查看: 2618|回復(fù): 2
基于51單片機(jī)+TM1640或者74hc573 非同一端口數(shù)碼管顯示程序
ID:155987 發(fā)表于 2020-4-28 10:19 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
TM1640芯片:
  1. #include <STC12C5A.H>
  2. #include "intrins.h"                   //包含_nop_()指令頭文件
  3. /********************定義控制端口**********************/
  4. sbit DIN=P4^1;                                   //定義DIN數(shù)據(jù)端口
  5. sbit CLK=P3^7;                                   //定義CLK數(shù)據(jù)端口
  6. sbit  HH1 = P2^4;
  7. sbit  HH2 = P2^3;
  8. sbit  HH3 = P2^2;
  9. sbit  HH4 = P2^1;
  10. sbit  LL1 = P2^0;
  11. sbit  LL2 = P0^7;
  12. sbit  LL3 = P0^6;
  13. sbit  LL4 = P0^5;
  14. unsigned char KeyValue = 20;//按鍵值 顯示-
  15. /********************定義數(shù)據(jù)*************************/
  16. //共陰數(shù)碼管段選表
  17. unsigned   code tabel[]= {
  18. //        1         2     3     4     5     6     7     8
  19. 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
  20. //9    0    A     B           C         D           E         F                H         L
  21. 0x6F, 0x3F,   0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x76, 0x38,
  22. //n           u          -          熄滅
  23. 0x37, 0x3E, 0x40, 0x00 };
  24. /********************延時(shí)函數(shù),延時(shí)nms******************/
  25. void delay(unsigned z)
  26. {
  27.    unsigned x,y;
  28.         for(x=z;x>0;x--)
  29.                 for(y=300;y>0;y--);
  30. }
  31. /*====================================
  32. 函數(shù)        :KeyScan()
  33. 參數(shù)        :無(wú)
  34. 返回值        :無(wú)
  35. 描述        :4*4矩陣鍵盤與獨(dú)立鍵盤掃描
  36. 按鍵按下KeyValue全局變量值發(fā)生相應(yīng)變化
  37. ====================================*/
  38. char  KeyScan(void)   //行列掃描
  39. {
  40.     HH1 = 0;
  41.     if (!LL1)         KeyValue =0;
  42.     if (!LL2)         KeyValue =1;
  43.     if (!LL3)          KeyValue =2;
  44.     if (!LL4)          KeyValue =3;
  45.     HH1 = 1;
  46.     HH2 = 0;
  47.     if (!LL1)         KeyValue =4;
  48.     if (!LL2)          KeyValue =5;
  49.     if (!LL3)          KeyValue =6;
  50.     if (!LL4)          KeyValue =7;
  51.     HH2 = 1;
  52.     HH3 = 0;
  53.     if (!LL1)          KeyValue = 8;
  54.     if (!LL2)          KeyValue = 9;
  55.     if (!LL3)          KeyValue = 10;
  56.     if (!LL4)          KeyValue = 11;
  57.     HH3 = 1;
  58.     HH4 = 0;
  59.     if (!LL1)          KeyValue =12;
  60.     if (!LL2)          KeyValue =13;
  61.     if (!LL3)          KeyValue =14;
  62.     if (!LL4)          KeyValue =15;
  63.     HH4 = 1;
  64.         HH1=1;
  65.         if(!HH1)   KeyValue =16;
  66.         HH2=2;
  67.         if(!HH2)   KeyValue =17;
  68.     HH3=3;
  69.         if(!HH3)   KeyValue =18;
  70.         HH4=4;
  71.         if(!HH4)   KeyValue =19;
  72.     return 255;    //沒(méi)有按鍵,就返回 255
  73. }
  74. /********************Start函數(shù)*************************/
  75. void I2CStart()
  76. {
  77.     DIN=1;
  78.     CLK=1;
  79.         delay(2);
  80.         DIN=1;
  81.         delay(2);
  82.         DIN=0;
  83.         delay(4);
  84.         CLK=0;
  85.         delay(2);
  86. }
  87. /********************Stop函數(shù)*************************/
  88. void I2CStop()
  89. {
  90.         CLK=1;
  91.         delay(2);
  92.         DIN=0;
  93.         delay(2);
  94.         DIN=1;
  95.         delay(2);
  96.         CLK=0;
  97.         DIN=0;
  98. }
  99. /***************發(fā)送8bit數(shù)據(jù),從低位開始**************/
  100. void I2CWritebyte(unsigned char oneByte)
  101. {
  102.   unsigned char i;
  103.   for(i=0;i<8;i++)
  104.   {
  105.     CLK=0;
  106.         if(oneByte&0x01)
  107.           DIN=1;
  108.         else
  109.           DIN=0;
  110.         delay(3);
  111.         CLK=1;
  112.         oneByte=oneByte>>1;
  113.         }
  114.         CLK=0;
  115.         delay(4);
  116.         DIN=0;
  117.         delay(2);
  118. }
  119. void main()
  120. {
  121. while(1){
  122. unsigned char i;
  123. I2CStart();
  124. I2CWritebyte(0x40);        //數(shù)據(jù)命令設(shè)置:普通模式,地址自動(dòng)加一
  125. I2CStop();
  126. I2CStart();
  127. I2CWritebyte(0xc0);        //地址命令設(shè)置:初始地址00H
  128. for(i=0;i<1;i++)        //發(fā)送16位顯示數(shù)據(jù)
  129. {
  130.   KeyScan();//20個(gè)按鍵鍵盤掃描
  131.   I2CWritebyte(tabel[KeyValue]);         //顯示按鍵值
  132. }
  133. I2CStop();
  134. I2CStart();
  135. I2CWritebyte(0x8c);        //顯示控制:顯示開,脈沖寬度設(shè)為11/16
  136. I2CStop();
  137.          }
  138. }
74HC573芯片:
  1. #include<reg51.h>
  2. #include <intrins.h>//包含移位標(biāo)準(zhǔn)庫(kù)函數(shù)頭文件
  3. #define uint unsigned int
  5. sbit DU = P2^6;//數(shù)碼管段選
  6. sbit WE = P2^7;//數(shù)碼管段選
  7. uchar num;//數(shù)碼管顯示的值
  8. uchar KeyValue = 20;//按鍵值 顯示-
  9. //共陰數(shù)碼管段選表
  10. uchar  code tabel[]= {
  11. //0                1         2     3     4     5     6     7     8
  12. 0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
  13. //9     A     B           C         D           E         F                H         L
  14. 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x76, 0x38,
  15. //n           u          -          熄滅
  16. 0x37, 0x3E, 0x40, 0x00 };
  17. /*====================================
  18. 函數(shù)        : delay(uint z)
  19. 參數(shù)        :z 延時(shí)毫秒設(shè)定,取值范圍0-65535
  20. 返回值        :無(wú)
  21. 描述        :12T/Fosc11.0592M毫秒級(jí)延時(shí)
  22. ====================================*/
  23. void delay(uint z)
  24. {
  25.         uint x,y;
  26.         for(x = z; x > 0; x--)
  27.                 for(y = 114; y > 0 ; y--);
  28. }
  29. /*====================================
  30. 函數(shù)        :KeyScan()
  31. 參數(shù)        :無(wú)
  32. 返回值        :無(wú)
  33. 描述        :4*4矩陣鍵盤與獨(dú)立鍵盤掃描
  34. 按鍵按下KeyValue全局變量值發(fā)生相應(yīng)變化
  35. ====================================*/
  36. sbit  HH1 = P3^0;
  37. sbit  HH2 = P3^1;
  38. sbit  HH3 = P3^2;
  39. sbit  HH4 = P3^3;
  40. sbit  LL1 = P3^4;
  41. sbit  LL2 = P3^5;
  42. sbit  LL3 = P3^6;
  43. sbit  LL4 = P3^7;
  44. char  KeyScan(void)   //行列掃描
  45. {
  46.     HH1 = 0;
  47.     if (!LL1)         KeyValue =0;
  48.     if (!LL2)         KeyValue =1;
  49.     if (!LL3)          KeyValue =2;
  50.     if (!LL4)          KeyValue =3;
  51.     HH1 = 1;
  52.     HH2 = 0;
  53.     if (!LL1)         KeyValue =4;
  54.     if (!LL2)          KeyValue =5;
  55.     if (!LL3)          KeyValue =6;
  56.     if (!LL4)          KeyValue =7;
  57.     HH2 = 1;
  58.     HH3 = 0;
  59.     if (!LL1)          KeyValue = 8;
  60.     if (!LL2)          KeyValue = 9;
  61.     if (!LL3)          KeyValue = 10;
  62.     if (!LL4)          KeyValue = 11;
  63.     HH3 = 1;
  64.     HH4 = 0;
  65.     if (!LL1)          KeyValue =12;
  66.     if (!LL2)          KeyValue =13;
  67.     if (!LL3)          KeyValue =14;
  68.     if (!LL4)          KeyValue =15;
  69.     HH4 = 1;
  70.     return 255;    //沒(méi)有按鍵,就返回 255
  71. }
  72. void main()//main函數(shù)自身會(huì)循環(huán)
  73. {
  74.         WE = 1;//打開位選鎖存器
  75.         P0 = 0XFE; //1111 1110
  76.         WE = 0;//鎖存位選數(shù)據(jù)
  77.         DU = 1;//打開段選鎖存器
  78.         while(1)
  79.         {
  80.                 KeyScan();//20個(gè)按鍵鍵盤掃描
  81.                 P0 = tabel[KeyValue];//顯示按鍵值
  82.         }
  83. }
TM1640矩陣鍵盤.rar
23.58 KB, 下載次數(shù): 19, 下載積分: 黑幣 -5
74HC573矩陣鍵盤.rar
16.47 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
ID:1 發(fā)表于 2020-4-28 14:29 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:540283 發(fā)表于 2020-6-24 15:02 | 只看該作者
不錯(cuò),好歹點(diǎn)亮了一個(gè)數(shù)碼管。很有參考意義
