樓主的單片機(jī)源程序:
- // 程序名稱:28BYJ-48步進(jìn)電機(jī)測試程序
- // 功能描述:步進(jìn)電機(jī)分別以單四拍、雙四拍、八拍驅(qū)動方式驅(qū)動,正反轉(zhuǎn)各360度
- // 單片機(jī): AT89S52,F(xiàn)OSC=12MHz
- // 硬件連接:P1.0----INA
- // P1.1----INB
- // P1.2----INC
- // P1.3----IND
- // 驅(qū)動板的驅(qū)動電壓和芯片邏輯供電電壓均為5V;
- // 步進(jìn)電機(jī)紅線接+5V驅(qū)動電壓,橙黃粉藍(lán)分別接OUT1、OUT2、OUT3、OUT4,
- // 注意外接電源要與單片機(jī)共地。
- // 維護(hù)記錄:2012.11.2 雙龍電子科技
- #include<reg52.h>
- #include <string.h>
- #define uint unsigned int
- #define uchar unsigned char
- uint i,j,k;
- uint N=128;//主軸旋轉(zhuǎn)度數(shù)設(shè)置,度數(shù)D=N*45/減速比,采用1:16減速比的步進(jìn)電機(jī),旋轉(zhuǎn)度數(shù)即為D=128*45/16=360度
- unsigned int cycle=0,Ti=2048;
- uchar code single_pos[4]={0x07,0x0b,0x0d,0x0e};//單四拍驅(qū)動方式正轉(zhuǎn)表 D-C-B-A
- uchar code single_rev[4]={0x0e,0x0d,0x0b,0x07};//單四拍驅(qū)動方式反轉(zhuǎn)表 A-B-C-D
- uchar code double_pos[4]={0x06,0x03,0x09,0x0c};//雙四拍驅(qū)動方式正轉(zhuǎn)表 AD-DC-CB-BA
- uchar code double_rev[4]={0x0c,0x09,0x03,0x06};//雙四拍驅(qū)動方式反轉(zhuǎn)表 AB-BC-CD-DA
- uchar code eight_pos[8]={0x06,0x07,0x03,0x0b,0x09,0x0d,0x0c,0x0e};//八拍驅(qū)動方式正轉(zhuǎn)表 AD-D-DC-C-CB-B-BA-A
- uchar code eight_rev[8]={0x0e,0x0c,0x0d,0x09,0x0b,0x03,0x07,0x06};//八拍驅(qū)動方式反轉(zhuǎn)表 A-AB-B-BC-C-CD-D-DA
- void m_single_pos();
- void m_single_rev();
- void m_double_pos();
- void m_double_rev();
- void m_eight_pos();
- void m_eight_rev();
- void delay_us(unsigned int aa);
- unsigned char tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
- unsigned char init=0,t=0;
- unsigned char m,tt;
- unsigned char rxch;//????
- unsigned char ReceiveFinish,ReceiveStart,ReceiveCnt;
- unsigned char RxdBuf;
- unsigned int TxdBuf[3];
- bit read_flag=0;
- /********************??z??**************************************/
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- /*******************???????(N*45/16)?***********************/
- void init_serialcom(void)//????????
- SCON=0x50; //UART???1,8???, ????
- TMOD=0x20; //???1???2,8?????
- PCON=0x80; //SMOD=1;
- TH1 = 0xFA; //Baud:9600fosc=11.0592MHz//TL1 = 0XFA;
- IE |= 0x90; //Enable Serial Interrupt
- TR1 = 1; //timer 1 run
- TH0=0X3C;
- TL0=0XB0;
- TR0=1;
- ET0=1;
- void serial_isr(void) interrupt 4 //????????
- unsigned char Rxdtemp;
- if(RI)
- RI=0;
- Rxdtemp = SBUF ;
- RxdBuf=Rxdtemp;
- void send_msg(char * msg)
- int i;
- i = 0;
- while(msg[i] != '\0')
- SBUF=msg[i];
- while(!TI); //?????????
- TI=0;
- i++;
- void time0_isr(void) interrupt 1
- TH0=0X3C;
- TL0=0XB0;
- // pwm=1;
- t++;
- if(t==20)
- t=0;
- // pwm=0;
- TH0=0X3C;
- TL0=0XB0;
- void send_char_com(char ch) //?????????
- SBUF=ch;
- TI=0;
- ES=1;
- //led=0;
- delay(200);
- //led=1;
- void main()
- char *msg;
- init_serialcom();
- memset(TxdBuf,0,sizeof(TxdBuf));
- msg = "\r\nReceiver is ready! \0";
- send_msg(msg);
- P0=0x00;//數(shù)碼管初始值
- while(1)
- switch(RxdBuf)
- case 0xF0: m_single_pos(); break;
- case 0xF1: m_single_rev(); break;
- case 0xF2: m_double_pos(); break;
- case 0xF3: m_double_rev(); break;
- case 0xF4: m_eight_pos(); break;
- case 0xF5: m_eight_rev(); break;
- default: break;
- /*******************單四拍驅(qū)動正轉(zhuǎn)(N*45/16)度***********************/
- P0=tab[0];
- for(k=0;k<N;k++)
- j=0;
- for(i=0;i<4;i++)//在單四拍工作方式下,一個脈沖轉(zhuǎn)子轉(zhuǎn)動角度為5.625*2=11.25度,四拍共45度
- P1=single_pos[j];
- delay(5);//適當(dāng)延時,保證轉(zhuǎn)子轉(zhuǎn)動時間,延時過短會丟拍
- j++;
- /*******************單四拍驅(qū)動反轉(zhuǎn)(N*45/16度)***********************/
- P0=tab[1];//數(shù)碼管顯示的數(shù)
- for(k=0;k<N;k++)
- j=0;
- P1=single_rev[j];
- delay(5);
- j++;
- /*******************雙四拍驅(qū)動正轉(zhuǎn)(N*45/16)度***********************/
- P0=tab[2];
- for(k=0;k<N;k++)
- j=0;
- for(i=0;i<4;i++)//在雙四拍工作方式下,一個脈沖轉(zhuǎn)子轉(zhuǎn)動角度為5.625*2=11.25度,四拍共45度
- P1=double_pos[j];
- delay(8);
- j++;
- /*******************雙四拍驅(qū)動反轉(zhuǎn)(N*45/16)度***********************/
- P0=tab[3];
- for(k=0;k<N;k++)
- j=0;
- P1=double_rev[j];
- delay(8);
- j++;
- /*******************八拍驅(qū)動正轉(zhuǎn)(N*45/16)度***********************/
- P0=tab[4];
- for(k=0;k<N;k++)
- j=0;
- for(i=0;i<8;i++)//在八拍工作方式下,一個脈沖轉(zhuǎn)子轉(zhuǎn)動角度為5.625度,八拍共45度
- P1=eight_pos[j];
- delay(2);
- j++;
- /*******************八拍驅(qū)動反轉(zhuǎn)(N*45/16)度***********************/
- P0=tab[5];
- for(k=0;k<N;k++)
- j=0;
- P1=eight_rev[j];
- delay(2);
- j++;
- while(aa--);
復(fù)制代碼 |
