查看: 2327|回復: 2
ADXL345自動休眠配置
ID:588723 發(fā)表于 2020-4-29 11:38 | 顯示全部樓層 |閱讀模式
  1. u8 ADXL345_Init(uint8 AClimit,uint8 STlimit,uint8 time)
  2. {
  3.   IIC_Init();                                                        //初始化IIC總線
  4.   if(ADXL345_RD_Reg(DEVICE_ID)==0XE5)        //讀取器件ID
  5.   {
  6.     ADXL345_RD_Reg(0x30);
  7.     ADXL345_WR_Reg(DATA_FORMAT,0X0B);//   中斷高低電平觸發(fā)
  8.     ADXL345_WR_Reg(BW_RATE,0x1c);   // 低功耗 和速率設置
  9.     ADXL345_WR_Reg(POWER_CTL,0x28);
  10.     ADXL345_WR_Reg(INT_ENABLE,0x00);
  11.     ADXL345_WR_Reg (0x2d, 0x38);  // measure and wake up 8hz  08   38
  12.     ADXL345_WR_Reg (0x24, AClimit); //活動觸發(fā)閾值
  13.     ADXL345_WR_Reg (0x27, 0xff); //比較法 3軸比較
  14.     ADXL345_WR_Reg (0x2b, 0x70); //第一 軸比較
  15.     ADXL345_WR_Reg (0x2F, 0x10);  // int map reg 0 means INT2中斷選擇
  16.     ADXL345_WR_Reg (0x2E, 0x18);  // int enable reg 中斷開啟
  17.     ADXL345_WR_Reg (0x25, STlimit); //靜止閾值
  18.     ADXL345_WR_Reg (0x26, time); //靜止觸發(fā)時間 s
  19.     ADXL345_WR_Reg(OFSX,0x00);
  20.     ADXL345_WR_Reg(OFSY,0x00);
  21.     ADXL345_WR_Reg(OFSZ,0x00);
  22.     ADXL345_RD_Reg(0x30);
  23.     return 0;
  24.   }
  25.   return 1;
  26. }
復制代碼
admin + 50 共享資料的黑幣獎勵!
ID:588723 發(fā)表于 2020-4-29 11:39 | 顯示全部樓層
實測能正常使用  能設置休眠時間  喚醒閾值 和休眠閾值
ID:588278 發(fā)表于 2021-12-16 14:57 | 顯示全部樓層
a915533130 發(fā)表于 2020-4-29 11:39
活動觸發(fā)閾值有大小限制嗎?比如必須得大于1g?
Powered by 單片機教程網
