- #include "reg52.h"
- #include <intrins.h>
- sbit IN1=P1^0; //定義驅(qū)動模塊IN1為P1.0 左上電機 M2 OUT1 OUT2
- sbit IN2=P1^1; //定義驅(qū)動模塊IN2為P1.1
- sbit IN3=P1^2; //定義驅(qū)動模塊IN3為P1.2 左下電機 M3 OUT3 OUT4
- sbit IN4=P1^3; //定義驅(qū)動模塊IN4為P1.3
- sbit IN5=P1^4; //定義驅(qū)動模塊IN5為P1.4 右上電機 M1 OUT5 OUT6
- sbit IN6=P1^5; //定義驅(qū)動模塊IN6為P1.5
- sbit IN7=P1^6; //定義驅(qū)動模塊IN7為P1.6 右下電機 M4 OUT7 OUT8
- sbit IN8=P1^7; //定義驅(qū)動模塊IN8為P1.7
- //尋跡探頭
- sbit left_led=P2^5; //定義左路尋跡為P2.5
- sbit middle_led=P2^6; //定義中路尋跡為P2.6
- sbit right_led=P2^7; //定義右路尋跡為P2.7
- #define Left_moto_go {IN1=1,IN2=0,IN3=1,IN4=0;} //左邊兩個電機向前走
- #define Left_moto_back {IN1=0,IN2=1,IN3=0,IN4=1;} //左邊兩個電機向后轉(zhuǎn)
- #define Left_moto_Stop {IN1=0,IN2=0,IN3=0,IN4=0;} //左邊兩個電機停轉(zhuǎn)
- #define Right_moto_go {IN5=1,IN6=0,IN7=1,IN8=0;} //右邊兩個電機向前走
- #define Right_moto_back {IN5=0,IN6=1,IN7=0,IN8=1;} //右邊兩個電機向后轉(zhuǎn)
- #define Right_moto_Stop {IN5=0,IN6=0,IN7=0,IN8=0;} //右邊兩個電機停轉(zhuǎn)
- #define M2_moto_pwm IN2 //PWM信號端 左上電機M2
- #define M3_moto_pwm IN4 // 左下電機M3
- #define M1_moto_pwm IN6 // 右上電機M1
- #define M4_moto_pwm IN8 // 右下電機M4
- //PWM 尋跡中調(diào)速
- unsigned char pwm_val_left =0;//變量定義
- unsigned char push_val_left =0;//左電機占空比N/10
- unsigned char pwm_val_right =0;//變量定義
- unsigned char push_val_right=0;//右電機占空比N/10
- bit Right_moto_stop=1; //在右電機調(diào)速時,如果右電機停止,PWM小于PUSH,PWM置1,否則為0;若PWM≥10,PWM關(guān)斷
- bit Left_moto_stop =1; //在左電機調(diào)速時,如果右電機停止,PWM小于PUSH,PWM置1,否則為0;若PWM≥10,PWM關(guān)斷
- unsigned int timer1=0;
- // sfr T2CON = 0xC8;
- sfr T2MOD = 0xC9;
- // sfr RCAP2L = 0xCA;
- // sfr RCAP2H = 0xCB;
- // sfr TL2 = 0xCC;
- // sfr TH2 = 0xCD;
- //藍牙數(shù)據(jù)發(fā)送
- #define left 'C' //左轉(zhuǎn)發(fā)送數(shù)據(jù)C
- #define right 'D' //右轉(zhuǎn)發(fā)送數(shù)據(jù)D
- #define up 'A' //前進發(fā)送數(shù)據(jù)A
- #define down 'B' //后退發(fā)送數(shù)據(jù)B
- #define stop 'F' //停止發(fā)送數(shù)據(jù)F
- #define Car '1' //手機軟件1號鍵 表示尋跡按鈕
- char code str[] = "收到指令,向前!\n";
- char code str1[] = "收到指令,向后!\n";
- char code str2[] = "收到指令,向左!\n";
- char code str3[] = "收到指令,向右!\n";
- char code str4[] = "收到指令,停止!\n";
- unsigned char i=0;
- unsigned char dat=0;
- unsigned char buff[5]=0; //接收緩沖字節(jié)
- // 程序功能
- bit flag_REC=0; //串行接收標去位
- bit flag =0; //
- bit flag_xj =0; //尋跡標志
- //延時函數(shù)
- void delay(unsigned int k)
- unsigned int x,y;
- for(x=0;x<k;x++)
- for(y=0;y<2000;y++);
- //前進函數(shù) 加入PWM
- void run_pwm(void)
- push_val_left=9; //速度調(diào)節(jié)變量 0-9。。。9最小,0最大
- push_val_right=9; //速度調(diào)節(jié)變量 0-9。。。9最小,0最大
- Left_moto_go ; //左電機往前走
- Right_moto_go ; //右電機往前走
- //后退函數(shù) 加入PWM
- void backrun_pwm(void)
- Left_moto_back ; //左電機往后走
- Right_moto_back ; //右電機往后走
- //左轉(zhuǎn)函數(shù) 加入PWM
- void leftrun_pwm(void)
- Left_moto_Stop ; //左電機往前走
- Right_moto_go ; //右電機往后走
- //右轉(zhuǎn)函數(shù) 加入PWM
- void rightrun_pwm(void)
- push_val_left=9; //減低一半速度 速度調(diào)節(jié)變量 0-9。。。9最小,0最大
- push_val_right=9; //減低一半速度 速度調(diào)節(jié)變量 0-9。。。9最小,0最大
- Right_moto_Stop ; //右電機往后走
- //小車停止
- void keepstop(void)
- Right_moto_Stop ; //右電機往前走
- //小車前進 全速
- void run(void)
- //小車后退 全速
- void backrun(void)
- //左轉(zhuǎn)函數(shù) 全速
- void leftrun(void)
- //右轉(zhuǎn)函數(shù) 全速
- void rightrun(void)
- //左電機調(diào)速
- void pwm_out_left_moto(void)
- if(Left_moto_stop)
- if(pwm_val_left<=push_val_left)
- M2_moto_pwm=1; //M2的PWM
- M3_moto_pwm=1; //M3的PWM
- else
- M2_moto_pwm=0;
- M3_moto_pwm=0;
- if(pwm_val_left>=10)
- pwm_val_left=0;
- else
- M2_moto_pwm=0;
- M3_moto_pwm=0;
- //右電機調(diào)速
- void pwm_out_right_moto(void)
- if(Right_moto_stop)
- if(pwm_val_right<=push_val_right)
- M1_moto_pwm=1; //M1
- M4_moto_pwm=1; //M4
- else
- M1_moto_pwm=0;
- M4_moto_pwm=0;
- if(pwm_val_right>=10)
- pwm_val_right=0;
- else
- M1_moto_pwm=0;
- M4_moto_pwm=0;
- void Time1(void) interrupt 3 //3 為定時器1的中斷號 1 定時器0的中斷號 0 外部中斷1 2 外部中斷2 4 串口中斷
- TH1 = 0xFF;
- TL1 = 0x9C;
- timer1++;
- pwm_val_left++;
- pwm_val_right++;
- pwm_out_left_moto();
- pwm_out_right_moto();
- //中斷號為4 串口中斷
- void sint() interrupt 4 //中斷接收3個字節(jié)
- if(RI) //是否接收中斷
- RI=0;
- dat=SBUF;
- if(dat=='O'&&(i==0)) //接收數(shù)據(jù)第一幀
- buff[i]=dat;
- flag=1; //開始接收數(shù)據(jù)
- else
- if(flag==1)
- i++;
- buff[i]=dat;
- if(i>=2)
- {i=0;flag=0;flag_REC=1 ;} // 停止接收
- //主函數(shù)
- void mian(void)
- { // T1 T0
- TMOD=0x11; // 0001 0001 工作方式3 兩個獨立8位計數(shù)器
- TH1=0xFF; //100uS定時 高8位
- TL1=0x9c; // 低8位
- TH0=0;
- TL0=0;
- T2CON=0x34; //8位寄存器0011 0100 串行發(fā)送時鐘 TCLK=1, T2工作于波特率發(fā)生器方式
- T2MOD=0x00; // 串行接收時鐘 RCLK=1,T2工作于波特率發(fā)生器方式
- RCAP2H=0xFF; // 為1時外部事件計數(shù),為0時T2為定時器
- RCAP2L=0xDC ; //波特率位4800 12/[32*(65536-x)]
- SCON=0x50;
- PCON=0x00;
- PS=1;
- TR1=1; // 定時器1工作
- ET1=1; // 打開定時器1中斷
- ES=1; // 串行口中斷
- EA=1; // 總中斷允許
- while(flag_xj) //循線標志位
- if(flag_REC==1)
- break;
- //有信號為0 沒有信號為1
- if(right_led==1&&middle_led==1&&left_led==1) //三路檢測到黑線
- Left_moto_stop=1;
- Right_moto_stop=1;
- run_pwm();
- else
- if(right_led==1&&middle_led==0&&left_led==0) //右邊檢測到黑線
- Left_moto_stop=1;
- rightrun_pwm();
- if(right_led==0&&middle_led==0&&left_led==1) //左邊檢測到黑線
- Left_moto_stop=1;
- leftrun_pwm();
- if(flag_REC==1) //
- flag_REC=0;
- if(buff[0]=='O'&&buff[1]=='N') //第一個字節(jié)為O,第二個字節(jié)為N,第三個字節(jié)為控制碼
- switch(buff[2])
- case up : // 前進
- // send_str( );
- flag_xj=0; //尋跡置0
- Left_moto_stop=0;
- Right_moto_stop=0;
- run();
- break;
- case down: // 后退
- // send_str1( );
- flag_xj=0;
- Left_moto_stop=0;
- backrun();
- break;
- case left: // 左轉(zhuǎn)
- // send_str2( );
- flag_xj=0;
- leftrun();
- break;
- case right: // 右轉(zhuǎn)
- // send_str3( );
- flag_xj=0;
- Left_moto_stop=0;
- rightrun();
- break;
- case stop: // 停止
- // send_str4( );
- flag_xj=0;
- Left_moto_stop=0;
- keepstop();
- break;
- case Car : //
- flag_xj=1;
- break;
