿真STM32407ZGT6系列007_定時器中斷.rar
353.65 KB, 下載次數(shù): 19, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
Powered by 單片機教程網
