51單片機驅(qū)動lcd12864,無字庫串口屏
2020-5-4 16:14 上傳
單片機源程序如下:
- /* 液晶演示程序
- 液晶模塊型號:JLX12864G-086-PN(或12864G-0088),串行接口!
- 驅(qū)動IC是:UC1701X或兼容的IC,比如ST7565R
- 編寫:葉先生,11月5日,13年
- 版權(quán)所有:晶聯(lián)訊
- #include <reg52.H>
- #include <intrins.h>
- #include<string.h>
- sbit sclk=P2^3; //接口定義:lcd_sclk就是LCD的sclk
- sbit sid=P2^4; //接口定義:lcd_sid就是LCD的sid
- sbit rs=P2^5; //接口定義:lcd_rs就是LCD的rs
- sbit reset=P2^6; //接口定義:lcd_reset就是LCD的reset
- sbit cs1=P2^7; //接口定義:lcd_cs1就是LCD的cs1
- sbit key=P2^0; //定義一個按鍵
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- char code huang[]={
- /*-- 文字: 黃 --*/
- /*-- 宋體12; 此字體下對應(yīng)的點陣為:寬x高=16x16 --*/
- 0x10,0x10,0x12,0xD2,0x52,0x5F,0x52,0xF2,0x52,0x5F,0x52,0xD2,0x12,0x10,0x10,0x00,
- 0x00,0x00,0x00,0x9F,0x52,0x32,0x12,0x1F,0x12,0x32,0x52,0x9F,0x00,0x00,0x00,0x00};
- char code he[]={
- /*-- 文字: 河 --*/
- 0x10,0x60,0x02,0x8C,0x00,0x04,0xE4,0x24,0x24,0xE4,0x04,0x04,0xFC,0x04,0x04,0x00,
- 0x04,0x04,0x7E,0x01,0x00,0x00,0x0F,0x04,0x04,0x0F,0x40,0x80,0x7F,0x00,0x00,0x00};
- char code yuan[]={
- /*-- 文字: 遠(yuǎn) --*/
- 0x40,0x40,0x42,0xCC,0x00,0x20,0x22,0xE2,0x22,0x22,0xE2,0x22,0x22,0x20,0x00,0x00,
- 0x00,0x80,0x40,0x3F,0x40,0xA0,0x98,0x87,0x80,0x80,0x9F,0xA0,0xA0,0xBC,0x80,0x00};
- char code shang[]={
- /*-- 文字: 上 --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x00,0x00,
- 0x40,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00};
- char code bai[]={
- /*-- 文字: 白 --*/
- 0x00,0x00,0xF8,0x08,0x08,0x0C,0x0A,0x09,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,0x00,
- 0x00,0x00,0xFF,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0xFF,0x00,0x00,0x00};
- char code yun[]={
- /*-- 文字: 云 --*/
- 0x40,0x40,0x42,0x42,0x42,0x42,0xC2,0x42,0x42,0x42,0x42,0x42,0x42,0x40,0x40,0x00,
- 0x00,0x20,0x70,0x28,0x24,0x23,0x20,0x20,0x20,0x24,0x28,0x30,0xE0,0x00,0x00,0x00};
- char code jian[]={
- /*-- 文字: 間 --*/
- 0x00,0xF8,0x01,0x06,0x00,0xF0,0x12,0x12,0x12,0xF2,0x02,0x02,0x02,0xFE,0x00,0x00,
- 0x00,0xFF,0x00,0x00,0x00,0x1F,0x11,0x11,0x11,0x1F,0x00,0x40,0x80,0x7F,0x00,0x00};
- char code dou[]={
- /*-- 文字: , --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- char code yi[]={
- /*-- 文字: 一 --*/
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- char code pian[]={
- /*-- 文字: 片 --*/
- 0x00,0x00,0x00,0xFE,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x00,0x00,
- 0x00,0x80,0x60,0x1F,0x02,0x02,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x00};
- char code gu[]={
- /*-- 文字: 孤 --*/
- 0x02,0x02,0xF2,0x8A,0x46,0x00,0xFC,0x04,0xFC,0x04,0x02,0xFE,0x03,0x02,0x00,0x00,
- 0x42,0x82,0x7F,0x00,0x80,0x60,0x1F,0x00,0x7F,0x28,0x10,0x61,0x0E,0x30,0x40,0x00};
- char code cheng[]={
- /*-- 文字: 城 --*/
- 0x20,0x20,0xFF,0x20,0x20,0xF8,0x88,0x88,0x88,0x08,0xFF,0x08,0x09,0xCA,0x08,0x00,
- 0x10,0x30,0x1F,0x88,0x68,0x1F,0x10,0x20,0x9F,0x40,0x27,0x18,0x26,0x41,0xF0,0x00};
- char code wan[]={
- /*-- 文字: 萬 --*/
- 0x04,0x04,0x04,0x04,0x04,0xFC,0x44,0x44,0x44,0x44,0x44,0xC4,0x04,0x04,0x04,0x00,
- 0x80,0x40,0x20,0x18,0x06,0x01,0x00,0x00,0x40,0x80,0x40,0x3F,0x00,0x00,0x00,0x00};
- char code ren[]={
- /*-- 文字: 仞 --*/
- 0x00,0x80,0x60,0xF8,0x07,0x00,0xE4,0x04,0x04,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
- 0x01,0x00,0x00,0xFF,0x80,0x41,0x20,0x18,0x07,0x00,0x40,0x80,0x40,0x3F,0x00,0x00};
- char code shan[]={
- /*-- 文字: 山 --*/
- 0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,
- 0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,0x00};
- char code qiang[]={
- /*-- 文字: 羌 --*/
- 0x00,0x08,0x48,0x48,0x49,0x4E,0xC8,0x78,0x48,0x4C,0x4B,0x48,0x48,0x08,0x00,0x00,
- 0x82,0x82,0x42,0x22,0x12,0x0E,0x03,0x02,0x7E,0x82,0x82,0x82,0x82,0x82,0xE2,0x00};
- char code di[]={
- /*-- 文字: 笛 --*/
- 0x20,0x10,0xCC,0x47,0x4C,0x54,0x44,0xF4,0x48,0x47,0x44,0x4C,0xD4,0x04,0x04,0x00,
- 0x00,0x00,0xFF,0x44,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,0x00};
- char code he1[]={
- /*-- 文字: 何 --*/
- 0x00,0x80,0x60,0xF8,0x07,0x04,0xE4,0x24,0x24,0xE4,0x04,0x04,0xFC,0x04,0x04,0x00,
- 0x01,0x00,0x00,0xFF,0x00,0x00,0x0F,0x04,0x04,0x0F,0x40,0x80,0x7F,0x00,0x00,0x00};
- char code xu[]={
- /*-- 文字: 須 --*/
- 0x20,0x10,0x08,0x84,0x63,0x00,0x00,0xF2,0x12,0x1A,0xD6,0x12,0x12,0xF2,0x02,0x00,
- 0x84,0x42,0x21,0x10,0x08,0x06,0x80,0x4F,0x20,0x18,0x07,0x10,0x20,0x4F,0x80,0x00};
- char code yuan1[]={
- /*-- 文字: 怨 --*/
- 0x10,0x08,0x14,0xA7,0x44,0x24,0x1C,0x00,0xFE,0x02,0x12,0x22,0x1E,0xC0,0x00,0x00,
- 0x42,0x32,0x01,0x00,0x38,0x40,0x40,0x44,0x58,0x41,0x41,0x71,0x01,0x09,0x30,0x00};
- char code yang[]={
- /*-- 文字: 楊 --*/
- 0x10,0x10,0xD0,0xFF,0x90,0x10,0x00,0x42,0xE2,0x52,0x4A,0xC6,0x42,0x40,0xC0,0x00,
- 0x04,0x03,0x00,0xFF,0x00,0x23,0x10,0x8C,0x43,0x20,0x18,0x47,0x80,0x40,0x3F,0x00};
- char code liu[]={
- /*-- 文字: 柳 --*/
- 0x10,0x10,0xD0,0xFF,0x90,0x10,0xFC,0x04,0x02,0xF8,0x00,0xFC,0x04,0x04,0xFC,0x00,
- 0x04,0x03,0x00,0xFF,0x00,0x01,0x8F,0x44,0x32,0x0F,0x00,0xFF,0x04,0x08,0x07,0x00};
- char code chun[]={
- /*-- 文字: 春 --*/
- 0x40,0x44,0x54,0x54,0xD4,0x54,0x74,0x5F,0x54,0x54,0xD4,0x54,0x54,0x44,0x40,0x00,
- 0x04,0x04,0x02,0x01,0xFE,0x92,0x92,0x92,0x92,0x92,0xFE,0x01,0x02,0x04,0x04,0x00};
- char code feng[]={
- /*-- 文字: 風(fēng) --*/
- 0x00,0x00,0xFE,0x02,0x12,0x22,0xC2,0x02,0xC2,0x32,0x02,0xFE,0x00,0x00,0x00,0x00,
- 0x80,0x60,0x1F,0x00,0x20,0x10,0x0C,0x03,0x0C,0x30,0x00,0x0F,0x30,0x40,0xF8,0x00};
- char code bu[]={
- /*-- 文字: 不 --*/
- 0x00,0x02,0x02,0x02,0x02,0x82,0x42,0xF2,0x0E,0x42,0x82,0x02,0x02,0x02,0x00,0x00,
- 0x10,0x08,0x04,0x02,0x01,0x00,0x00,0xFF,0x00,0x00,0x00,0x01,0x02,0x0C,0x00,0x00};
- char code du[]={
- /*-- 文字: 度 --*/
- 0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0x25,0x26,0x24,0xFC,0x24,0x24,0x24,0x04,0x00,
- 0x40,0x30,0x8F,0x80,0x84,0x4C,0x55,0x25,0x25,0x25,0x55,0x4C,0x80,0x80,0x80,0x00};
- char code yu[]={
- /*-- 文字: 玉 --*/
- 0x00,0x02,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x82,0x02,0x00,0x00,
- 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x44,0x58,0x40,0x40,0x40,0x00};
- char code men[]={
- /*-- 文字: 門 --*/
- 0x00,0xF8,0x01,0x06,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,
- 0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00};
- char code guan[]={
- /*-- 文字: 關(guān) --*/
- 0x00,0x00,0x10,0x11,0x16,0x10,0x10,0xF0,0x10,0x10,0x14,0x13,0x10,0x00,0x00,0x00,
- 0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00};
- char code ju[]={
- /*-- 文字: 。 --*/
- 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- /*延時*/
- void delay(int i)
- int j,k;
- for(j=0;j<i;j++)
- for(k=0;k<110;k++);
- //短延時
- void delay_us(int i)
- int j,k;
- for(j=0;j<i;j++)
- for(k=0;k<1;k++);
- void waitkey()
- repeat: if(key==1) goto repeat;
- else delay(200);
- /*寫指令到LCD模塊*/
- void transfer_command(int data1)
- char i;
- cs1=0;
- rs=0;
- for(i=0;i<8;i++)
- sclk=0;
- if(data1&0x80) sid=1;
- else sid=0;
- sclk=1;
- data1<<=1;
- cs1=1;
- /*寫數(shù)據(jù)到LCD模塊*/
- void transfer_data(int data1)
- char i;
- cs1=0;
- rs=1;
- for(i=0;i<8;i++)
- sclk=0;
- else sid=0;
- sclk=1;
- data1<<=1;
- cs1=1;
- /*LCD模塊初始化*/
- void initial_lcd()
- cs1=0;
- reset=0; /*低電平復(fù)位*/
- delay(500);
- reset=1; /*復(fù)位完畢*/
- delay(200);
- transfer_command(0xe2); /*軟復(fù)位*/
- delay(50);
- transfer_command(0x2c); /*升壓步聚1*/
- delay(50);
- transfer_command(0x2e); /*升壓步聚2*/
- delay(50);
- transfer_command(0x2f); /*升壓步聚3*/
- delay(50);
- transfer_command(0x23); /*粗調(diào)對比度,可設(shè)置范圍0x20~0x27*/
- transfer_command(0x81); /*微調(diào)對比度*/
- transfer_command(0x28); /*0x28,微調(diào)對比度的值,可設(shè)置范圍0x00~0x3f*/
- transfer_command(0xa2); /*1/9偏壓比(bias)*/
- transfer_command(0xc8); /*行掃描順序:從上到下*/
- transfer_command(0xa0); /*列掃描順序:從左到右*/
- transfer_command(0x40); /*起始行:第一行開始*/
- transfer_command(0xaf); /*開顯示*/
- void lcd_address(uchar page,uchar column)
- column=column-1; //我們平常所說的第1列,在LCD驅(qū)動IC里是第0列。所以在這里減去1.
- page=page-1;
- transfer_command(0xb0+page); //設(shè)置頁地址。每頁是8行。一個畫面的64行被分成8個頁。我們平常所說的第1頁,在LCD驅(qū)動IC里是第0頁,所以在這里減去1*/
- transfer_command(((column>>4)&0x0f)+0x10); //設(shè)置列地址的高4位
- transfer_command(column&0x0f); //設(shè)置列地址的低4位
- /*全屏清屏*/
- void clear_screen()
- uchar i,j;
- for(i=0;i<9;i++)
- lcd_address(1+i,1);
- for(j=0;j<132;j++)
- transfer_data(0x00);
- //顯示16x16點陣圖像、漢字。
- //括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- void disp_blink_16x16(uchar page,uchar column,uchar blink,uchar reverse,uchar *dp)
- uchar i,j,k,*data_temp;
- if(blink==0)
- data_temp=dp;
- for(j=0;j<2;j++)
- lcd_address(page+j,column);
- for (i=0;i<16;i++)
- if(reverse==1)
- transfer_data(~*data_temp); /*寫數(shù)據(jù)到LCD,每寫完一個8位的數(shù)據(jù)后列地址自動加1*/
- else
- transfer_data(*data_temp); /*寫數(shù)據(jù)到LCD,每寫完一個8位的數(shù)據(jù)后列地址自動加1*/
- data_temp++;
- else
- for(k=0;k<10;k++)
- data_temp=dp;
- for(j=0;j<2;j++)
- data_temp++;
- delay(2000);
- data_temp=dp;
- for(j=0;j<2;j++)
- data_temp++;
- delay(2000);
- //顯示16x16點陣圖像、漢字。
- //括號里的參數(shù)分別是(頁,列,帶下劃線閃爍與否,反顯與否,數(shù)據(jù)指針)
- void disp_underline_16x16(uchar page,uchar column,uchar under,uchar reverse,uchar *dp)
- uchar i,j,k,*data_temp,data1;
- if(under==0)
- data_temp=dp;
- for(j=0;j<2;j++)
- if(reverse==1)
- else
- data_temp++;
- else
- for(k=0;k<10;k++)
- data_temp=dp;
- lcd_address(page,column);
- data_temp++;
- lcd_address(page+1,column);
- data1=*data_temp|0x80;
- transfer_data(data1); /*寫數(shù)據(jù)到LCD,每寫完一個8位的數(shù)據(jù)后列地址自動加1*/
- data_temp++;
- delay(2000);
- data_temp=dp;
- for(j=0;j<2;j++)
- data_temp++;
- delay(2000);
- //顯示16x16點陣圖像、漢字。
- //括號里的參數(shù)分別是(頁,列,帶右豎線光標(biāo)閃爍與否,反顯與否,數(shù)據(jù)指針)
- void disp_cursor_16x16(uchar page,uchar column,uchar cursor,uchar reverse,uchar *dp)
- if(cursor==0)
- data_temp=dp;
- for(j=0;j<2;j++)
- if(reverse==1)
- else
- data_temp++;
- else
- for(k=0;k<10;k++)
- data_temp=dp;
- for (i=0;i<15;i++)
- data_temp++;
- transfer_data(0xff);
- data_temp++;
- data_temp++;
- data_temp++;
- delay(2000);
- data_temp=dp;
- for(j=0;j<2;j++)
- data_temp++;
- delay(2000);
- //主函數(shù):
- void main(void)
- initial_lcd(); //初始化LCD
- clear_screen(); //清屏
- while(1)
- disp_blink_16x16(1, 1,0,0,huang); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(1,17,0,0,he); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(1,33,0,0,yuan); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(1,49,0,0,shang); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(1,65,0,0,bai); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(1,81,0,0,yun); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(1,97,0,0,jian); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(1,113,0,0,dou); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(3, 1,0,0,yi); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(3,17,0,0,pian); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(3,33,0,0,gu); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(3,49,0,0,cheng); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(3,65,0,0,wan); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(3,81,0,0,ren); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(3,97,0,0,shan); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(3,113,0,0,dou); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(5, 1,0,0,qiang); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(5,17,0,0,di); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(5,33,0,0,he1); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(5,49,0,0,xu); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(5,65,0,0,yuan1); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(5,81,0,0,yang); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(5,97,0,0,liu); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(5,113,0,0,dou); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(7, 1,0,0,chun); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(7,17,0,0,feng); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(7,33,0,0,bu); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(7,49,0,0,du); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
- disp_blink_16x16(7,65,0,0,yu); //顯示單個漢字"狀". 括號里的參數(shù)分別是(頁,列,閃爍與否,反顯與否,數(shù)據(jù)指針)
- disp_blink_16x16(7,81,0,0,men); //顯示單個漢字"態(tài)",不閃爍,反顯
- disp_blink_16x16(7,97,0,0,guan); //顯示單個漢字"使",閃爍,不反顯
- disp_blink_16x16(7,113,0,0,ju); //顯示單個漢字"用",閃爍,反顯(當(dāng)有閃爍時,反顯不起作用)
program.rar
(44.18 KB, 下載次數(shù): 201)
2020-5-4 16:15 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
